Madratter
Reged: 01/14/13
Reviving an old observatory or start over?
#5623574 - 01/14/13 10:34 PM
I have a roll off roof observatory that has a number of problems and I'm trying to figure out whether I'm better off fixing what I have or tearing it down and starting over. Obviously I would prefer not to do that. The observatory is 12x10. I will be using it with my 20" Dob or my other telescopes. It was built originally with the Dob in mind.
Problem 1: Dirt floor. For this app, do you think I need to poor a floor, or can I just use patio stones? I could either do the entire floor or leave where the rocker box sits bare dirt.
Problem 2: The roof rolls off to the North. The door into the shed is to the South. Because I wanted a low south view, I built one half of the wall up only half way. I can then open up the wall on that side. Between that and the door, if I time things right I can get a view pretty far South. The problem is that because of that, the two side walls are not tied together at all on the South end. The result is predictable, the outside walls want to shift out. One possible solution is a wire cable with a turnbuckle between the two sides.
Problem 3 - My door was just double layer plywood with some hinges. a) the hinges are not heavy duty enough. b) the door is totally falling apart. c) The wall it hinges to shifts somewhat, again because there is no cap plate, etc. The door is quite wide and needs to be to get the 20" in and out (4 feet wide). I'm thinking about again building one out of plywood, but this time using 1x1s inside and then skinning it with the plywood.
4) I get water in the observatory because of gaps between the roof and the walls on all sides. I think I can fix the gaps on the side by going up with 1x8's or something from the top of the outside bottom section. On the North side, I can probably go down with a 1x8 secured to the 2x4s that make up the bottom frame of the roof. But I'm at a loss what to do with the South side with the door.
5) I used wavy steel roof sheeting (whatever they call that stuff) for the roof. Unfortunately although I capped it with the piece they sold, and I used the waffle boards for it to lay on, on the side, those waffle boards did not hold up to exterior weather well and have fallen apart. This leads to gaps between the cap and the roofing, again which leak.
I'm thinking of pulling the roof on that side and putting down strips of 1x4 or 1x3 which I used on the other side and which have held up much better. While doing that, I have the obvious option to replace the roof material entirely. Any suggestions one way or the other.
Obviously I would rather not start over if I can avoid it. The roof DOES work and I remember what a pain making it in the first place was.
Thanks for any suggestions.
JJK
Reged: 04/28/08
Re: Reviving an old observatory or start over?
[Re: Madratter]
#5623596 - 01/14/13 10:51 PM
Please add a few images of the structure.
mich_al
Reged: 05/10/09
[Re: Madratter]
#5623615 - 01/14/13 11:04 PM
Sounds like you know what the problems are, what needs to be done and how to do it. I almost always opt for fixing rather than replacing, well for equipment anyways. Wifes not so much, don't know much about fixin them. I'd want to pour a floor I think. Dirt (even with pavers) and moisture just go together. My vote is go for observatory version 2.0, the modification of version 1.0.
Madratter
Reged: 01/14/13
[Re: mich_al]
#5624557 - 01/15/13 02:38 PM
I'll have to get some pictures. If I pour a pad, how thick do I need to make it? And do I need to leave where I setup the telescopes isolated from it? That is an issue because where I place the Dob is different from where I place the other scopes. (The Dob needs to be closer to the Northern end to get the best southern views and to give it space to be down for working on it, collimating, etc., but that does limit the view to the North. The other scopes are more centered. The paving stones are less work and less permanent. On the other hand, depending how thick the pad needs to be, that might be cheaper.
Mary B
Reged: 05/21/10
Loc: Minnesota
[Re: Madratter]
#5624937 - 01/15/13 06:32 PM
Move the door to the north end, patio stone on packed sand works. Pour just a pad for the dob. then rebuild your south wall for full drop down. Carol solved the side leaks with garage door weather strip.
Madratter
Reged: 01/14/13
[Re: Mary B]
#5624992 - 01/15/13 07:12 PM
The idea about moving the door to the North is just the kind of thing I would never have thought of myself and that would solve so many problems. What a great suggestion!
JJK
Reged: 04/28/08
[Re: Madratter]
#5625146 - 01/15/13 08:35 PM
Most of the concrete pads (i.e., not structural elements) I've seen and worked with tend to be about 4" thick. They have a crushed gravel base, and reinforcing material (e.g., a rectangular metal mesh) within the pour. I would not want a dirt or paver floor in my observatory.
stmguy
Reged: 10/11/12
Loc: Western NH
[Re: JJK]
#5625762 - 01/16/13 08:37 AM
Not sure how tall your walls are but if they are tall enough an option might be, pour a pad for Dob, use 2x8 pressure treated floor joists and plywood floor isolated from pad
Norm
Madratter
Reged: 01/14/13
[Re: stmguy]
#5625898 - 01/16/13 10:06 AM
Norm
Unfortunately, the walls are only about 6' tall to keep sight lines better, so there really isn't room for doing that. Also I have some refractors, and that would put the eyepiece at very low levels.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
[Re: Madratter]
#5625934 - 01/16/13 10:25 AM Attachment (27 downloads)
I would never leave my dob on bare dirt. Moisture, plus mice, etc., finding their way in.
That seems very high for a dob. My dobservatory has 3' high walls for my 16", to get as low to the horizon as possible.
Here is how I sealed the spacing between the roof & the walls, as Mary mentioned. I've never had any moisture whatsoever, even with my usual storms of "sideways" snow & rain storms. This is just garage door bottom stripping that I think comes in 9' lengths. I just stapled it on the top of the walls.
*skyguy*
Reged: 12/31/08
Loc: Western New York
[Re: csa/montana]
#5626073 - 01/16/13 12:01 PM Attachment (18 downloads)
"Great minds think alike." I also used garage door bottom molding between the walls and the roll off roof in my 11 year old observatory. Snow or rain has never made it past this flashing system.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
[Re: *skyguy*]
#5626093 - 01/16/13 12:12 PM
Madratter
Reged: 01/14/13
[Re: csa/montana]
#5626964 - 01/16/13 08:33 PM Attachment (23 downloads)
Here are some pictures of the observatory in its current state. My apologies for the poor quality but it was drizzling and a good camera didn't seem like a good idea.
Wmacky
Reged: 11/24/07
Loc: Florida
[Re: Madratter]
#5627008 - 01/16/13 08:56 PM
I did the same,but even had to have mine transported. In the end, not much was left of the original, and I wasted a lot of time stripping old stuff off. It was probably a bad idea.
Here's the thread......
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5027475/page...
Edited by Wmacky (01/16/13 08:57 PM)
Madratter
Reged: 01/14/13
[Re: Wmacky]
#5627110 - 01/16/13 10:04 PM Attachment (12 downloads)
I did the same,but even had to have mine transported. In the end, not much was left of the original, and I wasted a lot of time stripping old stuff off. It was probably a bad idea. Here's the thread...... http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5027475/page...
Thanks. I'll need to read that thread.
Some more pics.
Madratter
Reged: 01/14/13
[Re: Madratter]
#5627114 - 01/16/13 10:05 PM Attachment (15 downloads)
The North side where I would put move the door. The roof is open.
Edited by Madratter (01/16/13 10:06 PM)
Madratter
Reged: 01/14/13
[Re: Madratter]
#5627118 - 01/16/13 10:08 PM Attachment (13 downloads)
Part of the South side that I would need to modify for drop wall.
Madratter
Reged: 01/14/13
[Re: Madratter]
#5627119 - 01/16/13 10:08 PM Attachment (10 downloads)
And the other half of the South side.
Madratter
Reged: 01/14/13
[Re: Madratter]
#5627123 - 01/16/13 10:10 PM
As can be seen from all of this, my carpentry skills are "modest". So whatever I do either starting over or modifying this one has to take that into account.
Dan G
Reged: 06/27/06
Loc: Minisink, NY, USA
[Re: Madratter]
#5627183 - 01/16/13 10:44 PM
I would open the roof, jack up the walls 6" (a few ways you could accomplish this), pour a concrete floor, place pressure treated sills under the walls and reset the building. The other issues can be addressed but you need a sound foundation for the structure AND a good, clean, dry platform for the scope.
Dan in NY
