What to do with an old DSLR?
#1
Posted 14 January 2013 - 11:29 PM
#2
Posted 15 January 2013 - 12:43 AM
#3
Posted 15 January 2013 - 12:47 AM
I would however make it an IR camera or something..that would be a great way to expand your daytime photography..
Would be pretty easy...just buy an IR filter and install it inside the camera, replacing the stock filter with it.
Again, that is if you are doing it yourself..
If none of that works, find someone in your family that is a bit creative and see if they would like to try photography..
I have an old camera sitting around collecting dust that I will probably give to my niece sometime...
#4
Posted 15 January 2013 - 12:50 AM
Interesting question... was thinking of selling my 40D too. It's not worth much any more though. Maybe I should mod it too... I wonder if the instructions for our cameras are out there.
Mike: ***HERE*** or ***HERE*** (just use your IP to translate..)
OP: ****HERE****
#5
Posted 15 January 2013 - 12:56 AM
#6
Posted 15 January 2013 - 08:49 AM
How important is something like a Baader filter? I can't seem to find them for less than $150 a which point it starts to not make common or financial sense to do any more. Is there any cheaper alternatives other than just clear glass?
#8
Posted 15 January 2013 - 09:52 AM
Alex
#9
Posted 15 January 2013 - 11:11 AM
#10
Posted 15 January 2013 - 11:31 AM
#11
Posted 15 January 2013 - 11:38 AM
Thanks Brent.... whoa... looks like ample opportunity to screw up.
Ya I don't blame you fro being wary. I had heard about modding when I first got the 300d, but I didn't want to take the risk. The 300d body is probably worth $50 or less now, so if I mess up it's not the end of the world. Your 400d body is still probably worth at least $150 so a mistake on it would be more expensive.
#12
Posted 15 January 2013 - 12:44 PM
#13
Posted 15 January 2013 - 10:10 PM
Hmmm I had been looking at http://ghonis2.ho8.com/rebelmod.html where they replace with just clear glass. At ~$25 it's fairly reasonable to do.
baader filter is not THAT important. It will provide absolute best IR Blocking possible, period.
BUT, the difference is VERY minimal and you can easily get away with only using a clear glass replacement for LPF-2 (**assuming LPF-1 remains intact**)
No..not that I am aware of..Is there any cheaper alternatives other than just clear glass?
I have pre-cut clear glass replacements(I buy in large sheets and cut my filters to size, very cost effective).
Good luck!
#14
Posted 15 January 2013 - 10:40 PM
I have pre-cut clear glass replacements(I buy in large sheets and cut my filters to size, very cost effective) that I usually sell for very little $...fwiw
Good luck!
Yes but alas the 300D only has one filter. So this wouldn't work.
I read This today (boy that took a while) and I now understand a lot more. I could do a full spectrum mod by replacing with clear glass, but then I'd only be able to use it with a reflector (which I currently don't own).
I think I'm kinda stuck. I may just do the full spectrum mod just for fun, but baring spending more than the camera's worth, I don't think I'll be able to use it for anything. Maybe I'll find someone with a reflector I can sell it to and at least recoup some of the costs.
#15
Posted 15 January 2013 - 10:56 PM
Phil
#16
Posted 16 January 2013 - 10:26 AM
Grant
#17
Posted 16 January 2013 - 10:36 AM
I would think a 300D (with larger than average pixels) would make a pretty good astro camera!
Grant
Yet again unfortunately no. I guess the technology has just improved so much that it outweighs the larger pixel size. It only goes up to 1600 iso and there is signicicant noise at that point. I'd say you have to keep it 400 iso and less to keep the noise down, which is much worse than any of the more recent cameras.
#18
Posted 16 January 2013 - 05:04 PM
#19
Posted 16 January 2013 - 05:25 PM
I have an old digital rebel 300d that I no longer need. I've tried selling it as a camera, but nobody seems to want a 6 mp camera anymore. I was wondering, if I modded it, would it have any value to an astrophotographer or would I just be wasting my time and money?
Don't know how many other hobbies you have, but DSLRs have been turned into Nature Cams, Weather Cams, Sunset Cams...
There's a whole industry around adding remote triggers and such.
Might as well get some use out of it, eh?
#20
Posted 16 January 2013 - 07:36 PM
#21
Posted 16 January 2013 - 08:32 PM
+1
