Michael Morris
Member
Reged: 01/05/05
Loc: Worcestershire, UK
Sound on remote computer?
      #5626626 - 01/16/13 05:21 PM
I'm in the process of changing my set up so that I open up the observatory, set up the kit, then run an imaging session from the warmth of my study. At each end of the system I have a 1GB RAM machine running XP home. I have limited band width and a monthly limit on my internet usage, so I want a system that has a relatively low impact on computing power, internet bandwidth and information transfer.
So far I've downloaded and workout how to use RealVNC to control the observatory computer from the study and I've jerry-rigged a Philips SPC 900NC webcam to monitor the scope. The study computer can now control the scope and I can see it moving on the webcam.
The next thing I'm after is getting the study computer to pick up sound outputs from the observatory computer. RealVNC doesn't seem to do this. I want this option for two reasons
1 - so that I get audible alarms on the study computer from software running on the observatory computer
2 - so that the webcam microphone can pick up noises inside the observatory (mainly the scope slewing).
Has anyone any ideas about the best/cheapest/easiest/ lowest computing power way to achieve this?
johne
Reged: 11/10/06
Loc: Prescott, AZ.
Re: Sound on remote computer? new [Re: Michael Morris]
      #5627582 - 01/17/13 08:22 AM
If you're running Windows XP Pro on both ends, using the Remote Desktop that comes with XP Pro will provide the remote computer's sound on your study machine (as long as both computers have sound capability.)
I had this running under XP Pro and have since upgraded to Windows 7 Pro and its works that way as well.
Michael Morris
Member
Reged: 01/05/05
Re: Sound on remote computer? new [Re: johne]
      #5628122 - 01/17/13 01:45 PM
Thanks John.
As I said in my original post, both machines are running XP home.
johne
Reged: 11/10/06
Loc: Prescott, AZ.
      #5629429 - 01/18/13 07:30 AM
Sorry Michael. Apologies for missing that.
Charlie B
Reged: 03/22/08
Loc: Sterling, Virginia
      #5629579 - 01/18/13 09:56 AM
You may want to check here.
Charlie B
LoveChina61
Reged: 06/20/09
Re: Sound on remote computer? new [Re: Charlie B]
      #5631196 - 01/19/13 09:26 AM
I advise you get the following webcam off of Amazon.com or Ebay: "Foscam FI8918W Wireless IP Cam Wifi IR-LED WiFi Camera".
The webcam can be set up in 1-2 minutes to operate while plugged directly into your computer's USB port. It provides sound and you can pan/tilt and turn its IR light on/off via the computer. It even has its own external speaker so you can talk to someone else who is out in your observatory, but the broadcast quality is not so good. However, the webcam's ability to listen is very good. I can't imagine operating my observatry without it!
The webcam can also be set up for access via the web. It has its own webpage and you can login with your own Username and Password to view from anywhere in the world. The set up of this feature was not very easy, however. I finally found a decent video on youtube.com that helped me out a bit but it was still challenging as I had never gone into my modem and opened up a remote port and the like. However, for your needs where you can plug the webcam directly into your observatory computer's USB port it will do a great job!
JAT Observatory
NOT a Wimp
Reged: 02/20/05
Loc: In the Primordial Soup
      #5631263 - 01/19/13 10:19 AM
Check your PMs. This worked for me on a mobile PC running XP Home. It takes about 10 mins to do once you read everything.
3 registered and 12 anonymous users are browsing this forum.
Moderator:  Bowmoreman, richard7
