Privacy Policy |
Please read our Terms
of Service | Signup and
mitaccio
Reged: 03/17/09
Loc: Oahu, Hawaii
1.25" T Adapter vs. SCT T Adapter
#5626705 - 01/16/13 06:07 PM
I currently have a Nexstar 8SE SCT scope and a Canon T3i. I want to take some solar system images and need to get the T Adapter. I wanted to know what is the better adapter, the SCT or generic 1.25". Each has it's own obvious advantages, but I want to know if there is a reason to get one over the other.
Midnight Dan
Reged: 01/23/08
Re: 1.25" T Adapter vs. SCT T Adapter
[Re: mitaccio]
#5626733 - 01/16/13 06:20 PM
Definitely get the SCT adapter. You'll get a much more solid connection to the scope.
Just curious, what do you see as "obvious advantages" of the 1.25" adapter?
-Dan
mitaccio
Reged: 03/17/09
Loc: Oahu, Hawaii
[Re: Midnight Dan]
#5626827 - 01/16/13 07:24 PM
You can use the 1.25" adapter on any scope. you aren't limited to using it on a SCT. It's more future-proof if I ever get a Newt or Refractor.
Midnight Dan
Reged: 01/23/08
[Re: mitaccio]
#5627191 - 01/16/13 10:47 PM
Ah, I see. Personally though, I wouldn't use a DSLR on a 1.25" barrel connector. There's just not enough stability with that small of a tube, plus it limits the view and can cause vignetting.
Using a T-to-2" adapter gives a much more solid connection, although it does require a 2" diagonal or visual back (or focuser in the case of a different scope type). And the larger opening does not constrict the optical path.
I'd still go for the SCT connector as my first choice, but a 2" adapter would be ok too.
-Dan
10 registered and 12 anonymous users are browsing this forum.
Moderator: Undermidnight, fishonkevin
