Eric63
Reged: 06/16/12
Loc: Ottawa, Ontario
Low Power EP for 127mm Mak new
      #5625323 - 01/15/13 10:17 PM
I currently use a 2 inch 32mm 70 degree Titan as a low power eyepiece in my 127Mak. I love the view I get in this eyepiece and I can get approximately 1.5 degree FOV. I'm therfore wondering if a 38mm 70 degree eyepiece would also work, or is it too low for this scope. I have the SW 127Mak, which came with a 2 inch diagonal, however the visual back is less than 2 inches.
Thank you
Eric
Ed Holland
Reged: 06/16/10
Loc: San Jose, CA and Oxford, UK
Re: Low Power EP for 127mm Mak new [Re: Eric63]
      #5626221 - 01/16/13 01:42 PM
You'll get something, but there will be vignetting. I use a ~60° 35mm (1.25") as my lowest power EP on the 127. This has some vinetting, but you have to look for it - for casual observing it is not intrusive. It's most easily detected when looking at the out of focus diffraction pattern of a star. The rings will appear distorted/cut off as you move the scope to place the star at the edge of the field in the EP.
Can you give the setup a try before purchasing?
Ed
Eric63
Reged: 06/16/12
Re: Low Power EP for 127mm Mak new [Re: Ed Holland]
      #5626804 - 01/16/13 07:00 PM
Thank you Ed. I'm mostly a visual observer, and with my limited experience I have yet to recognise any vignetting. I think I will take your advice and see if I can try out a 38mm EP first. Right now I like the 1.5 degree FOV that I have with 32mm. I guess I'm just trying to get a bit more sky in my view
Eric
Ed Holland
Reged: 06/16/10
Re: Low Power EP for 127mm Mak [Re: Eric63]
      #5626896 - 01/16/13 07:59 PM
I don't blame you for trying. Not until I tried to look at the Pleiades, did I realise what restricted field of view really meant. That said, I purchased the scope as a convenient means of planetary viewing and to satisfy a curiosity about catadioptric instrument designs. For these purposes, it has served very well indeed
Ed
17 registered and 43 anonymous users are browsing this forum.
