Lane
Reged: 11/19/07
Loc: Frisco, Texas
Sky Safari not connecting to Sky Commander new
      #5538686 - 11/25/12 12:45 PM
I got my new T-Rex mount with the Sky Commander and both are working great. But when I tried to use it with my SKYFI wifi unit, iPad 3, and Sky Safari it is not connecting.
I have used this setup with my Orion Sirius and my CGEM many times so I thought I knew everything I needed to know, but I obviously have something wrong because I am getting a message that indicates it is unable to connect. I have the Sky Commander selected in Sky Safari, have it set to the altaz pushto setting, and I have the SKYFI unit selected in my iPad Settings.
When I click the connect button the green light on the SKYFI blinks and then I get the unable to connect message.
If anyone has an idea of what I might have set incorrectly I would appreciate your input.
Chucky
Reged: 04/16/10
Loc: Dublin, Ohio
Re: Sky Safari not connecting to Sky Commander new [Re: Lane]
      #5538885 - 11/25/12 02:53 PM
Try hitting the Reset button on your SkyFi and see if that helps.
Chucky
Reged: 04/16/10
Loc: Dublin, Ohio
Re: Sky Safari not connecting to Sky Commander new [Re: Chucky]
      #5538897 - 11/25/12 02:56 PM
Also check out these potential issues/fixes: Bottom of page.
http://www.southernstars.com/products/skyfi/scope_communication.html
btschumy
Vendor - Simulation Curriculum
Reged: 04/13/04
Loc: Longmont, CO, USA
      #5538942 - 11/25/12 03:19 PM
Lane,
What serial cable are you using with the SkyCommander? You cannot use the Sirius mount cable as the two devices have different pinouts. You need a serial cable designed to work with SkyCommander.
Bill
Chucky
Reged: 04/16/10
Loc: Dublin, Ohio
Re: Sky Safari not connecting to Sky Commander new [Re: btschumy]
      #5539141 - 11/25/12 05:36 PM
Bullet #6 in the SkyFi Trouble Shooting section of their web site pretty much sums up what Bill has indicated.
<< Make sure you're using the correct serial cable combination for your telescope. >>
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5550912 - 12/02/12 07:44 PM
Thanks guys,
Sorry for the late response but I had pressing business that pulled me away for a week.
I was indeed trying to use the same cable I used for the Sirius mount, but I see now that is not going to work. I found a diagram that shows how to build the correct cable and have purchased the crimping tool and materials I need to do that. I will make the cable this week and try again to make the connection to the SkyFi and iPad.
Edited by Lane (12/02/12 11:39 PM)
GaryJCarter
Reged: 06/06/09
Loc: Fairview, Texas
      #5551562 - 12/03/12 06:37 AM
Where is this schematic made available?
tezster
Reged: 07/14/09
Loc: Missisauga, Canada
      #5551643 - 12/03/12 08:27 AM
Do you still have the cable that comes with the Sky Commander used for Flash programming (the one that's connected to the serial adapter - see below)? I believe that can also be used to connect to the SkyFi.
Edited by tezster (12/03/12 08:28 AM)
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Sky Safari not connecting to Sky Commander new [Re: tezster]
      #5553277 - 12/04/12 03:01 AM
http://www.southernstars.com/products/skyfi/files/SkyFi-SkyTracker.pdf
jloweva
Reged: 01/09/12
      #5618824 - 01/12/13 11:09 AM
Guys:
I am having the same issue. I tried building a homebrew cable using the two pinout diagrams but for some reason it does not work. Currently, I am just using the serial/db9 that came with skyfi connected to the serial db/9 that came with sky commander, reversing the ends of the serial inserted into the sky commander db9 and it works perfectly. But my goal is to eliminate all that excess cable/db9s. I bought black phone cable at radio shack, an rj11 crimping tool and some rj11 4-pin connectors, followed the pinout diagrams, but still no luck. Any thoughts? Would love to talk with someone who had been succesful with this.
Edited by jloweva (01/12/13 02:44 PM)
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Sky Safari not connecting to Sky Commander new [Re: jloweva]
      #5619928 - 01/12/13 10:23 PM
Well I put it off for a while because I was too busy, but I am going to try building the cable right now. I will let you know my results. If it doesn't work then I will do the same thing you are doing with the DB9's. Assuming I have a DB9 with my skyfi. I actually bought the starseek unit from Orion and I don't remember it coming with a DB9 cable, but my memory sucks so I need to check the box it came in.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5620040 - 01/12/13 11:56 PM
Cable is made, but I don't guess I can test it until I get some stars in the sky. I think I will have to align the TRex mount using sky commander first and then establish the connection and see what happens. Unless I am missing something
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5622059 - 01/14/13 02:11 AM
jloweva - my cable did not work either. I am certain I am creating it correctly so I think something else is wrong.
I am wondering if Sky Tracker and Sky Commander really do have the same pin-outs. Those instructions are actually for Sky Tracker not Sky Commander.
I did not get a serial cable with my Sky Commander or my SkyFi unit. So for now I am not going to be able to use my iPad at all with my TRex as I had hoped.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5625053 - 01/15/13 07:43 PM
Well Mike just PM'd me and pointed out something I misread in the document. So I need to reverse two wires and the cable should work. I will give this another try.
jloweva
Reged: 01/09/12
      #5626863 - 01/16/13 07:42 PM
I figured out what I was doing wrong. I forgot that one essentially needs to do the opposite end up side down, as you are inserting it in a mirror image. In other words, rather than having the wire run straight, I had to introduce a 180 twist. Works perfectly and greatly reduces clutter. PM me if you want to talk live.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Sky Safari not connecting to Sky Commander [Re: jloweva]
      #5626903 - 01/16/13 08:04 PM
I am trying mine tonight, got some nice clear skies out there.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5627315 - 01/17/13 12:58 AM
Success!
I had two of the wires backwards, I connected Transmit to Transmit and Receive to Receive but it had to be Transmit connected to Receive. Duh.
Now I can just align with Sky Commander and find things with Sky Safari, just as I wanted. Not that Sky Commander is not a pretty cool little device but I just find it easier to search for something in sky safari and then move the scope until the pointer is over the object. This is all so cool, sure beats the old days.
k9yr
Reged: 05/21/08
Loc: Far North suburbs of Chicago
      #5635450 - 01/21/13 05:57 PM
I had to build my cable as well, but it would be nice to purchase one that was 1-2 feet long already built. There is a business opportunity for this cable...hint hint
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Sky Safari not connecting to Sky Commander new [Re: k9yr]
      #5646890 - 01/27/13 08:37 PM Attachment (20 downloads)
I thought I would post this here too. You are looking directly at the ends of the wires in this diagram. To make the wire you just need a crimping tool for a 6P plug.
AstroGabe
Reged: 01/10/10
Loc: SE Wisconsin
      #6311556 - 01/14/14 01:33 AM
Lane,
Your diagram has been very helpful in my attempt to get my SkyFi connect to my Sky Commander. Works like a charm now with my new DSV-3! Thanks!
Gabe
2 registered and 12 anonymous users are browsing this forum.
Moderator:  richard7, kkokkolis
