ZuoZhao
Reged: 10/16/12
Jupiter 20130108 in SHENZHEN ; A warm night~
#5627722 - 01/17/13 09:59 AM Attachment (134 downloads)
A warm night in winter. Seeing became good,I dont need to trill in cold wind. Let's take a warm Jupiter. Again,took the moons around Jupiter similar they original position.
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 20130108 in SHENZHEN ; A warm night~
[Re: ZuoZhao]
#5627874 - 01/17/13 11:23 AM
Beautiful.
karlo
Reged: 05/21/09
Loc: Yorkshire,UK, BLIGHTY !!
[Re: Rankinstudio]
#5628234 - 01/17/13 02:52 PM
You are in a thread of pure gold at the moment- superb shot !!
anemec
Reged: 01/26/10
Loc: Oklahoma
[Re: karlo]
#5628514 - 01/17/13 05:25 PM
Wonderful.
What is your processing routine, if you don't mind my asking? I have the ASI120MC and am curious how other people handle their post imaging processing.
Tassydevil
Reged: 08/17/11
Loc: Tasmania, Australia
[Re: anemec]
#5628648 - 01/17/13 06:42 PM
Very nice.
azure1961p
Reged: 01/17/09
Loc: USA
[Re: Tassydevil]
#5629098 - 01/17/13 11:11 PM
What size scope? This is stunning.
Petr
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
[Re: azure1961p]
#5629170 - 01/18/13 12:12 AM
Wow!I think I need to use ASI120MM instead of ASI120MC.Can't be lazy any more
ZuoZhao
Reged: 10/16/12
[Re: anemec]
#5629356 - 01/18/13 05:04 AM
Wonderful.
It seem you need some basic articles. Maybe some can help you. I dont have a link in English. My routine not an exception as usually. Capture>AS2>R6>JUPOS>PS But you need compare and try again and agin every step.
ZuoZhao
Reged: 10/16/12
[Re: azure1961p]
#5629357 - 01/18/13 05:05 AM
Petr
I use a Skywatcher DOB10 GOTO
ZuoZhao
Reged: 10/16/12
[Re: wenjha]
#5629359 - 01/18/13 05:06 AM
Jupiter passed ...
Ciarlotto
Reged: 03/26/11
Loc: Mondragone - Italy
[Re: ZuoZhao]
#5629363 - 01/18/13 05:14 AM
Hi, I see you use a Dob Goto (I've the SW 12" GoTo): I've noticed that my dobsonian isn't perfect in tracking objects (I make a perfect alignment) so I often have to adjuste the tracking by handset. Is your tracking sistem perfect or does it work not perfectly as mine? ... Your images are perfect!
ZuoZhao
Reged: 10/16/12
[Re: Ciarlotto]
#5629387 - 01/18/13 06:13 AM
OH...yes. We have the same system. It cant track perfect. So I must stay with computer all the time and correct object to center of screen.  And I must use a capture screen much wider than object.For example,800X640 for a 430X430 Jupiter. I must keep some space let Jupiter run fron one side to other side. unfortunately,a wider size ill limit the capture speed.For example,800X640 limit 50fps, and 640X560 will 60fps. So...my work really hard.
TorstenEdelmann
Reged: 09/29/04
Loc: Landsberg, Germany
[Re: ZuoZhao]
#5629389 - 01/18/13 06:19 AM
Fantastic image again. Given the consistent superb seeing on your location you should consider going for a bigger scope. Torsten
Ciarlotto
Reged: 03/26/11
[Re: TorstenEdelmann]
#5629392 - 01/18/13 06:30 AM
Thank you very much for your simply explanation. I can understand how hard is the "backstage" of your images. It's just difficult to take a single movie to obtain a single B/W image: I dont' image the work you have to do to make an RGB composition! Now, Appreciate even more your images.
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
[Re: Ciarlotto]
#5629549 - 01/18/13 09:29 AM
Superb detail again ZZ! As Torsten says a bigger scope would produce very special images in your location with that great seeing. Maybe a 14" Dob?
ZuoZhao
Reged: 10/16/12
#5629699 - 01/18/13 11:02 AM
Well... many thing must be considered. If I want to get presise tracking,a equatorial system must be. A big capacity EQ like Paramount will very expensive. Maybe, a DOB16 GOTO still a good choice.
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
[Re: ZuoZhao]
#5629712 - 01/18/13 11:10 AM
Just one question on the hard working side of imaging you told us about! What program do you use for imaging?
You could use Firecapture to do the Autoguiding for you, it really works great. Lately I did 3 hours imaging on a ROI of 320x320 with 4200 mm FL without even being at home! All avi's had Jupiter perfectly centered! Can't recommend it enough!
ZuoZhao
Reged: 10/16/12
[Re: Mert]
#5629743 - 01/18/13 11:20 AM
I still use SharpCap. Firecapture not work on my capture PC(it work on my processing PC but). I dont know whether a DOB support autoguiding. It is work like deep sky autoguiding? May you can tell me more detail. If it can autoguiding to a DOB, a big DOB will be great choice!
ZuoZhao
Reged: 10/16/12
[Re: ZuoZhao]
#5629848 - 01/18/13 12:14 PM
A simple question: autoguiding of Firecapture need a guiding telescope or not?
TorstenEdelmann
Reged: 09/29/04
[Re: ZuoZhao]
#5630230 - 01/18/13 04:34 PM
There is no guiding scope needed for autoguiding in Firecapture. You need an ASCOM driver for your DOB and I'm not sure if the guiding interface would work with an AZ mount.
