Privacy Policy |
Please read our Terms
of Service | Signup and
edwinh
Reged: 03/01/08
Loc: Chandler AZ
CG5 (as?) tripod - how to attach something else?
#5628220 - 01/17/13 02:45 PM
I have a CG5 and tripod... I think its one of the later ones, it has big tubular legs it doesn't look like some of the pictures of older ones I have seen.
I would like to be able to attach something else to the tripod for a head occasionally. Like my paragon bino mount for instance.
How can I get a normal 3/8 or 1/4 tripod bolt sticking out the top?
Research on this topic just confused me....
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
Re: CG5 (as?) tripod - how to attach something else?
[Re: edwinh]
#5628398 - 01/17/13 04:15 PM
Unscrew the 10mm center bolt and use a 3/8 or 1/4 bolt and washer...
edwinh
Reged: 03/01/08
Loc: Chandler AZ
[Re: RTLR 12]
#5628563 - 01/17/13 05:56 PM
Oh. yeah. I didn't even look at unthreading the existing rod or looking to see how its captured in the mount, thanks.
With just a smaller bolt there, would be no leg spreader. Some all-thread of the right length and or something could be made up into a longer assembly to get that attached also...basically just replace the central rod with a 3/8 one...
RTLR 12
Reged: 12/04/08
[Re: edwinh]
#5628632 - 01/17/13 06:31 PM
Now you've got it.
Stan
Cow Jazz
Reged: 11/24/03
Loc: Toronto, Ontario
[Re: RTLR 12]
#5634980 - 01/21/13 01:28 PM
I did the same thing for my CG5AS tripod to convert it to use with an LXDa55 mount: works great, and cost around 20 cents.
edwinh
Reged: 03/01/08
Loc: Chandler AZ
[Re: Cow Jazz]
#5636670 - 01/22/13 11:18 AM
Yes it did work great... just a 12" piece of 1/4" threaded rod and a some wing nuts and washers. Wanted 3/8" originally but the 3/8 threads half catch on the M10 threads in tripod, and didn't want to pull/strip anything. So using 1/4 and a tripod bushing.
Also took a very thick walled 3" ABS plastic cap and drilled a center hole in it - using that as a top plate as a head I wanted to try on it didn't sit right on the cg5 tripod itself.
Works out well and now have a multi-use tripod.
20 registered and 35 anonymous users are browsing this forum.
