StarmanDan
Reged: 08/27/07
Loc: Deep in the heart of Texas
My ISP is killing me!
#5624658 - 01/15/13 03:35 PM
Live out in the sticks so choices of internet providers is pretty slim pickins. Since I'm on the edge of cellular and satellite is a definite no, the only reliable service available is wireless WiFi. I hooked up with a local provider a few months ago and all was good up until a few weeks ago when my wife complained that she had issues with connecting to her company's VPN. I also discovered that I was no longer able to remote into my server or CCTV DVR. Checked my router settings and discovered that my WAN was no longer being assigned a public IP but now has a private IP assignment of 192.168.40.245. I've inquired about this to my ISP but they adamantly proclaim that nothing is wrong and that my service is correctly configured. I'm at my wits end. Every service provider I've used in the past has provided me with a public IP. Seems to me this shouldn't even be legal on the ISP's end to treat their customers as if they are on a private LAN.
rboe
Reged: 03/16/02
Loc: Phx, AZ
Re: My ISP is killing me!
[Re: StarmanDan]
#5624704 - 01/15/13 03:58 PM
It will cost you, but a static IP should be an option.
I have not seen the private IP addressing used that way so it's an eye opener for sure. Sounds like they are short of real IP addresses (which should not be the case with the move to IP6).
fmhill
Reged: 07/17/12
Loc: Cape Cod, Massachusetts, USA
[Re: StarmanDan]
#5624720 - 01/15/13 04:06 PM
Dan,
Are you sure you are not in an area covered by the Verizon Wireless digital network?
I've had similar problems to those you describe and three years ago I found I had coverage into the Verizon 3G digital network and acquired the gear on a 2 year contract. It has worked great, very reliable and I'm very satisfied with it. This past year, May, 2012, Verizon upgraded the local wireless digital service to 4G and offered me new gear and a $10 a month drop in the fee if I'd make the switch to the new network. Either the 3G or the 4G network link device includes a WiFi router and I connect to it from any of my computers for internet access as well as linking between computers as well as a wireless printer...
For me the Verizon Wireless network has proven to be well worth the $49 a month contract...
If you have either the Verizon 3G or 4G network in your area, I'd suggest exploring it as an option...
PM me your location and I can look on the Verizon Wireless coverage map...
Cliff Hipsher
Reged: 12/31/08
Loc: North Chesterfield, VA
[Re: StarmanDan]
#5625087 - 01/15/13 07:59 PM
From wikipedia:
"A private network is a network that uses private IP address space, in the Internet addressing architecture, following the standards set by RFC 1918 and RFC 4193. These addresses are commonly used for home, office, and enterprise local area networks (LANs), when globally routable addresses are not mandatory, or are not available for the intended network applications. Under Internet Protocol IPv4, private IP address spaces were originally defined in an effort to delay IPv4 address exhaustion, but they are also a feature of the next generation Internet Protocol, IPv6. These addresses are characterized as private because they are not globally delegated, meaning they are not allocated to any specific organization, and IP packets addressed by them cannot be transmitted onto the public Internet. Anyone may use these addresses without approval from a regional Internet registry (RIR). If such a private network needs to connect to the Internet, it must use either a network address translator (NAT) gateway, or a proxy server."
Your ISP is breaking the rules. Go get 'em...
StarmanDan
Reged: 08/27/07
[Re: fmhill]
#5625145 - 01/15/13 08:35 PM
I've looked into the Verizon MyFi but from what I gather they only work on up to 5 devices, I need more than that. I've looked at the coverage maps for multiple cellular data plans and they all say I'm in the coverage area. Problem is I'm in a deep valley of the Bosque river and 3G is spotty where I'm at. Using my phone, I usually have to get out on the main road before it picks it up reliably. Occationally I've let my wife tether my phone so she can work if the ISP is down, and while the download speeds appear adequate when it works, the upload speeds are very limiting especially for her VPN connection which needs pretty reliable and fast connections both ways.
fmhill
Reged: 07/17/12
[Re: StarmanDan]
#5625209 - 01/15/13 09:13 PM
You might want to talk to the wireless tech support people at Verizon. The new Jetpack device they are delivering with the 4G kits also operates on the 3G network. As a router it has 10 ports... The whole trick nwith Verizon is to get past the lower level people that answer phones and read answers of FAQ on a computer screen. If you can get to an advanced tech support person, they are good and can help you if there is a solution...
I'm very happy with Verizon service, I have switched my home phone from a wired landline to a Verizon Wireless home connect device which will travel with me in my RV trailer and saves me considerable money with its nation wide service. Its basically the same type of service as a cell phone except that you use a house type phone plugged into a black box device with a small antenna on it and the service is a flat rate $19.95 a month regardless of where you are and where you call in the ConUS... I've been using the home connect wireless service for about a year and a half now, and the wireless digital service and find them to be better than landline/cable service where I am located. That and with Dish Network satellite TV in the RV and I take all my home connection services with me where ever I go except for electricity... And for that I have a 420 watt SOLAR system and 210 AH worth of batteries in the trailer.
Point is, I really like the Verizon wireless services, I keep a laptop connected for e-mail and business purposes full time in the trailer... I also have a Verizon Cell phone but rarely use it as I have a Panasonic DECT 6.0 cordless phone plugged into the home connect with a DECT 6.0 rangebooster on the wireless and the portable handset works anywhere i go in a 600 foot radius around the local area... Its an excellent setup and I have very good internet access.
Edited by fmhill (01/15/13 09:18 PM)
JoseBorrero
Reged: 09/04/09
Loc: MI
[Re: fmhill]
#5625292 - 01/15/13 10:05 PM
http://www.mybluedish.com/
StarmanDan
Reged: 08/27/07
[Re: JoseBorrero]
#5625342 - 01/15/13 10:27 PM
The Jetpack looks enticing. Only prohibitive factor is the bandwidth cap. I really need something with an unlimited plan. With three kids and the wife working from home, we easily eat through almost 10GB a month. At $80/mo. for the 10GB plan from Verizon that's a little steep. Though I was paying almost that much for Sprint's 5GB data plan when I was closer in town. This may be my only resort if I can't resolve this issue with my current ISP.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
[Re: StarmanDan]
#5625425 - 01/15/13 11:11 PM
Why is sattelite a definite no?
What about HughesNet? - I know a guy who's wife works for the National Park service so he does his job from an RV. He is a computer programmer and connects to mainframes using VPN without any problems. She did tell me that he had to get their most expensive option to make it fast enough but I believe it was still only $100 a month.
StarmanDan
Reged: 08/27/07
[Re: Lane]
#5626463 - 01/16/13 04:02 PM
Aside from cost, satellite historically has had really bad latency. For things like remoting into a server or observatory for real time control, long latency can be a killer.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
[Re: StarmanDan]
#5626811 - 01/16/13 07:05 PM
They may have been slow in the past but those days are gone. The only real problem with them are storms interfering with the signal.
daev
Technically Enlightened
Reged: 03/10/04
Loc: On the edge of the desert
[Re: StarmanDan]
#5627016 - 01/16/13 09:01 PM
And for the foreseeable future it will be. ~250ms to the bird and back in addition to normal latency. Anyone who likes online games would hate you for buying that service.
Sounds like you're either going to have to lawyer up or find a new provider. They don't seem too thrilled with VPNs. Were I a suspicious type (and I am) I'd suspect you're being penalized for moving large chunks of data that packet sniffing can't decode due to the VPN encryption.
edit: not being able to remote in to your own PC is broken, as far as I'm concerned.
Or they could just be incompetent, or out of addresses, or too cheap to have someone properly configure things. I like Ron's idea of a static IP, if the added cost is still comparable to any other options you may have.
dave
Edited by daev (01/16/13 09:20 PM)
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
[Re: daev]
#5627032 - 01/16/13 09:14 PM
http://www.whatsmyip.org/
It's possible that your ISP is giving your an open 1:1 nat and that you can in fact get back using the globally addressable IP listed on that page.
daev
Reged: 03/10/04
[Re: Mike Phillips]
#5627090 - 01/16/13 09:55 PM
Oh! I'm not sure if this will be of use, but try replacing your ISPs DNS with a third party's DNS. There are many out there free to use, and it's an easy fix if that's part of the issue.
dave
StarmanDan
Reged: 08/27/07
[Re: daev]
#5628652 - 01/17/13 06:44 PM
Interesting thought on the free DNS. Looking into this, I've discovered that my router's DNS just happens to be Google's (8.8.8.8 and 8.8.4.4). So it would appear that my ISP is using a free DNS service and issuing private IP addresses to its customers. This is starting to really sound fishy.
groz
Reged: 03/14/07
Loc: Duncan, BC
[Re: StarmanDan]
#5629781 - 01/18/13 11:41 AM
I've dealt with this _a few times_. One of my clients has a network spanning over a thousand locations, and we have connectivity from just about every provider out there across that network. As for getting public ip from the isp, it's getting more and more rare. On a thousand connections, less than half actually get public ip today, and as we roll out new locations, that number is going steadily down. As far as the legality goes, just read your terms of service, and see what they say. The only time it would be an issue, is if your terms of service specifically state, a public routeable ip is to be provided. I've NEVER seen that on the terms for a low end consumer type connection. When it is offered, usually comes with a significant premium on the monthly billing for a business account. There are some operations where it's not offered at all. It is perfectly acceptable for an isp to treat you as if you are connected to a private network, because you are connected to a private network, one owned and operated by the isp. Refer to the terms of service to determine just what that means, and, what kind of connection to the public networks you should expect from that. Today, for many operations, if web browsers and email work transparently from the 'inside', that's considered 'fully functional'.
The trend today with most isp locations, for providing IPV4, is to deliver the endpoint in the form of a router, to which you can connect as many gadgets as you wish, they will all get private internal ip. On the isp side of that router, it may or may not get public ip, and, as noted above, the number that do get public ip, is steadily declining.
We solved this problem by creating a rather large internal vpn. We have a dedicated server, on a high bandwidth public location, which handles a couple thousand vpn connection. The routers at the client end, are configured to create a vpn connection to our central location, and set up appropriate routing over the vpn for internal use. But there are a few caveats.
Forget about using PPTP or IPSec protocols, just to many locations that wont pass them correctly. Both may come 'in the box' on a windows system, but they are rather brain dead when it comes to transparent routing. If the upstream router connections dont have specific support in them, for passing special protocols transparently, they just dont work reliably. We long ago switched to other methods for vpn connections, to make that problem go away.
The root crux of the problem, ip space in the IPV4 range is pretty much used up, there just isn't any more to give out. Masquerading internal networks was the initial cure, and, another layer of masquerade at the isp level is rapidly becoming common / necessary. IPV6 is a theoretical solution to the problem, that isn't working out to well in the real world, for a lot of reasons. While most desktop type computing systems can be upgraded, out in the real world, there are millions and millions of dedicated devices like point of sale terminals, and various data logging devices, that are not IPV6 capable, and, not going to get that way any time soon.
The bottom line today is, IPV4 address space is used up. If you _require_ publicly routeable IPV4 addresses, prepare to pay up, and, in many cases, smaller isp operations just dont have any to hand out, so, switch isp or 'figure it out'. We were forced to 'figure it out' because a lot of our location have exactly one choice for isp, and that choice doesn't offer any form of public addressing.
StarmanDan
Reged: 08/27/07
[Re: groz]
#5630340 - 01/18/13 06:08 PM
I was aware of the IPv4 issues but didn't realize the extent until last night. I was at my daughter's dance school surfing the net on the school's wifi when the thought occurred to me to see what their router had to say. To my surprise, their router wasn't secured at all, still set to the default user and password. Snooping around a little, I found that they, too, were on a private IP on their WAN and were even on a private DNS (whereas I'm apparently on Google's). So it would seem I'm skunked. I can either pay extra for a static IP, change providers yet again in the hopes that I can get a public, yet dynamic IP without paying extra, or sit where I'm at. For the time being I've found workarounds for most of my issues, though at the expense of losing some features that I've been used to, so I think I'll sit still for a while and see what happens. Like I said there aren't many options out here. Thanks for the advice and suggestions and letting me rant a little!
2 registered and 16 anonymous users are browsing this forum.
Moderator: Bowmoreman, richard7
