mtw4518
Reged: 09/12/12
Power source question
      #5631352 - 01/19/13 11:13 AM
I was going to buy a larger power tank to run my scope and dew zapper, but after reading all the comments on here about using a jump starter, I will go that direction. My only concern is the DC outlets on the power tank are fused at 10 amps, but all the jump staters I have found are 15 amp. Is this something to be concerned about?
Bob Griffiths
Getting Grouchy
Reged: 10/10/05
Loc: Frederick Maryland
Re: Power source question new [Re: mtw4518]
      #5631412 - 01/19/13 11:47 AM
NO....
Bob G
mtw4518
Reged: 09/12/12
Re: Power source question new [Re: Bob Griffiths]
      #5631450 - 01/19/13 12:06 PM
Arthur Dent
Galactic Hitch-Hiker
Reged: 10/23/08
Loc: South Yorkshire, UK
      #5631936 - 01/19/13 05:45 PM
To amplify Bob's answer,
No, the device will only draw as much current as it requires.
As long as it is 12V dc output, you should be fine.
Art
Midnight Dan
Reged: 01/23/08
Re: Power source question new [Re: Arthur Dent]
      #5631955 - 01/19/13 05:57 PM
None of your equipment will draw anywhere near 10 amps so you're fine.
-Dan
mtw4518
Reged: 09/12/12
Re: Power source question new [Re: Midnight Dan]
      #5632029 - 01/19/13 06:59 PM
So, no worries of the power source sending more amps than needed? The fuse is so the equipment attatched doesnt overdraw power?
Midnight Dan
Reged: 01/23/08
      #5632188 - 01/19/13 08:33 PM
Correct. The equipment only draws the current that it needs. A power supply cannot "send" more.
And yes, the fuse is there to protect the power supply, not the equipment that it is connected to. If the equipment were to develop a short circuit, it could start drawing hundreds of amps and, in the worst scenario, the battery could explode. The fuse prevents this from happening.
-Dan
mtw4518
Reged: 09/12/12
      #5632206 - 01/19/13 08:58 PM
Thanks I understand now, it makes perfect sense
0 registered and 9 anonymous users are browsing this forum.
Moderator:  KWB, WaterMaster
