Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Jupiter 1.19.13 with the ASI120MM new
      #5630854 - 01/19/13 12:06 AM Attachment (67 downloads)
Finally had a spot of good seeing to really give this cam a good run at Jupiter. Super impressed with the results.
Seeing was probably 7/10 Shot at 3:06ut
Large:
http://rankinstudio.com/Jupiter_1.19.13
Enjoy!
Retouched a bit:
Edited by Rankinstudio (01/20/13 11:28 AM)
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
Re: Jupiter 1.19.13 with the ASI120MM new [Re: Rankinstudio]
      #5630963 - 01/19/13 01:39 AM
Very good!
detail and comfortable color
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Re: Jupiter 1.19.13 with the ASI120MM new [Re: wenjha]
      #5631022 - 01/19/13 04:17 AM
That's impressive David, excellent result!
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 1.19.13 with the ASI120MM new [Re: Mert]
      #5631343 - 01/19/13 11:09 AM
Thanks Guys. I am wondering how this cam is more sensitive than the Flea3? I can shoot much higher frame rates and it also creates much larger video files in the same amount of time. Another thing that surprised me is I don't need any spacers at all to get Jupiter to fill up the chip? On the flea3 I have to put a lot of spacers on it to get Jupiter large enough on the chip. Great little cam.
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 1.19.13 with the ASI120MM [Re: Rankinstudio]
      #5631468 - 01/19/13 12:21 PM Attachment (19 downloads)
Reprocessed R50% RGB at 130%.
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5631606 - 01/19/13 01:40 PM
Very nice!
Tassydevil
Reged: 08/17/11
Loc: Tasmania, Australia
Re: Jupiter 1.19.13 with the ASI120MM new [Re: Sunspot]
      #5631910 - 01/19/13 05:27 PM
Very nice.
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5631953 - 01/19/13 05:56 PM
Good to see you finally got a break in the weather David. A fine image - well done!
Glenn
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 1.19.13 with the ASI120MM new [Re: DesertRat]
      #5632017 - 01/19/13 06:52 PM
Thanks guys!
Yes, finally some decent seeing. Tonight looks promising as well. Going to have to see what becomes of it
Cheers
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
      #5632247 - 01/19/13 09:29 PM
David, since Sam asked me to help "launch" this camera outside of China back in September 2012 I am still finding myself "gob-smacked" at times with its' performance.....at the time Sam sent me some images from a couple of Chinese AA'ers (himself & ZZ included if I recall correctly) and he thought then that it would out-perform the DMK618 camera, backing it up with some pretty strong evidence.....
I was reticent to "go the whole hog" and employ it in preference to my Flea3 because, as everyone knows, that camera has an extremely good reputation and I'd been using it very successfully for over 2 years...
To cut a long story short I have no hesitation now in stating from an empirical perspective that it is the better camera of the 2.....no problems with others disagreeing on this point but what I pulled last night at well under 30 degrees elevation only enhanced that personal appraisal..!
You've created a fine image here and I'm sure you'd agree that it should only get better with further useage!!!
As to the smaller pixel size in the sensor I find operating at considerably lower f/l's produces a really "sweet spot" but I now have a fully-fledged variable amplification fitting (home-designed naturally! ) that accomodates a whole range of image scales.
This morning the ASI120MM demonstrated its advantages with 50fps captures in all channels where the Flea could only approach said in the red, with blue being almost half that rate! Image scale at that comparison is smaller despite the smaller pixels - but I'm finding this scale to be in a really "sweet spot" for my C14 and as yet I'm not being handicapped by the image sizes...they are taking upsampling better than the (larger) Flea3 images would, which suggests to me it really is a winner on all fronts!
Will post my own results from last night/this morning when I get home tomorrw from my local dark sky site - and hope to see more fine images from you and others with this cam soon..!
zawijava
Reged: 10/06/07
Loc: Wells, Maine 04090
      #5632886 - 01/20/13 10:15 AM
I'm curious as to the availability of this camera in the US? thanks, -Tim
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 1.19.13 with the ASI120MM new [Re: Kokatha man]
      #5632968 - 01/20/13 10:59 AM
I have found everything you said to be true. I actually have my Flea3 posted for sale in the classifieds . I had got into this realm of imaging with the DMK21 and really enjoyed its ability to do long exposures. I was somewhat disappointed when I got the Flea3 and it couldn't do longer exposures. While the Flea3 is an awesome camera, I am fully sold on the ASI120MM as my main planetary cam now, and also surprised how well it does with deep space imaging.
Yes, I am still surprised how much Jupiter fills the chip at lower FL's, and how much more light I am getting. I am really itching to shoot Saturn with this thing as it has always been such a tough target with my setup.
Looking forward to seeing what you post!
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 1.19.13 with the ASI120MM new [Re: zawijava]
      #5632984 - 01/20/13 11:06 AM
You can buy it directly from Sam at ZWO Optical here:
http://www.zwoptical.com/eng/Cameras/ASI120/index.asp
The shipping is surprisingly fast.
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
      #5633020 - 01/20/13 11:25 AM
David, you got that zorro strike too! Nice!
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 1.19.13 with the ASI120MM new [Re: Mike Phillips]
      #5633102 - 01/20/13 12:25 PM
Thanks Mike
Yes, I noticed it during processing, interesting feature for sure.
10 registered and 13 anonymous users are browsing this forum.
Moderator:  Boot, bilgebay
