zambonikane
Reged: 01/14/11
Loc: West Chester PA
PHD problems
#5633281 - 01/20/13 01:53 PM
Hey everyone- Is there a guide to PHD guiding anywhere? I have been guiding with the orion st80/ssag combo for about a year now with little to no issues. Well, now that I got my 550d modded and picked up a clip in cls-ccd, my guiding is in the tank. The last three nights of imaging have been useless for me. My set up consists of an atlas mount with their 8in f4.9 reflector attached. I have it balanced so that it is a little heavy on the counterweight side, as well as the camera side in the declination axis. I have updated the firmware for the ssag, uninstalled then reinstalled PHD, and it still gives me poor results. Two nights ago it was taking over 50 steps to calibrate in the N-S axis and the E-W axis, so I changed the calibration step from the default to 2500ms, and that made the calibration take about 13 steps in the E-W but still about 42 in the N-S axis. When I look at my graph, one or both of the lines go off of the charts (last night the blue one was staying on the charts, but WAY off of the mid line, and the red line climbed and never came back. Any ideas? Thanks! Mike
dp297
Reged: 12/14/10
Re: PHD problems
[Re: zambonikane]
#5633315 - 01/20/13 02:16 PM Attachment (100 downloads)
There you are....
fmhill
Reged: 07/17/12
Loc: Cape Cod, Massachusetts, USA
Re: PHD problems
[Re: zambonikane]
#5633329 - 01/20/13 02:25 PM
As a user of the Orion SSAG with an 80mm guide scope with PHD in my setup on a CGEM DX mount with an ES127, and my own experiences getting my settup working, It sounds to me like the problem you are seeing is in the mechanical configuration of the OTA/mount/guidescope.
The three areas of possibility is Balance, flexure in the coupling between the guidescope and the imaging scope, or possibly cable catching and dragging.
First thing to look at is to make sure wires and cables are secured with a loop between the moving part of the mount and the fixed part of the mount to allow both axis to rotate in full range of directions that the scope will cover the sky on both axis and the wires and cables can not catch on any mount knobs or levers.
To eliminate balance as a cause, make a test image with the OTA/mount in perfect balance, do not set the balance heavy in any direction. With the clutches released, the mount should turn freely through the full range of motions. If this fixes the problem, then try setting the balance slightly heavy to the east and repeat an image test...
As to flexure, I can not tell you how to test for this, just that there should be a solid mechanical coupling between the guidescope and the imaging scope including the coupling of the cameras to the scopes for both the guide scope and the imaging scope, that any motion between the two combined camera & scopes will create problems with guiding...
One bit of advice, if you have changed to a longer focal length scope in your setup (which is the way I read your post), the longer focal length scope will be more critical to any parameters that affect guiding.
Not only does a longer focal length increase the apparent image magnification, it also increases guiding and tracking errors proportionately...
Edited by fmhill (01/20/13 02:33 PM)
dp297
Reged: 12/14/10
Re: PHD problems
[Re: fmhill]
#5633335 - 01/20/13 02:31 PM
what have u changed in between...besides adding the CLS and modding your camera?
fishonkevin
Reged: 04/29/07
Loc: Michigan
Re: PHD problems
[Re: dp297]
#5633434 - 01/20/13 03:38 PM
PM sent
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: dp297]
#5633444 - 01/20/13 03:43 PM
thanks for the help. It will give me something to do tonight. I imagine that each time I change a parameter in the settings, I should recalibrate. Is this the case? I have not changed a thing, other than what I have done to my imaging camera. I have always guided with the st80/ssag combo, and this scope/mount combo. mike
zerro1
Reged: 08/02/09
Loc: Smokey Point , 48.12°N 122.25°...
Re: PHD problems
[Re: zambonikane]
#5633461 - 01/20/13 03:57 PM
Well since you uninstalled and re-installed have you made any changes to RA agressiveness, or the MAX Dec pulse? Still want to adjust that Cal step... I would say to increase your step count to between 15 and 20 steps for calibration. How are you doing Polar alignment ? Have you checked your polar scope to make sure it's in alignment with the RA axis? Are you using EQMOD?
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: zerro1]
#5633582 - 01/20/13 05:11 PM
I'm doing the eqmod alignment technique for my polar alignment, and the polar scope was in line with the ra axis when I checked it last about 2 or three months ago. I will check that again when I go out next.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: PHD problems
[Re: zambonikane]
#5633594 - 01/20/13 05:17 PM
Many of the settings can be changed on the fly. Specifically, the ones that show up on the graph.
I'm assuming the problems showed up in your images as well as the graph... What did your images look like?
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: Footbag]
#5633618 - 01/20/13 05:30 PM
In my images, the stars were streaked in one direction. when i turned guiding off, the stars we streaked in the same direction (iirc), but just not as much - guiding was making things worse. After a couple of minutes, the guide star was out of the green box. Thanks again for taking the time to help me troubleshoot - i know you all probably have better things to do today!
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: PHD problems
[Re: zambonikane]
#5633648 - 01/20/13 05:47 PM
You said it took 50 steps to calibrate. Were you imaging something close to North Celestial Pole? The closer to the pole the longer it takes to calibrate. If that's the case, increase calibration step size.
Also, what was the sky condition like? Was the seeing bad? How bright was the guide star? I've had several cases when the guide star would disappeared from guide box and I believe it was due to either seeing condition degrading or high thin clouds may have came by. If that happens, sometimes it can confuse PHD and it may have thought the guide star moved too far so PHD over corrected.
Try again next time and make sure the quality of guide star is good. If the seeing is bad, increase exposure to increase SNR. It's okay to increase to as much as 5 seconds. Also decrease RA Aggressive way down to 50-60% for bad seeing conditions.
Peter
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: Peter in Reno]
#5633776 - 01/20/13 06:55 PM
I was imaging (or trying too) the horsehead nebula - pretty close to the ecliptic. The night was cloudless, but seeing was really bad. My exposure for the guide scope was 3.5 seconds. The star was pretty bright, but not the brightest in the frame - should I use the brightest star? I was afraid that it would take up too many pixels and mess up guiding. Thanks again! mike
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: PHD problems
[Re: zambonikane]
#5633810 - 01/20/13 07:24 PM
Wow. That does not explain the 50 calibration steps. Did you change guide speed rate in your mount via hand controller? If you lower the guide rate, then calibration steps will increase. Double check your mount's guide rate.
You said you updated the firmware for SSAG. Do you mean driver for your PC? If you update to use the latest driver, do you also have latest PHD at least version 1.12? I think the driver that came in CD disk works with PHD 1.11 or earlier. Updating PHD should not affect your previous PHD settings but double check.
It's okay to use a bright guide star, just don't over expose.
If you are using ST80/SSAG, then use default PHD settings. The only thing I would change is RA Aggressiveness for bad seeing condition. If you see a guide star is twinkling quite a bit, lower this setting between 50% and 60%.
Peter
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: PHD problems
[Re: Peter in Reno]
#5633851 - 01/20/13 07:52 PM
The only thing that stands out to me is the calibration step. 2500 seems high. I know you pushed it up in response to the calibration not working, but if the problem was unrelated, you may have to put it back and test other things.
Did you setup each night you had problems, or did you leave it setup overnight? I think you are saying you leave it setup.
Typically, when I have out of the blue problems like you are explaining, I find that I either forgot to tighten the guide-scope down, or have a cable dragging or not properly seated, or something simple that usually becomes clear in the breakdown. Maybe break everything down, set it back up, re-polar align, and image away and see how it goes.
fmhill
Reged: 07/17/12
Re: PHD problems
[Re: zambonikane]
#5633953 - 01/20/13 09:34 PM
Thanks again!
mike
Using a bright star for guiding should not be a problem however you say your using a 3.5 sec exposure? In my experience that is way to slow for a bright star. I normally use an exposure of .5 sec to 1 sec for reasonably bright stars in PHD...
I think you should list all the parameter settings on the brain page, a screen capture shot would be nice of all the parameters then we can get a better idea of what is going on...
Edited by fmhill (01/20/13 09:36 PM)
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: fmhill]
#5634160 - 01/20/13 11:42 PM Attachment (15 downloads)
Another night of frustration for me. I played with some settings, made sure that my cables were not snagging, or tugging on my setup, and froze my butt off. Here are some screenshots of the settings, my eqmod settings, and my graph. I guess I have some more work ahead of me.
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: zambonikane]
#5634163 - 01/20/13 11:43 PM Attachment (12 downloads)
eqmod settings
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: zambonikane]
#5634166 - 01/20/13 11:44 PM Attachment (20 downloads)
graph
fmhill
Reged: 07/17/12
Re: PHD problems
[Re: zambonikane]
#5634184 - 01/20/13 11:56 PM
The one thing I see that is wrong is the Max DEC duration should be set to the same value or larger than the RA Max... Having it set to 50 is part of the reason the red line climbs right up off the graph... For the sake of diagnosis, I would set DEC max duration to 1500 to see if it then allows the guiding to correct for this condition...
Why does the blue RA line on the graph stop suddenly just shy of the middle vertical line at the end of the second box? Did you stop guiding at this point or has something failed?
Edited by fmhill (01/20/13 11:57 PM)
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: fmhill]
#5634202 - 01/21/13 12:14 AM
Hey Mitch- guiding lacked the s/n ratio to keep on going, so I stopped it. I will have to adjust the RA max and have a go tomorrow. Thanks for the help! Mike
mmalik
Reged: 01/13/12
Loc: USA
Re: PHD problems
[Re: zambonikane]
#5634212 - 01/21/13 12:22 AM
To simplify, what you may really need is using PHD defaults after a fresh install and selecting 'Mount-On Camera' if you are using ST-4 guiding (which I would recommend instead of serial/ASCOM). That's really all what you need to do. Rest are just bells and whistles which I have never tinkered with nor would I suggest tinkering with. Thx
zerro1
Reged: 08/02/09
Re: PHD problems
[Re: zambonikane]
#5634257 - 01/21/13 01:09 AM
On my Atlas using a 50mm mini-guide scope; I set the RA aggressivness to about 75, I set the Hyst to 12 and MAX Dec to 550. Cal step to 1850. Then in the EQMOD/ASCOM I run the sliders under pulse guiding "rate" up to 30 to maybe 40.
before adjusting the rate in EQMOD my calibration was all over the place. I would certainly get the MAX dec and the rate adjusted first thing and see what that does for you.
I dug up this thread I posted back in August of 2011 PHD Settings Well Explained
zambonikane
Reged: 01/14/11
Re: PHD problems
[Re: zerro1]
#5841583 - 05/05/13 12:32 PM
Sorry to revive an old thread, but I thought I would update those who took the time to help me nail down the problem. About a month ago, I took my rig to another site to set up in hopes of catching Panstarrs. Once everything was set up, I went to fire up the mount, and nothing happened. After I got home, I inspected for missing/damaged/disconnected cables, checked the charge on the battery, and all of the other things that could have caused the mount to be dead. I opened the mount and noticed some soot around one of the components and after doing a little digging online, came to realize that my board was fried. I ordered a new one from Orion and everything seems to be back to normal. My graphs for the most part stay within one box of the center line and I am able to get clean subs (70% of the time) with out issue. I don't know if the failing board was responsible for my guiding issue, but replacing it seems to cure my ills. Thanks for the help! Mike
