Privacy Policy |
Please read our Terms
of Service | Signup and
rgm40
Reged: 04/15/08
Loc: Western Kentucky
Cleaning Meade 5000 SWA 24mm
#5634065 - 01/20/13 10:37 PM
Anyone ever been into the guts of this one to clean the lenses? Mine could use a cleaning. I already have the outer shell removed to lighten it up. Any info on the lens configuration and how to disassemble would be greatly appreciated. Thanks in advance.
REC
Reged: 10/20/10
Loc: NC
Re: Cleaning Meade 5000 SWA 24mm
[Re: rgm40]
#5634753 - 01/21/13 11:22 AM
I had some of that barrel grease on the eyelens and used a lens cleaning solution on it. Meade say's the coatings on it are pretty hard and won't damage cleaning it.
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
[Re: REC]
#5634795 - 01/21/13 11:58 AM
I have a pair of the Meade 5k SWA 24, both deshrouded for binoviewing. The idea never entered my head to take them apart to clean them. How do eyepieces become dirty between the lenses? Mine seem pretty tight and have never needed cleaning beyond the top of the eye lens and the bottom of the field lens.
rgm40
Reged: 04/15/08
[Re: Sarkikos]
#5635688 - 01/21/13 08:52 PM
"how do eyepieces become dirty between the lenses"
I wonder that myself. Perhaps some temperature extremes resulted (from first owner) in some internal fogging and leftover residue after drying out?
Regardless, I dove into it tonight. I'll have to say I have a new respect for lens makers after this. I didn't think I would be able to get it back together after taking it apart. I thought, "what in the world have I done." I had a sinking feeling that I had ruined my eyepiece. I took a deep breath and told myself I could do it. I had put all the lenses in the order exactly in the same orientation that I took them out, and had them on a microfiber towel (including all the spacers). One lens at a time I took them to the sink and cleaned them with a tiny drop of dawn in distilled water, cotton swabs (several), and a final rinse with only distilled water. One at a time I carefully put them back down that seemingly long eyepiece housing. I literally had to drop the first one in. The way I handled that is by placing a thin lens towel (microfiber) in the bottom to cushion the blow so to speak. The two widest lenses I had to just place evenly over the barrel and drop evenly and carefully, and hope for the best. I took my time and it worked out ok. I believe the trapped air offers some measure of cushion as the lens drops and air is forced out (as long as it is dropped evenly). Lastly, the final two elements from what I can tell actually touch each other. One is convex, and the other concave. This is one of the areas I was seeing a tiny bit of residue. In fact, there appears to be slight wear in this area that looks like a very thin ring approximately 1/4 inch in diameter. This is MUCH less noticeable now after cleaning. The way I handled this one was to blow of the lens towel and lay a corner of it across the concave (bottom lens). I carefully placed the final lens (convex side) and carefully slid out the lens towel.
Overall, now that it is over I am very glad I did it. Strictly speaking from an appearance standpoint the optics look much much better. Basically new except for that very thin ring I spoke of, which now you really really have to look closely to see. Even then it is barely noticeable.
HOWEVER, I do not recommend anyone try this unless you really know what you are doing, and unless you really really really need to. Point blank, I was lucky. Lucky I didn't scratch one of the lenses "dropping" them in the barrel. Lucky I didn't scratch one of the lenses using the lens towel as a slider. Lucky I didn't drop one of the lenses in the sink. I'm telling you, I was just plain lucky. Take extreme care if you try this. I don't know that I will ever do it again.
If I had it to do over, I might have tried to put the entire assembly together, standing up on a lens towel, then place the housing over the entire assembly, and carefully lift from the bottom with the towel to position eye lens. Thinking back, that might have been the best way to do it but that would be very tricky as well.
cjc
Reged: 10/15/10
Loc: Derbyshire, England
[Re: rgm40]
#5636715 - 01/22/13 11:45 AM
I have found that dropping lenses into the tube is not a good idea, because they can jam or flip over. The way I have done it is put the tube over a post (a permanent marker in my case). Then you place successive lenses and spacers into the tube to rest on the post, raising the tube to create the space needed as you go.
32 registered and 38 anonymous users are browsing this forum.
Moderator: ausastronomer, Scott in NC, iceblaze
