Space99
Reged: 08/14/08
CGEM-DX fried??? Help please
      #5634361 - 01/21/13 05:21 AM
Hi guys.....
new to go-to mounts.... the cgemdx is my first.
After the first couple of weeks of trouble free operation (apart that I can't switch on the GPS)
today I got a :
BOOT LOADER
Invalid Pkg: 0008
Now what? Is the mount fried? Was OK yesterday....
Help please
Mick
Space99
Reged: 08/14/08
Re: CGEM-DX fried??? Help please new [Re: Space99]
      #5634373 - 01/21/13 06:10 AM
I think I find it.... have to re-program the HC
Is this normal that a new mount lock-up like that?
Mick
RTLR 12
Reged: 12/04/08
      #5634419 - 01/21/13 07:06 AM
There was a problem with some of the NexStar+ hand controllers. This is a known glitch and Celestron has a fix for it in the newer firmware versions. You need to reflash or update the hand controller using the Celestron program called CFM or Celestron Firmware Manager. Just download the program to your computer and the open it up. In the upper LH corner choose the drop down list "Hand Controller" and then choose "Mount Types". Click on "Equitorial (GEM)". The program should then automatically upgrade the firmware. If you don't already have one, you will need a USB to Serial RS232 adapter cable with a driver install CD.
Here is the CFM download;
http://www.celestron.com/c3/support3/index.php?_m=downloads&_a=viewdownlo...,7
Stan
Space99
Reged: 08/14/08
Re: CGEM-DX fried??? Help please new [Re: RTLR 12]
      #5643862 - 01/26/13 06:51 AM
OK... the CFM did worked Thanks Stan
but the GPS still not recognized... I have a SKYSYNC GPS and when I set the Utility-GPS ON/OFF menu to switch it ON, the message is "NO GPS FOUND" ... The LED on the GPS module is on (working).
Any suggestion? May be a faulty GPS unit?
Mick
RTLR 12
Reged: 12/04/08
      #5644001 - 01/26/13 09:11 AM
How do you have the SkySync plugged in? The SkySync plugs into the "Hand Controller" port on the mount and then the hand controller plugs into the SkySync. If it doesn't work that way, try plugging the SkySync into the "AUX" port and see if it works that way. If not, then you may have a defective unit.
Stan
Space99
Reged: 08/14/08
      #5645392 - 01/27/13 02:31 AM
well.... I tried every option ... to the AUX port... to the HC port... no gps is the msg after I tried to sw it on.
In desperation I pulled the unit apart... the small PCB has the socket a eprom(?)and a 5V reg... 5V OK the regulator moderately hot... a small SMD LED on the actual GPS pcb is constantly blinking - is this an indication that the unit is trying to lock on? Anyone with experience of fixing GPS module? I have excess to scope smd components etc.
Mick
23 registered and 38 anonymous users are browsing this forum.
