Tim J K
Reged: 05/19/09
Loc: Iowa
Re: CPC tripod for 8se new [Re: Tim J K]
      #5634672 - 01/21/13 10:35 AM
Thanks for all of the help everyone. The CN thread covering this is at:
http://www.cloudynights.com/ubbthreads/showflat.php?Cat=&Board=nexstar&am...
I checked the azimuth drive sprocket, both little hex screws were tight. I then tightened the azimuth nut a little tighter than it was. There is still just a little play, but not quite as much. Hoping for a clear and not so windy night to try it out soon.
Tim
bcuddihee
Reged: 11/04/06
Loc: Cincinnati Ohio
      #5634748 - 01/21/13 11:20 AM Attachment (9 downloads)
In my case the play in the system was coming from the three black Phillips head screws holding the large gear ring in place. Hope this helps.
Tim J K
Reged: 05/19/09
Loc: Iowa
Re: CPC tripod for 8se new [Re: bcuddihee]
      #5634765 - 01/21/13 11:37 AM
Thanks again for the info BC. I didn't check the 3 philips screws. I'll have to check those. Is there any play at all in the azimuth on your SE mount now? I've still got a very small amount, less than 1 mm. Just wondering what is a normal amount if any.
Tim
bcuddihee
Reged: 11/04/06
Re: CPC tripod for 8se [Re: Tim J K]
      #5634784 - 01/21/13 11:51 AM
None now but 1mm is just fine.
Glad you were able to fix the issue.
bc
1 registered and 11 anonymous users are browsing this forum.
Moderator:  KWB, WaterMaster
