Charlie HeinAdministrator
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Jan13 Beginning DSO Challenge new
      #5627458 - 01/17/13 05:37 AM
This month's subject: Messier 35
Post your entries here.
The rules:
1. All entries must be captured within the same season as the contest. For example, if the subject was Orion Nebula, than any photo captured during this particular winter (or period that it was visible) would qualify for the contest. Entries must be made prior midnight of the last day of the month.
2. Images to be considered for entry to the challenge must be posted to and visible in the challenge submissions thread. A link to an off-site image without a version that is actually displayed in the challenge submissions thread will not suffice and is subject to disqualification.
3. Images to be considered for entry to the challenge must conform in all respects with the site wide image posting requirements. Entrants may elect to set this "entry image" up as a "clickable link" to a higher resolution image if they so desire, and entrants may also elect to instead provide a separate link to such an image if they so choose. If the entrant provides a legally sized and working "clickable link" as their "entry image", that "clickable link" will be included in the polling thread so that voters can examine the high resolution image before voting. However, any "entry images" displayed on the CN site that do not meet the file size and pixel dimension requirements will subject the entry to disqualification. Any questions on this rule? Just ask.
4. Please include the equipment used to take the image. Scope/Mount/Camera/Focal reducers/Barlows...whatever. Also include your location.
5. Please do not post comments in the entries thread. It is just for these wonderful images you all will be submitting.
6. The equipment must be yours. Doesn't matter what it is. 20" RC, ETX70, 2" Tasco or an 8" TMB.
7. No collaborations. You must be the operator. You must setup, align, take the exposures and process them yourself. You can have help mounting that 26" RC if need be. No remote scope images. Unless you own that remote scope and have set it up aligned it and hooked your camera up. Then you can use it. No pay by the hour renta-scope images will be allowed.
*If you have a physical disability which prevents you from being able to set up your equipment, you may still post images in the contests. However, you must own the equipment.
8. Most importantly! Have fun. Support one another's efforts. As we all can learn from this and enjoy each others accomplishments.
Magellan
Reged: 01/26/06
Loc: Enfield, NS Canada
Re: Jan13 Beginning DSO Challenge new [Re: Charlie Hein]
      #5627611 - 01/17/13 08:39 AM
Here is my M35 submission. Enjoy everyone
Lightbox Mode, larger image
Object: M35
Date: January 15th, 2013
Camera: Full Spectrum Honis Modified Canon XSi / 450D with MPCC
Filter: Astronomik CLS
Scope: Orion 8" F4 Astrograph
Mount: Celestron CGEM
Guiding: No
Guidescope: Celestron 80mm Guidescope
Guider: None Used
Subs: 40x120s 1hr20m Integration)
Darks: 12
Bias: 25
Flats: 25
Dark Flats: 25
Captured with: BackyardEOS
Stacked with: DSS
Processed in Pixinsight
M35_ISO1600_40x120s_1hr20m by AstroJeff, on Flickr
willem123
Reged: 08/09/11
Loc: South-Africa
Re: Jan13 Beginning DSO Challenge [Re: Charlie Hein]
      #5635238 - 01/21/13 03:43 PM Attachment (23 downloads)
Hi Guys,
M35
10 x 60sec. subs + darks, Canon 1100D(T3)Modded
SW 120ED Refractor
EQ6 Mount
SMigol
Reged: 07/30/10
Re: Jan13 Beginning DSO Challenge new [Re: willem123]
      #5638212 - 01/23/13 03:21 AM
M35 as seen from my Menlo Park, CA, USA backyard on January 18, 2013. It was slightly hazy then clear - and quite cold for this area with temperatures dropping to freezing.
This is from a stack of 14 frames each 600 seconds at 400 ISO, giving a total integration of 2 hours and 20 minutes.
Scope: Stellarvue SV4 with SSF6 flattener and IDAS LPR V2 filter.
Camera: full spectrum modified Pentax K10D with cooler.
Guide: Orion SSAG on Stellarvue SV70ED
Mount: Losmandy G11 G2
Guided and Calibrated using Maxim using 21 darks, 64 flats, 256 bias.
Stacked and debayered with DSS
Processed with Pix Insight
Large on Flickr
On Astrobin
Derryk
Reged: 07/05/12
Loc: California, US
      #5646380 - 01/27/13 04:30 PM Attachment (15 downloads)
Hello all,
Taken December 13-14, 2012 from Lake San Antonio, CA, USA.
Details, Equipment, & Software:
Telescope: Astro-Tech AT6RC w/ AT2FF (FL1370mm f/9)
Camera: Canon T2i (stock)
Mount: Orion Atlas EQ-G
Guide: Orion ST80 w/ SSAG
Capture: Backyard EOS (7x300s lights / 20x darks / 25x flats / 50x bias)
Stacking: Nebulosity 3
Final Processing: StarTools/Photoshop CS5
M35 - Gemini Open Cluster on Flickr
jdiwnab
Reged: 11/21/11
Re: Jan13 Beginning DSO Challenge new [Re: Derryk]
      #5647618 - 01/28/13 09:05 AM Attachment (13 downloads)
Here's my submission for M35, although there are much better ones already up here.
M35 from 1/21/2013
97x30s ISO1600 Sony NEX-5, 25 darks
Celestron Nexstar 80mm f/11 (900mm fl)
Celestron CG-5 mount, unguided
Stacked and processed in PixInsight
Astrobin link
StoneasRock
Reged: 01/31/11
Loc: Toronto, Canada
      #5653366 - 01/30/13 10:41 PM Attachment (10 downloads)
Scope: SkyWatcher 5" reflector
Camera: stock Canon XSI
Mount: LXD 75
Guide : SSAG
Process : DSS + PS4
Integration : 35X2minutes
LP: Red Zone
Edited by StoneasRock (01/30/13 10:43 PM)
BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
      #5653400 - 01/30/13 11:05 PM Attachment (11 downloads)
Here is my entry:
Object: M35
Date: 3 January, 2013
Camera: Hutech Modified Canon T1i / 500DH
Scope: AT65EDQ astrograph
Mount: Orion Atlas
Guiding: No
Guidescope: N/A
Guider: None Used
Subs: 28x120s (56 total minutes)
Darks: 6
Captured with: APT v2.01
Stacked with: DSS
Processed in PS CS 4 w/ Carboni tools
Reged: 11/02/03
Re: Jan13 Beginning DSO Challenge new [Re: BKBrown]
      #5655881 - 02/01/13 09:20 AM
Submissions are now closed. Best of luck in the contest!
Charlie
14 registered and 10 anonymous users are browsing this forum.
