helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
Star Seek wifi from Orion
#5634122 - 01/20/13 11:09 PM
I could connect between my iPad and Intelliscope with wires, with no problems, but I just tried for the first time with the Orion StarSeek wifi... I get a message that says while the app can connect with the wifi, the telescope is not responding. Anyone else see this? I have tried everything mentioned under the support page on SkySafari.
Btw, yes the SS works with the Orion hardware, but to be sure, I also tried this with the Orion StarSeek app, same problem.
Thank , David
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Star Seek wifi from Orion
[Re: helpwanted]
#5635339 - 01/21/13 04:54 PM
I got that message when I plugged my Sky Commander into the Star Seek unit and tried to connect with the iPad. The problem in my case was that the wire was not correct, I had to make one with the right pin positions. So are you sure you are using the right wire? Even when I made the correct wire, both ends are the same size plug, but each end is specific for each device so I had mark the ends to remember which on goes to the Sky Commander and which end goes to the Star Seek. Perhaps you have the same situation?
CJK
Reged: 12/05/12
Loc: Scenic SE TN
[Re: Lane]
#5635582 - 01/21/13 07:26 PM
One of the RJ-12 connectors on my StarSeek wasn't attached properly. I had to crimp it onto the cable with a telecom crimping tool.
Looks like their cable quality control needs a little help.
The unit itself works great.
-- Chris
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
[Re: CJK]
#5635587 - 01/21/13 07:28 PM
But I used the same cable to connect directly to the iPad?
Lane
Reged: 11/19/07
Loc: Frisco, Texas
[Re: helpwanted]
#5635791 - 01/21/13 09:52 PM
Do you mean the SkyWire? That cannot be connected to the Star Seek device as far as I know.
Maybe some pictures would help. I am totally confused here.
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
[Re: Lane]
#5636382 - 01/22/13 08:25 AM
I had the wire from Orion, and was forced to use only the Orion app, StarSeek, because of the Apple restrictions. I then bought the Orion Wifi, which CAN be used with the Southern Stars app... Although I have tried both apps to be sure. I meant to take a look at these cables again last night, but lost track of time, I will work on this tonight.
David
rboe
Reged: 03/16/02
Loc: Phx, AZ
[Re: helpwanted]
#5637110 - 01/22/13 03:04 PM
I've used Sky Safari in the laptop and the iPad to connect to my Star Seek; works like a champ. Killer app and interface. Bluetooth was supposed to be the bomb but never had luck with it. Wi-Fi worked.
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
[Re: rboe]
#5637995 - 01/22/13 11:21 PM
it was the wire! i still had the 6' long cable from when i connected via wire, and it works perfectly now!!
thanks for everyone's help! David
GaryJCarter
Reged: 06/06/09
Loc: Fairview, Texas
[Re: Lane]
#5645822 - 01/27/13 11:01 AM
Lane,
I have heard conflicting accounts about the requirements to make a StarSeek / SkyCommander cable. Do you have a schematic you could share?
TIA
Edited by GaryJCarter (01/27/13 11:03 AM)
Lane
Reged: 11/19/07
Loc: Frisco, Texas
[Re: GaryJCarter]
#5646884 - 01/27/13 08:34 PM Attachment (10 downloads)
Do you have a phone plug crimping device for a 6P connector? If so, here is a diagram I made that shows the wire connections, you are looking directly at the ends of the wires in this diagram. These are the actual colors of my wires but obviously the colors do not matter, you need to make the connections shown.
2 registered and 11 anonymous users are browsing this forum.
Moderator: Bowmoreman, richard7
