Pages: << 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 | 42 | 43 | 44 | 45 | 46 | 47 | 48 | 49 | 50 | (show all)
Agatheron
Reged: 11/03/10
Loc: Calgary, Alberta, Canada
Re: Celestron StarSense new [Re: RobertH]
      #6186355 - 11/10/13 11:14 AM
@neilson: Thanks for this. I have the software downloaded to my laptop. I just now need to fish around for the right cables. I know I have the Celestron programming cable, I'm just not entirely sure where the USB to serial adapter is. Hopefully I can find it, or go out and get one quickly at a local computer supply store...
aberrs
Reged: 08/23/11
Re: Celestron StarSense new [Re: Agatheron]
      #6187641 - 11/10/13 09:59 PM
I think the hand control updater just bricked my camera; it no longer gets detected.... I too will have to call the factory. Let's see what they say. It was good while it lasted....
Agatheron
Reged: 11/03/10
Re: Celestron StarSense new [Re: aberrs]
      #6189837 - 11/12/13 12:51 AM
I tried mine out tonight. Excellent on the first try. I set it up for increased accuracy as well. I did this under streetlights, and each time it put the intended target right in the center of the eyepiece. Excellent.
The hitch is, I've been having some issues with my AZ motor/gears/bearings. Tonight, when it was tranversing to see M81, I had some gear slipping/power flicker issues (I was running off of house power). I don't know exactly what it was, but when I went to look in the eyepiece, I could smell the acrid odour of unhappy electronics. The computer electronics seemed to be working just fine, but I think I may have some issues with my AZ motor and/or gears. Sigh.
It was a great first shot though, now if I can get the gears to work properly we'll be in great shape!!
gaz-in
Reged: 12/17/07
      #6190685 - 11/12/13 01:16 PM
the latest worked great on my NSGPS8....update went smoothly...previous version would not recognize the camera...
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Celestron StarSense new [Re: gaz-in]
      #6190735 - 11/12/13 01:48 PM
But do you have ASAP? If not how are you polar aligning now? Kasey
Reged: 07/06/07
Re: Celestron StarSense new [Re: dragonslayer1]
      #6191052 - 11/12/13 04:18 PM
Do you mean ASPA? With a GPS scope I suspect he is alt-az...
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Celestron StarSense new [Re: rmollise]
      #6191079 - 11/12/13 04:27 PM
Yes is what I meant, TYPO, sorry.. Am wondering without ASPA, or if its not fixed yet if its worthwhile, thats a major selling point with Celestron mounts I think? The only way to do ASPA is after alignment with SS, power down, plug in old handset and realign, then do ASPA, then powerdown again and redo with SS?? Kasey
Kasey
Charlie B
Reged: 03/22/08
Loc: Sterling, Virginia
      #6191192 - 11/12/13 05:23 PM
Why start with SS? Just do the alignment with the old handset and then power down change to SS. However, SS did work for me on my CGEM, so ASPA is not broke for all.
Charlie B
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Celestron StarSense new [Re: Charlie B]
      #6191534 - 11/12/13 08:26 PM
Charlie,
So your ASPA did work on your CGEM? My understanding is that it was still not functioning. You were able to align and ASPA with your SS? Thank you, Kasey
neilson
Reged: 08/22/10
      #6191800 - 11/12/13 10:44 PM
I Polar aligned my CGE mount very close but not exact. Then I tried the ASPA with my SS. It had me adjust the mount way out of Polar alignment. I left it like that. Then I completely started over and tried the ASPA again. This time it got it dead on. On my mount I would say it works sometimes. But more testing is needed to give an accurate opinion.
Neilson
Charlie B
Reged: 03/22/08
      #6193368 - 11/13/13 07:35 PM
Yes and it did very well. I was at a star party and used the polar scope quickly (too quickly) and had star streaks after 20 seconds. The ASPA with SS gave me round stars after 1 minute.
Most of the times the SS seems to go off track is my fault. I have a hard time adjusting to the multi-line display and keep forgetting that it scrolls, but I'm learning.
Charlie B
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #6193589 - 11/13/13 09:55 PM
Wow thats great Charlie,
I don't know if you are signed up for Team Celestron but I am thinking they would really like to hear from you... I was under the impression ASPA didn't work (or worked rarely) from trying to follow this SS work thru thread in here and in Team Celestron.. Thank you for the reply, Kasey
Charlie B
Reged: 03/22/08
      #6195134 - 11/14/13 06:11 PM
People with complaints are more vocal. I am a member, but I've had no complaints except the camera update was not working. However, the latest release fixed that.
Charlie B
brokenwave
Reged: 05/10/11
Loc: Scottsdale, AZ
      #6195568 - 11/14/13 09:44 PM
Pretty typical, 70% of the negitive posts are usually just noise, but there is some good info in there though, just have to wade through it.
neilson
Reged: 08/22/10
      #6195606 - 11/14/13 10:06 PM
From what I read the problems with the ASPA is that it's not as accurate as it use to be from what I understood. I can understand it being good enough if your using a focal length like 1000mm but at 2350mm it needs to be pretty close.
I tested my CGE again tonight. I did the ASPA and after doing both steps, the E/W and N/S adjustments, I got it polar aligned. I checked it and it was good. I cycled the power, did a regular alignment then did the ASPA again. Both the E/W and N/S steps of the ASPA showed my mount was still Polar aligned correctly from the first time.
By the way, I'm imaging at 2350mm f/10 and when I do my drift alignment after the ASPA I only need to make very minor adjustments. I recommend that anyone needing a Polar alignment to go ahead and at least try your ASPA.
Neilson
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
Re: Celestron StarSense new [Re: neilson]
      #6195621 - 11/14/13 10:14 PM
Be patient grasshopper
latest from Celestron;
Problem: All Star Polar alignment (ASPA) doesn't work. Solution: This feature doesn't work reliably on all mounts. We have no solution or work around at this time. But we are working on it
After most recent beta update;
Is ASPA also working now? No. there will definitely be sparklers and candy when we get that going
neilson
Reged: 08/22/10
Re: Celestron StarSense new [Re: Stew57]
      #6195742 - 11/14/13 11:42 PM
Master!
Who's in a rush.
I'm not concerned about when they're going to fix it. mine works fine. Even if it didn't I would just drift align, because I know they will fix it before long.
neilson
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
      #6196071 - 11/15/13 08:23 AM
Public release of update?
Searching for MCUpdate on;
http://www.celestron.com/c3/support3/index.php
Didn't think it was released yet but had this pop up.
Celestron Firmware Manager (CFM) v.1.7.3310
Direct link;
http://www.celestron.com/c3/support3/index.php?_m=downloads&_a=viewdownlo...
Be sure and take note of known bugs and issues still remaining. YMMV
Edited by Stew57 (11/15/13 05:22 PM)
neilson
Reged: 08/22/10
      #6196346 - 11/15/13 11:09 AM
Mark
Mark, could you look on Team Celestron > public beta testing > StarSense Accessary under "Starsense w/CGE Classic major Buggy" on the last post of page 5 written by me. Having to do with goto accuracy in the southern half of the sky, and the effectiveness of adding additional cal. points after the first one. Do you happen to know if their working on anything in general that might help fix that problem. Not necessarily specific to CGE mounts but maybe to GEM mounts in general.
Neilson
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
      #6197460 - 11/15/13 11:41 PM
I did a little test for you. I had to manual align as the SSA hung up every time on auto align. After 4 alignment areas were chosen and the alignment successful was given, I slewed to a variety of stars. No calibration points were added. I measured the pointing accuracy to the center of the FOV and to the first star. They all landed a little east of center. Here is the results. Distances are arcminutes
Star Distance from center Distance from Scheat
Scheat---------2.25----------------------0
Deneb----------2.25----------------------.75
Alpheratz------5.25---------------------3.0
Altair-----------4.5--------------------2.25
Mirfak----------4.5---------------------2.25
Aldebaran------3.75---------------------2.25
Menkar---------3.0----------------------1.5
Capella---------2.25--------------------1.5
Enif-------------3.0---------------------.75
FomalHaut------4.5----------------------2.25
As you can see if I could offset my center calibration I would be getting 3 arcminutes or better pointing accuracy (Just a little better than I was getting with a very careful 2+4). There is some talk of improving the pointing further but ASPA is first inline. I am kinda hoping they fix the auto align freeze ups first.
12 registered and 23 anonymous users are browsing this forum.
