Telescope Specific Forums >> NexStar GPS / CPC Telescopes
akulapanam
Reged: 08/27/12
Azimuth clutch gets stuck new
      #5633252 - 01/20/13 01:38 PM
I was wondering if it was normal for the Azimuth clutch to get stuck in cold weather. I take the scope out with the clutch loose then tighten for the goto routine. However after about 4 or 5 hours after I turn my scope off I find that I can no longer release the clutch by hand. Usually by the next day I can release it again. I would obviously like to avoid moving it with the clutch stuck like this and I was wondering if this was normal or if there was some key to getting it loose.
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
Re: Azimuth clutch gets stuck new [Re: akulapanam]
      #5633445 - 01/20/13 03:43 PM
I have had that happen a few times. I just GENTLY tap one of the clutch gripper ridges with a small hammer and it pops loose easily.
Doc Bob
Reged: 02/27/09
Loc: Maryland, USA
Re: Azimuth clutch gets stuck new [Re: MikeBOKC]
      #5634127 - 01/20/13 11:15 PM
I've also experienced this problem . . . did the same thing Mike suggested, and it worked. I have found that the clutch doesn't have to be ratcheted tight to work - actually on my scope I just lightly tighten the clutch; tracking is fine and it has not been stuck in 2 winters.
Bob
Koen Dierckens
Reged: 11/04/09
Loc: Antwerp, Belgium
Re: Azimuth clutch gets stuck new [Re: Doc Bob]
      #5640755 - 01/24/13 01:56 PM
Happens to me too, but then the opposite way: if I tighten it when it is cold, I am unable to unlock it when it has warmed up. I guess it has something to do with thermal effects on the different components of the clutch. I always make sure the clutch is loosened when not in use. Best practice anyways.
Doc Bob
Reged: 02/27/09
Loc: Maryland, USA
Re: Azimuth clutch gets stuck [Re: Koen Dierckens]
      #5641232 - 01/24/13 06:42 PM
+1 Koen !
1 registered and 10 anonymous users are browsing this forum.
Moderator:  BRisley
