lamplight
Reged: 09/18/12
Loc: west central MA, U.S.
Hypothetical 4" budget APO choices.. WWJD?
#5641698 - 01/24/13 10:59 PM
Vixen ED 100mm sf w portamount $1000 Meade 102mm ED APO $1000 used Skywatcher pro SW ed 100mm about $750ish new
I like the 4" range for size and visual use, don't want to go bigger.. But I don't also want to go smaller... Might do a 90mm if there's some good value in a certain scope..
Pros and cons? Why are the skywatchers SO much cheaper than other APOs? (Other than looks ) Do they suck horribly? Are others in this price range less than great as well? I'm leaning towards the vixen, decent reviews, brand resell value.. I guess Meade would have that too. although I don't need the portamount it mount it might prove useful.
Find myself browsing refractors and while im happy with the xlt I would like an apo at some point so just .. You know.. Kicking the tires. Thanks!
Reged: 06/16/04
Re: Hypothetical 4" budget APO choices.. WWJD?
[Re: lamplight]
#5641986 - 01/25/13 06:35 AM
Skywatchers are good, bascially the same scope as the Orion ED-100, sometimes one sees these on astromart for $400. It's your standard Synta FPL-53 F/9 Doublet.
Both the Meade and the ED-100 look over priced to me.
lamplight
Reged: 09/18/12
[Re: Jon Isaacs]
#5642018 - 01/25/13 07:13 AM
Thanks Jon just looking but noted. Will keep eyes peeled and keep reading
Reged: 06/16/04
[Re: lamplight]
#5642069 - 01/25/13 08:10 AM
There is a lot to know about refractors and apo's in particular. In my mind, the Synta 100EDs such as the Skywatcher represent an incredible value. Good optics, good color correction, reasonable mechanical components, nice scopes. At F/9 these scopes are 36 inches long, they are not so handy, definitely not a bird watching scope.
So then the search begins... maybe the ultimate in quality is the search. But often it's a shorter focal length, a sliding dewshield, these start bringing the 4 inch apo closer to being an overgrown 80mm... F/7 is pretty nice. The scopes are there, the 102EDs... like the Lunt and the StellarVue.
But the color correction suffers... so that means a triplet, eventually an FPL-53 triplet... So now were are at about $2000 and rising. Nice scopes, reasonably compact, excellent color correction, good quality mechanicals, a nice wide field of view, 3.5 degrees maybe.
A final step is dealing with the field curvature. Refractors have a curved field of view. The lowest magnifications, widest fields of view, the stars at the edge of the field are slightly out of focus when the stars in the center of the field are in focus. Photographically this is a problem, refractors require the use of a field flattener for this reason.
Visually, it's not a big problem but if one wants to spend even more money... There's the TeleVue NP-101 and Takahashi 106 FSQ. These are both 4 element apo-refractors with a two element rear section that acts as both a focal reducer, field flattener. The Takahashi is designed with astrophotography in mind and is capable of imaging a 10 degree field of view. The TeleVue is more aimed at the visual market place and with a 31mm Nagler provides an essentially perfect 4.5 degree field of view.
For most objects, the difference in the view between a TeleVue NP-101 and a SkyWatcher ED-100 is small. In some ways you don't get a lot for your extra $3000.
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
[Re: Jon Isaacs]
#5642111 - 01/25/13 08:45 AM
Might also look at the TMB 92 series . . . very nice optics and solid build.
howard929
Member
Reged: 01/02/11
Loc: Low End of High Ground
[Re: Jon Isaacs]
#5642116 - 01/25/13 08:47 AM
Tsk. Tsk. True planetary observations are better left to those who are talented enough to buy the VERY best equipment. Any, even a slight deviation from the true path of excellence is left to those poor unwitting souls who are satisfied to (nose very high in the air here) settle for anything less.
I'm joking of course but I have read threads like that here on the forum. Crying out loud, they make it seem like Mount Rushmore would crumble into dust if they deviation from that path. And the dog would just explode.
Jon, good stuff there (as always). Really. Write a book.
Fogboundturtle
Reged: 05/20/09
Loc: Burnaby, BC
[Re: howard929]
#5642377 - 01/25/13 11:26 AM
the Skywatcher is the best bang for the buck. I have the 80mm version and it been working great for me as visual and guiding scope.
Paco_Grande
Reged: 07/14/12
Loc: Napa Whine Country
[Re: lamplight]
#5642496 - 01/25/13 12:34 PM
The question about the Sky-Watcher might be, why are the others so expensive? Indeed, why? I've seen numerous posts here on CN, guys who've sold their TV 102s (or at least have both) and kept the Sky-Watcher ED100 because it's simply that good for the money! I'm impressed. Sky-Watcher would be my choice for sure for an ED of that f ratio.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
[Re: Paco_Grande]
#5642511 - 01/25/13 12:43 PM
lol Matt you gonna buy another scope..lol
Fogboundturtle
Reged: 05/20/09
Loc: Burnaby, BC
[Re: Paco_Grande]
#5642528 - 01/25/13 12:54 PM
my only pet peeve and its really a minor thing, I found the 2 speed focuser to be not to my standard. That's because I have an very good focuser on my Meade Triplet. That's my only minor complaint about the Sky-Watcher. Its an easy fix too.
JoLo
Reged: 02/09/10
Loc: Highland, IL
[Re: Fogboundturtle]
#5642595 - 01/25/13 01:28 PM
I luv my AT106 triplet but have a gripe similar to Mr. Turtle's above....the two speed focuser is good, but not great. When using barlows and an extension with my Imaging Source camera, I run into some slippage...with just my DSLR, no problems. I am going to replace the focuser and be a happy boy.
For less than 2K, I got the 106, the ATQ65, and a flattener for the 106. Both are excellent scopes, the 65 does triple duty as a guide scope, my primary birding scope, and a mighty fine wide field imager in its own right.
Joe
csrlice12
Reged: 05/22/12
Loc: Denver, CO
[Re: JoLo]
#5642611 - 01/25/13 01:35 PM
J would take that 4" and reshape it into a large mirror............
Reged: 06/16/04
[Re: Paco_Grande]
#5642646 - 01/25/13 01:54 PM
If "that good for the money" is the deciding factor, then a good quality, less pricy scope will nearly always win. One can make the same argument for the 102mm F/10 achromat versus the Synta ED-100's. As one moves up the ladder the differences are smaller and smaller.
No doubt about it, the Synta ED-100s are an amazing value. When they hit the market 7 or 8 years ago, they were about $1000 and that was a bargain. Now, they have come down in price, it's a lot of scope for the money. Mechanically, they are sufficient, very similar to the Synta Achromts, nothing fancy. If a three foot long, 100mm F/9 refractor will serve you needs, then it's certainly a good place to start.
Myself, I am generally on the budget side of things not in this case. I worked my way up to a 4 inch as a step up from an 80mm. Short focal length, short scope, well suited for an alt-az mount... an 100mm apo with body of an ED-80.
The classic is the Astro-Physics Traveler. These are the original 4 inch F/6 triplet... They haven't been made for about 10 years, used ones go for around $5000. Sue French uses an Traveler for her column.
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
[Re: Jon Isaacs]
#5642659 - 01/25/13 02:02 PM
There's something to be said for that. One might argue that if you want a budget-priced refractor, why not buy a reflector? A 150-mm f/6 reflector would be roughly the same size and weight as a 100-mm f/9 refractor, considerably easier to mount, even more free from false color, and have much greater resolution and light-gathering.
At some level, perfection is the whole draw of refractors -- at least in the larger sizes.
Paco_Grande
Reged: 07/14/12
#5642702 - 01/25/13 02:25 PM
I was going to mention that, but who knows? Each of us makes various trade-offs with our toys. I mean, the scope costs $750 and a Feathertouch costs half of that. But for a couple hundred a nice GSO might make sense.
Paco_Grande
Reged: 07/14/12
[Re: Paco_Grande]
#5642710 - 01/25/13 02:29 PM
BTW, I understand it's just not really fair to compare the SW and the TV, it's like comparing a Mini Cooper to a Porsche. It's simply the value quotient, and that usually changes for each of us over time. What was important becomes less important, or vice versa, etc..
bierbelly
Reged: 01/23/04
Loc: Sterling, VA
[Re: lamplight]
#5642801 - 01/25/13 03:27 PM
I wasn't aware that Jerry was interested in astronomy.
Edited by panhard (01/26/13 09:02 PM)
lamplight
Reged: 09/18/12
[Re: bierbelly]
#5642834 - 01/25/13 03:41 PM
I ask him all the deep questions (I am a fan)
Reged: 06/16/04
[Re: Paco_Grande]
#5642839 - 01/25/13 03:43 PM
I think it is fair to compare a TeleVue 102 to the Skywatcher ED-100 They are both very similar scopes, the Televue has a focal length of 880mm, the Skywatcher 900mm. It is even fair to compare the Skywatcher ED-100 to the TeleVue NP-101 even though the NP-101 has a 540mm focal length with it's legendary flat field and total lack of chromatic aberration. I have made that comparison myself.
Comparisons are valuable because they provide information and understanding, awareness. There is a choice to made between a Skywatcher 100 and a TV NP 101... However, comparisons should be made without expectations...
Tony's point is an important one. Apo refractors are a pursuit of perfection. Without looking through a variety of scopes, looking at a variety of scopes, it's hard to understand what the differences are, what is the difference at the eyepiece between a $750 Skywatcher and a $4000 TeleVue?
The Skywatcher ED-100 is quite perfect. The TeleVue NP-101 is just about as perfect as we mortals will ever experience.
Edited by Jon Isaacs (01/25/13 03:58 PM)
bierbelly
Reged: 01/23/04
Loc: Sterling, VA
[Re: lamplight]
#5642897 - 01/25/13 04:11 PM
So do/am I...and I'm pretty sure I know what his answer would be...
