Privacy Policy |
Please read our Terms
of Service | Signup and
Jarrod
Reged: 01/20/13
Loc: SE USA
Re: Nitrogen filled verses non-nitrogen binos
[Re: KennyJ]
#5654767 - 01/31/13 05:46 PM
Big respect for that, Kenny. I have a good fraction of my savings invested in North American NG pipes. It's a great industry. I used to have BP as well, before the accident....
Very interesting to read your comments on purging pipe. I imagine those considerations are big-time important before you contemplate putting an acetylene torch to a pipe that had pressurized, flammable substances flowing through it!
Edited by Jarrod (01/31/13 05:50 PM)
KennyJ
The British Flash
Reged: 04/27/03
Loc: Lancashire UK
[Re: Jarrod]
#5654896 - 01/31/13 07:01 PM
Thank you,Jarrod.
As you implied,it's ONE thing sitting around well crafted tables in plush surroundings,wearing expensive suits,drinking fine coffee from the best china cups,TALKING about a potential problem,but it can be somewhat different out on the front line,freezing private parts off or sweating like a pig,heart beating like a drum,whilst actually putting the theories into practice,knowing that any mistake can literally spell the end of existence for more than just yourself.
Of course,repairing binoculars is not quite such a potential "life and death" profession,but again,there are far fewer people who actually carry out the work professionally than there are who seem to enjoy speculating about it!
Kenny
BillC
on a new path
Reged: 06/04/04
Loc: Lake Stevens, WA, USA
[Re: KennyJ]
#5654916 - 01/31/13 07:13 PM
Everybody put your hands on the computer screen and say Amen!
BillC
RichD
Reged: 11/08/07
Loc: Derbyshire, UK
[Re: BillC]
#5655620 - 02/01/13 06:11 AM
very interesting Kenny
Reged: 06/16/04
[Re: Jarrod]
#5655894 - 02/01/13 09:25 AM
A few thoughts:
- Bicycle inner tubes are an example of the diffusion of air through butyl rubber. A standard 700C-23 tire pumped to 120psi will lose enough pressure that it will need to be pumped up within a week or so. Bicycle tires are operating at high pressures, with large surface areas, are quite thin and the enclosed volume is relatively small.
- Binoculars are quite a different situation. There is very little pressure differential driving the diffusion, there may be none. I suspect Jarrod is correct, the reason for the purging is to dry the internals of the binoculars, the purpose of the O-Rings is the prevent moisture from entering the binoculars.
In my line of work, when I want something to be really dry, I hook it up to a vacuum pump and pull it down to micron levels...
Binojunky
Reged: 12/25/10
[Re: Jon Isaacs]
#5656378 - 02/01/13 01:33 PM
Talking about sealing stuff, a few years back I pulled apart a VW air cooled motor and the cylinder head mated to the cylinder barrels with no gasket of any sort, not sure of the PSI when the piston was a TDC but it worked.DA.
9 registered and 37 anonymous users are browsing this forum.
Moderator: knuklhdastnmr, panhard
