BRisley
Reged: 09/04/06
Loc: SW Florida
Questions about a Vixen DMD-1 Controller
      #5641822 - 01/25/13 12:59 AM
I am trying to understand something about the DMD-1 (not the DD-1!) controller. I have an MD-6 controller, and it basically only has a 16x slew in the ra movement direction and a stop button in the reverse direction. Now with this DMD-1, I have full speeds working in the RA directions, but when I push the reverse, it just stops. Is this the correct operation for this controller, or should it properly reverse the motor? I have read on some earlier threads that it may not move in reverse. Just trying to understand it and would appreciate any feedback from someone who has a properly working DMD-1 controller or the manual explaining what it should do.
Brian
Reid W
Reged: 10/06/10
Loc: Shreveport, LA
Re: Questions about a Vixen DMD-1 Controller new [Re: BRisley]
      #5642673 - 01/25/13 02:10 PM
I have the DMD-2 which is the dual axis version.
Yes, the left button stops/pauses the RA drive. If you want to reverse direction temporarily, then change the direction switch, then slew with the right button.
Now, my DMD-2 operates very well with 9V power, by either using the 6 "C" battery pack, or a 9V DC adapter. The currently available 12V Vixen AC adapter caused my DMD-2 drive to not operate at all and my DD1 drive to stutter.
ccs_hello
Reged: 07/03/04
Re: Questions about a Vixen DMD-1 Controller new [Re: Reid W]
      #5643397 - 01/25/13 09:27 PM
... the left button stops/pauses the RA drive ...
In slowest setting, that is correct. The Earth's rotation does the "reverse" for you automagically . It's free and it's green!
Clear Skies!
ccs_hello
BRisley
Reged: 09/04/06
Loc: SW Florida
Re: Questions about a Vixen DMD-1 Controller new [Re: ccs_hello]
      #5646630 - 01/27/13 06:31 PM
Thanks Reid, that is what I do with the MD-6 as it has the separate 16x button for forward only.
With the DMD-1, you have speed control switch, the directions switch and the buttons, so this was confusing. They should have labeled it stop, not an arrow!
Brian
Reid W
Reged: 10/06/10
Loc: Shreveport, LA
      #5647039 - 01/27/13 10:03 PM
Glad it worked out. If you go to google images and search dmd-2, the third hit shows the left button labeled "stop". If only Harbor Freight Tools had a $2.00 labeler, I'd get one.
BRisley
Reged: 09/04/06
Loc: SW Florida
      #5647253 - 01/28/13 12:32 AM
DMD-1's had the arrow.
20 registered and 34 anonymous users are browsing this forum.
