wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
Anybody autoguide success with HEQ5 or Neq6 in FC? new
      #5641920 - 01/25/13 04:00 AM
I tried many times with my HEQ5 PRO.
I can click the arrow to move the image when connect.
but image failed to move when click auto guider. I could see the arrow flash.but mount doesn't move.
ZuoZhao
Reged: 10/16/12
Re: Anybody autoguide success with HEQ5 or Neq6 in FC? new [Re: wenjha]
      #5641946 - 01/25/13 05:01 AM
I try the DOB10 last night. Though the green arrows turn red again and again(it try take Jupiter back to center),but not any effect on telescope. That anybody use FC on AZ system?
TorstenEdelmann
Reged: 09/29/04
Loc: Landsberg, Germany
      #5642168 - 01/25/13 09:23 AM
Hi Sam,
You can send me the log.txt once more and if you find some time you can try out some code adjustments.
Let me know.
Torsten
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Re: Anybody autoguide success with HEQ5 or Neq6 in FC? [Re: TorstenEdelmann]
      #5642610 - 01/25/13 01:35 PM
I use Autoguide with great success on my EQ6, had to
play with setup and so on.
Here you have the FC-ini-file with the parameters for
Autoguiding that work for me!
useAutoguider=true
autoguiderInterface=EQMOD.Telescope
autoguiderRate=2
autoguiderDurationRA=200
autoguiderDurationDEC=200
autoguiderToleranceRA=10
autoguiderToleranceDEC=10
autoguiderBacklashRA=0
autoguiderBacklashDEC=0
autoguiderFlipRA=true
autoguiderFlipDec=true
autoguiderRateRA=0.002924651916666667
autoguiderRateDec=0.002924651916666667
autoguiderRAMinusFactor=1
autoguiderCOMPort=COM1
In EQMOD I have set the rates as follows:
AUTOGUIDER_DEC=x0.75
AUTOGUIDER_RA=x0.75
I hope that helps for you!
Let us know!
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
Re: Anybody autoguide success with HEQ5 or Neq6 in FC? new [Re: TorstenEdelmann]
      #5643304 - 01/25/13 08:29 PM
thanks Torsten
I will try again and send the log.txt
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
Re: Anybody autoguide success with HEQ5 or Neq6 in FC? new [Re: Mert]
      #5643305 - 01/25/13 08:30 PM
thanks Mert. I will check my fc.ini and try again
Mert
Reged: 08/31/05
      #5650303 - 01/29/13 01:17 PM
Any progess already Sam???
Have you been able to do some trials with different
settings??
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
      #5651045 - 01/29/13 07:54 PM
settings??
thanks Mert.Torsten solved the problem in his release #38.
I just tested last night. works great now
Mert
Reged: 08/31/05
      #5652489 - 01/30/13 02:46 PM
Good to hear Sam, are you using an AZ mount?
By the way I can't find build #38 yet on the usual
website.
Edit: Oops, sorry I just saw you are using HEQ5
and not an AZ mount.
Edited by Mert (01/30/13 02:50 PM)
16 registered and 16 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
