Telescope Specific Forums >> Meade Computerized Telescopes
wakk0
Reged: 01/08/13
Is this a good buy? new
      #5642324 - 01/25/13 10:47 AM
Hi guys,
Do you guys think this is a good buy? It is a Meade ETX125EC in brand new condition. Comes with Autostar 497 and tripod and whatever comes from the manufacturer. He wants $450 for it. What do you guys think?
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: Is this a good buy? new [Re: wakk0]
      #5642672 - 01/25/13 02:10 PM
Depends on the mount. On the original plastic mount, no. Suppose it's fair enough on the later aluminum alloy mount. The latter is sheathed in plastic, but if you spin off the Alt clutch and setting circle disc you can see if if there's alloy under the plastic.
wakk0
Reged: 01/08/13
Re: Is this a good buy? [Re: Geo.]
      #5642719 - 01/25/13 02:33 PM
Thanks Geo
Reged: 07/06/07
      #5644097 - 01/26/13 10:18 AM
I'd say 250 - 300 tops for a later model in excellent shape.
jgraham
Reged: 12/02/04
Loc: Miami Valley Astronomical Soci...
Re: Is this a good buy? new [Re: rmollise]
      #5646146 - 01/27/13 02:13 PM
Not bad for an ETX-125 in good condition with a #497 controller and a #884 field tripod. The true value is a personal choice; do you up end up with a scope that you like at a price that you can afford. If you do then the objective was met.
wakk0
Reged: 01/08/13
Re: Is this a good buy? new [Re: jgraham]
      #5646249 - 01/27/13 03:17 PM
I went to check it out..it's new but the EPs and view finder were dusty from the scope being out. It has autostar 497 that was never been taken out the box, hand controller, but the tripod is a #883. Optics looks good but I saw a small fingerprint smudge on it
JT5
Reged: 11/08/07
Loc: Ozarks of Missouri
      #5646313 - 01/27/13 04:03 PM
I would not consider buying a scope unless the owner is willing to set it up for you and do all of the calibrations and setups for auto align and tracking. Have the scope automatically find and track a know object for 5 minutes. How well does it remain centered?
John
Reged: 07/06/07
Re: Is this a good buy? new [Re: JT5]
      #5646498 - 01/27/13 05:30 PM
And keep in mind: Meade will not provide ANY support for the scope--zero, zip, zilch. For a couple of hundred or so, OK...for more, especially without confirming everything works under the stars? Hail no.
jgraham
Reged: 12/02/04
      #5646736 - 01/27/13 07:18 PM
Like most high tech gear, run it through its paces and make sure everything works. These things tend to die right away or they live forever. If the lack of tech support is a concern I'd seriously consider a Dob (economical and low tech). With an #883 tripod the value of this partucular offer goes from good to eh in my book, I'm not a huge fan of the #883.
wakk0
Reged: 01/08/13
      #5646763 - 01/27/13 07:29 PM
Thanks guys. Scope was already set up and left there thus dust building up on the EPs and viewfinder. I did slew it around but the autostar was in the box with plastic over it.
@jgraham: Yeh I've read that about the #883..very unstable for the 125s
jgraham
Reged: 12/02/04
      #5646852 - 01/27/13 08:13 PM
The #883 would probably be okay in altaz mode, it is just a bit light for my taste for a scope like the ETX-125. I would not even think about trying to use it with the ETX-125 in polar mode.
3 registered and 11 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
