Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | (show all)
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: jerryyyyy]
      #5473215 - 10/16/12 12:18 PM
Ok thank you
Chucke
Reged: 03/12/10
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: totolesbaloches]
      #5473573 - 10/16/12 04:45 PM
Laurent,
On your website it says Maxim DL 5.18 is required. Will MaxPilote work with 5.15?
Chuck
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: Chucke]
      #5473646 - 10/16/12 05:20 PM
Yes, they is no new fonction managable since
I change me web page, i put 5.XX
jerryyyyy
Reged: 10/06/11
Loc: Stanford, California
      #5483653 - 10/22/12 01:22 PM
I have been studying MaxPilote as I now have Maxim DL working well, but would like to capture a series of different objects over the night, which it appears I can do with MaxPilote.
However, I cannot see how one would automatically start guiding, even if a slew were corrected with PinPoint? Can this work automatically, say on a second target, assuming you had guiding set up correctly on the first target of the night?
Sorry, this is tedious, but have to proceed step-by-step.
A bientot.
totolesbaloches
Reged: 08/22/08
Loc: France
      #5483784 - 10/22/12 02:39 PM
you have give good "min ADU", and Maxpilote up the guide time to have this min adu with your new target
totolesbaloches
Reged: 08/22/08
Loc: France
      #5493229 - 10/28/12 03:18 PM
Version 2.01.24
download web page : http://www.felopaul.com/software.htm or "UPDATE"
i add :
- Added new USB sensor DewPoint available soon : http://www.usb-foc.us
- Temperature external
- Temperature probe placed on a remote mirror or otic
- Humidity
- Dew point (I'll quickly put piloting a VB script to start the resistance heating)
- The PDF manual is updated.
Chuck Faranda
Reged: 03/31/07
Loc: Florida
      #5531571 - 11/21/12 06:30 AM
Laurent,
Can MP be configured to access weather data from a Boltwood 2 compliant text file? Thanks!!
jerryyyyy
Reged: 10/06/11
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: Chuck Faranda]
      #5531960 - 11/21/12 10:56 AM
Laurent,
I now have TheSky Pro, so may come back and retry your software....
contraf15
Reged: 10/24/09
      #5595107 - 12/29/12 08:35 PM
Laurent,
I'm just getting started with automation and this software looks incredible! I do have one question. Would it be possible to call something other than Pinpoint for a plate solve? For example, the free PlateSolve2 program from PlaneWave Instruments ( http://www.planewave.com/index.php?page=4 ) gives me results that seem just as fast and accurate as PinpointLE. Maybe I'm asking too much from free software, but it would be nice!
totolesbaloches
Reged: 08/22/08
Loc: France
      #5595834 - 12/30/12 10:25 AM
New update 2.01.26
Fix bug detect zone for data with oser soft...
Note: i will see for PlateSolve2
Edited by totolesbaloches (12/30/12 01:21 PM)
totolesbaloches
Reged: 08/22/08
Loc: France
      #5614333 - 01/09/13 07:21 PM
New update 2.01.28
Use now Focusmax 3.7
totolesbaloches
Reged: 08/22/08
Loc: France
      #5632196 - 01/19/13 08:38 PM
New uptdate Update 2.01.30
-come back to focusmax 3.6.0.77
-add Dropbox use
-add shoot without guiding for Mount HS, but manage Dithering in direct drive
contraf15
Reged: 10/24/09
Re: MaxPilote: Software to manage Maxim DL/FocusMax... [Re: totolesbaloches]
      #5642958 - 01/25/13 04:42 PM
Laurent,
What is the reason for going back to FocusMax 3.6 as opposed to 3.7?
Jeremy
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: contraf15]
      #5681770 - 02/15/13 03:22 PM
Jeremy
focusmax seems to have problemes with some setup, loos parameters, not connect to maxim dl
Do you idee for this probleme ?
Laurent
totolesbaloches
Reged: 08/22/08
Loc: France
      #5721726 - 03/09/13 07:40 AM
New update V2.01.36
- use focusmax 3.7.0.52
- fix bugs - add goto watchdog
- add delay for close dome
- use now AAG CloudW 7.20.100
- add "Substract background"
- add Rotator management
jerryyyyy
Reged: 10/06/11
      #5721932 - 03/09/13 10:08 AM
Hi, how are you all doing? I am still using CCDComander but also having problems integrating FocusMax. May give your software another try now that I have all the proper software pieces....
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5721980 - 03/09/13 10:35 AM
Jerry,
It works really well. I've always had issues with FocusMax for some reason though.
Laurent, is there anyway to set up a park at a specific time? I burned up a motor on my mi-250 because the safety limit failed, and if I wasn't relying on the safety... it wouldn't have been an issue. Any ideas?
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: Raginar]
      #5750873 - 03/22/13 10:50 PM
I had the same problem with my Paramount if i forgeted or sleep , so i added a limit time, you have it in "StatUp"
totolesbaloches
Reged: 08/22/08
Loc: France
      #5750880 - 03/22/13 10:52 PM
New update 2.01.38
i add :
New showing
New Management for flip with Degre past meridian
the_blue_jester
journeyman
Reged: 11/12/06
      #5806813 - 04/18/13 02:15 PM
Laurent,
Very impressed. Every time I check out Maxpilote it gets nearer an excellent solution for me.
Please accept some suggestions. I may be wrong with (1) as I'm just starting to use a rotator and it is a bit confusing for me.
1) Rotator
a) The SkyX (and other programs) work on position angle (PA) and not necessarily rotator angle. When you click on "skymap" to bring an angle and object it reads the position angle whereas the angle from ASCOM is the actual angle of the rotator. There (perhaps) needs to be the facility to offset this difference
b) For a German equatorial then the actual angle versus the position angle change by 180 degrees (I think) so is there a way to automatically change this on a meridian flip?
2) Weather
I am not sure where the weather settings are. How do I set up so that if it's "unsafe" things stop. Also is there a way to simply "pause" if cloudy but to then "stop" if overcast? It's useful (in the UK!) for the session to "pause" for some conditions but close on others and even re-start when it becomes clear again.
3) Roof closure
Does the program park the mount BEFORE closing the roof? I have a roll off roof that would hit the telescope if shut too soon (well on my setup it wouldn't close because of safety switches)
4) The SkyX
Eventually it would be great to support The SkyX camera plugin
Many thanks for a great program and the amount of work it must take.
Best wishes
Paul
13 registered and 34 anonymous users are browsing this forum.
Moderator:  Oldfield, bilgebay
