Aquarist
Reged: 08/27/12
Loc: Illinois
Mild barlow for use with Leica 20-60x zoom?
      #5643983 - 01/26/13 08:55 AM
Any recommendations for a mild barlow with the Leica 20-60x zoom? Thanks for any ideas/recommendations.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Mild barlow for use with Leica 20-60x zoom? new [Re: Aquarist]
      #5644600 - 01/26/13 03:25 PM
You can screw the lens element of a Barcon onto the adapter, I dunno about the 20-60X zoom but in the ASPH this yields around 1.5X I believe. Only potential problem is the threads might not match exactly - mine don't.
A GSO barlow element would be a less expensive solution, I imagine it yields similar magnification.
Doug Culbertson
Reged: 01/06/05
Re: Mild barlow for use with Leica 20-60x zoom? new [Re: johnnyha]
      #5644617 - 01/26/13 03:38 PM
I use the Antares 1.6x barlow, which actually yields around 1.54x or so. I find it to be an excellent barlow, and you can add a 2" extension to get 2x.
Aquarist
Reged: 08/27/12
Loc: Illinois
      #5644641 - 01/26/13 03:56 PM
Actually I have the ASPH. I thought the Astro-Physics Barcon was discontinued and replaced with their 2" Advanced Convertible Barlow. Is that likely to be threaded for the ASPH? 1.5x is really what I would like.
johnnyha
Reged: 11/12/06
      #5644737 - 01/26/13 05:05 PM
The ASPH is not 20-60X, it's 25-50X.
I have an older Barcon which has 48mm threads but they do not match the pitch of the 48mm threads on my Leica Adapter, I can only screw it in a couple turns. I imagine the new Advanced Barcon would be the same. This is the fault of the APM Leica adapter not the Barcon.
I also have an Antares 1.6X barlow as Doug mentioned and it works really well with the Leica ASPH zoom.
Aquarist
Reged: 08/27/12
Loc: Illinois
      #5644803 - 01/26/13 05:45 PM
Yes, you are correct, my cutting and pasting was poorly done. I guess I will go with the Antares since that is about what I was looking to obtain.
johnnyha
Reged: 11/12/06
      #5644815 - 01/26/13 05:54 PM
Good choice. I have found the Antares 1.6X barlow to be an extremely versatile 2" barlow - low profile, inexpensive, and excellent quality - it seems to work well with everything.
andydj5xp
Reged: 05/27/04
Loc: 52.269 N/10.571 E
      #5645402 - 01/27/13 02:55 AM
Despite the title of this thread Leica ASPH in a slow Newt the discussion mainly deals with different configurations for barlowing the Leica ASPH. In case you haven't seen it have a close look.
Andreas
Aquarist
Reged: 08/27/12
Loc: Illinois
Re: Mild barlow for use with Leica 20-60x zoom? new [Re: andydj5xp]
      #5645640 - 01/27/13 09:05 AM
I have not seen it but will check it out. Thanks!
Aquarist
Reged: 08/27/12
Loc: Illinois
      #5645702 - 01/27/13 09:53 AM
Excellent information. Thanks Andreas!!!
11 registered and 20 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, Scott in NC
