Daniel Guzas
Reged: 11/20/10
Loc: Bethlehem NH/ Boston MA
Best eyepiece dew heaters?? new
      #5644368 - 01/26/13 01:00 PM
I have searched a bit on this forum and is seems that the Dew Not heaters are highly recommended. However some believe the Kendrick heaters are better.
I have a binoviewer with a couple of ES eyepieces that I have to add some sort of heating because of the cold. I currently have a Kendrick controller with 2 ports ( one for my wood wonders box dew heaters) and one spare available to possibly hook up a pair of eyepiece heaters.
So my question is... Can I use the Dew Not heaters with this controller or do they have to be Kendrick heaters?
Also is one necessarily better than the other? The Kendrick seem much more expensive. Am I getting more for the added cost?
Any advice would be helpful.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Best eyepiece dew heaters?? new [Re: Daniel Guzas]
      #5644383 - 01/26/13 01:12 PM
All these heaters run on 12VDC, and so are essentially compatible with the competition's gear. There may be minor differences in resistance between heaters of a given 'format', and hence a difference in heat output, but this should be of no real concern at all.
Fred1
Reged: 09/19/07
Loc: Somewhere in the Orion Spur
Re: Best eyepiece dew heaters?? new [Re: GlennLeDrew]
      #5644400 - 01/26/13 01:23 PM
The Kendricks are built better. They have cables and heating elements that are much more pliable in the cold and better RCA connectors. If you observe in sub-freezing temps and into the teens, I'd say go with the Kendricks, otherwise the Dew-Nots are fine. I have both. However, DewNot will do custom lengths and widths, if that's important.
ausastronomerModerator
Reged: 06/30/03
Loc: Kiama NSW (Australia)
Re: Best eyepiece dew heaters?? [Re: Fred1]
      #5645112 - 01/26/13 08:50 PM
I have locked this thread as it is duplicated. It can be found here, in the equipment forum
John B
16 registered and 18 anonymous users are browsing this forum.
