Pages: 1 | 2 | 3 | (show all)
WRAK
Reged: 02/18/12
Size of spurious disk
      #5645468 - 01/27/13 04:36 AM
We had this topic here several times and so far I had no reason to question the assumption that for a +6mag star the size of the spurious disk is about 50-60% of the size of the Airy disk (first minimum of the diffraction pattern). This means that the two spurious disks of an equal bright +6mag double star should slightly overlap at Rayleigh and certainly overlap at Dawes. But there have always been observation reports with "dark space" between the disks at Dawes or even less separation - and I have always taken these reports with caution because they seemed to disagree with established diffraction theory.
Now Chris Taylor writes in Argyle's book on "Observing ... Double Stars" on page 139 that he measured the size of the spurious disk of a +5-6mag star with a x825 magnification with 0.311" with an potential error of 0.037" and that this means only about 37% of the size of the Airy disk (with a reflector with a CO of 0,163 but he confirmed this result with his 4" refractor - although there should be a small difference in the relative size of the Airy Disk due to CO).
This would explain many dark space reports on close doubles and even explain many positive observations significantly below Dawes.
Wilfried
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Size of spurious disk new [Re: WRAK]
      #5645500 - 01/27/13 05:17 AM
Wilfried, it's a fascinating question. I have always used the 50% value at 6th magnitude and scaled it from there.
The dark space in a Dawes split is about 5% fall of in contrast between the maxima. It's not completely dark, but detectable to the human eye and appears dark. So, the spurious discs do overlap, it seems, at Dawes limit. And maybe even at Raleigh limit with 28% drop off in peak intensity. Of course, the latter does look "black."
Let me read up on the topic and hopefully some folks will chime in. I have always wanted to know how to calculate the spurious disc size, too, more accurately according to theory, aberrations present, and obstruction effects.
I believe this effect is further complicated with brighter stars because their spurious discs look uniformly bright. I am not sure at what point they may begin to appear no uniform as luminosity falls off. But, observing close 7th magnitude pairs in fairly good seeing did seem to show a contrast differential within each component's spurious disc.
"...the human eye response to light intensity is mainly logarithmic, hence better illustrated with logarithmic PSF. For instance, the intensity gap between central peak and second maxima in aberration-free aperture is 57 to 1, respectively; the eye, however, sees the peak as less than twice brighter (this applies when both are well within eye's detection threshold; as the fainter 1st bright ring nears detection threshold and falls bellow it, the perceived intensity differential dramatically increases)."
"For instance, the intensity gap between central peak and second maxima in aberration-free aperture is 57 to 1, respectively; the eye, however, sees the peak as less than twice brighter (this applies when both are well within eye's detection threshold; as the fainter 1st bright ring nears detection threshold and falls bellow it, the perceived intensity differential dramatically increases)."
"Moderately larger disc still should allow clear resolution, due to the intensity low forming between two star images, with the discs likely appearing less than perfectly round."
http://www.telescope-optics.net/telescope_resolution.htm
Here's one treatment of resolution. I am not sure it's exactly right. I read it and found I did not trust or understand it entirely. But it might offer some clues.
http://www.cloudynights.com/documents/resolution.pdf
Edited by Asbytec (01/27/13 05:42 AM)
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
      #5645639 - 01/27/13 09:03 AM
Wilf and Norme. I've been reading all the threads on this topic with fascination. You guys are really making an effort to nail down the science of 'splitting'. These threads should be required reading for all doublestar geeks (like me, for instance). At the eyepiece, for me however, things are far simpler.
All I ask myself is, "Can I see two stars?" Then I have succeeded in detecting duplicity. The degree of overlap can then be given a descriptor word like 'peanut', 'oblong' etc. Since the vast majority of amateur double star observers are not measuring the pairs (and those who do are using video and computer reduction methods) then the arbitrary 'dark sky split', Dawes' limit and Rayleigh's criterion are not necessary.
Another factor to consider is that the seeing is rarely good enough to closely examine the diffraction pattern at 800x with any telescope and if the seeing IS that good then I won't spend the night measuring the diameter of the spurious disc or the thickness of the rings or the various radii - I'll be viewing really close, difficult pairs.....
Dave
Cotts
Just Wondering
Reged: 10/10/05
Re: Size of spurious disk new [Re: Cotts]
      #5645652 - 01/27/13 09:12 AM
P.S. The idea of quantifying double star resolution into a neat set of equations has been around since the days of FGW Struve and has not been successfully nailed down yet. Considering the number of parameters involved It might well be impossible:
Aperture
% central obstruction
Magnitude of star A
Delta mag A vs. B
Color of A, B
Lord tried and Sissy Haas is having a go at the Delta Mag thing but it is like catching a soap bubble with a pair of vice-grips.
Dave
Dave
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5645690 - 01/27/13 09:45 AM
Dave, thank you. Yes, tropical seeing is /usually/ very good in a 6" aperture. It's been less than stellar, though, lately. Tonight I had 8 to 9/10 with a nearly full moon in the sky. Seeing the discs at any magnification was no problem, until magnitude neared 10th or more.
The proximity of the moon made dim difficult pairs even more so, or so it seemed. I did manage to split A 2705 at 9th and 10th magnitude and 1" arc sep but just could not go fainter. The spurious discs held nicely, but dimmer stars like A 2804 (nearly 10th mag and fainter companion) were begging for averted vision.
But, I agree, that's what I ask myself, "can I see two stars?" Not a rolling hint of brightness on one side of the ring like c Ori, but two discs or specks. A 2705 met that criteria, finally, as a tiny disc and a fainter speck.
Such nights are great for observing Jupiter, too, but the RoT project has my full attention.
You're correct, the RoT is very complicated and a difficult undertaking. But, I think if there is something to be gained by understanding the size of the spurious disc (either actually, theoretically, or visually), then some progress might be made.
Edited by Asbytec (01/27/13 09:51 AM)
WRAK
Reged: 02/18/12
Re: Size of spurious disk new [Re: Asbytec]
      #5646125 - 01/27/13 01:56 PM
Same book (Argyle), other observer with another scope (Jerry Spevak with 70mm refractor): STF2807 1.9" +8.7/8.8mag with touching spurious disks. Translating this into the smallest possible spurious disk fur such an observation I came up with ~45% of the Airy disk - but this is for a +8.7mag double and not in the +5-6mag range. So this observation seems to support rather the 50-60% hypothesis.
Taylor himself reports touching spurious disks for Beta Del with then (1996) 0.36". Regarding the effect of the rather small CO of 16,3% this would result in about 42% of the Airy Disk but this time for a brighter than +5mag double. This calculation does support his 37% claim to some degree but not fully.
So these numbers from Taylor and Spevak do not correspond very well.
I will be on the lookout for observation reports of equal bright doubles with touching spurious disks because these should allow to calculate the size of the spurious disk depending on the brightness of the components.
Dave - gratulation to your flexibility of changing your session plan according to seeing quality. I have the habit of sticking to my plan if possible at all. But as I use an iris diaphraghm I can translate any session plan into a limit observation session by reducing the aperture as far as possible. Wish I had better weather.
Your remark concerning past and current futile efforts for developping a useful RoT so far is certainly realistic - but thats just a challenge, not a reason to quit.
Wilfried
EdZ
Professor EdZ
Reged: 02/15/02
      #5646214 - 01/27/13 02:57 PM
I would like to point out one obvious error in my paper on resolution. About page 3, I say "a very bright star puts so much of the light into the spurious disk, the central disk can be 85% of the diaameter of the airy diosk." that is incorrect. While the central disk does contain 85% of hte light, that does NOT necessarily make it 85% of the diameter of the Airy disk.
That is the only error I know of to point out in that paper.
I recorded documentation in this forum many years ago on observations to test the size of the spurious disk. I'm sure now they are in the archives. There are several examples, but this one stands out. An observation of 16 Vul with a 150mm Ref.
I observed 16 Vul. mags 5.8-6.2/ separation 0.8" I used a 150mm f/8 refractor at magnifications from about 300x to 540x. At powers between 300 and perhaps 420x or 450x, it appeared to be completely separated. These lower powered observations would seem at first to support how some observers describe such observations as completely split. However as I approached the highest powers from 450x to 540x I was able to see more detail, that could not be seen at any lower powers. I clearly observed the spurious disks to have appox 10% overlap at powers over 500x. This observation supports that the spurious disk is approx 50%-60% of the Airy disk.
Other examples of observations very well documented in this forum are 52 Ori with a C5 (see the post "Limits of the C5") and the AB components of 16 CnC with a 150mm refractor, neither of which would support the spurious disks being less than 50% of the Airy disk.
All in all, over the last 10 years, I've documented dozens of observations in this forum, numerous in the mag 8 equal double category. (Actually, this forum has a treasure trove of documented observations.) I would say mag 8 equal double observations may get down to the 45% size of Airy disk, but the research of the actual observations recorded in here, that often give a percent overlap, would give a much more acurrate prediction.
In the "Limits of the C5" observations, I also explored the affect of blue stars on the size off the Airy and spurious disk, looking for a way to beat the 1.1" Rayleigh limit of the C5, IIRC to no avail.
edz
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Size of spurious disk new [Re: EdZ]
      #5647111 - 01/27/13 10:42 PM
Ed, thank you for clarifying. I believe that was the point I (personally, and maybe only me) got confused, and in the ensuing discussion about percentages of light in the Airy disc.
Is there a mathematical treatment for determining the diameter of the disc (without taking the human eye into account), maybe slicing the PSF at the visual threshold and calculating it's diameter?
Another active thread mentioned you comments in this thread, off to read it now...
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/3149322/Main...
fred1871
Reged: 03/22/09
Loc: Australia
      #5647130 - 01/27/13 10:54 PM
Lewis, following Airy (much earlier), gives some of the mathematics in his 1914 paper - along with levels of relative illumination in the diffraction image, etc. Of course, this is for optics without central obstruction.
Norme, the problem of where to slice - that is, what is perceptible to the eye - is I think more of an issue than the nature of the image. EdZ has indicated one aspect of that with his comments on what is seen at varying levels of magnification. In other words - how do you decide/establish "the visual threshold" to know where to slice?
WRAK
Reged: 02/18/12
      #5647364 - 01/28/13 02:40 AM
... I would like to point out one obvious error in my paper on resolution "... the central disk can be 85% of the diaameter of the airy diosk." that is incorrect...
Ed, thanks for pointing this out.
May be you could add some remarks to the topic "effect of CO" because your statement "If both scopes were the same size aperture, regardless of f#, the angular size of the Ariy disk would be the same" is certainly contradicting established diffraction theory stating the contrary that the size of the Airy disk is very well influenced by (the size of) CO.
Wilfried
EdZ
Professor EdZ
Reged: 02/15/02
      #5647442 - 01/28/13 06:01 AM
Well, you raised two completely different issues in that you just mentioned aperture and CO. I addressed the affect of CO in that paper. I treat aperture and CO in separate sections and talk about one effect at a time, so my comments regarding each are not contradictory. Likewise I treat wavelength and magnitude each in another section and treat them separately.
One of the most difficult issues when dealing with a topic that has perhaps as many as 10 different influences that affect the outcome is to not mix up influences in the discussion. The only way to do that is discuss one influence at a time, as I did in the passage where you mentioned my statement regarding aperture. By itseelf it is completely correct and not contradictory at all. By discussing one influence at a time, the reader is not left asking, OK which of those issues caused that outcome?
Let me also point out, the CO robs light from the central peak and throws that light into the sunsequent rings, making the rings much brighter in a scope with a CO. By doing so, it reduces the size of the spurious (visual central) disk. It has very little , if any, affect on the size of the Airy disk.
edz
EdZ
Professor EdZ
Reged: 02/15/02
      #5647488 - 01/28/13 07:04 AM
I have always wanted to know how to calculate the spurious (visible) disc size,
Is there a mathematical treatment for determining the diameter of the (visible) disc
I do recall reading a paper years ago in which a table was presented with fractions for the visible disk. I don't recall if those were determined mathematically or from observations..
IIRC that paper was found at
Publications of the Brayebrook Observatory
a double star resource leading to numerous technical papers
and this Brayebrook technical paper in particular
Telescopic Resolution of Unequal Binaries by C.J.R. Lord
The resources thread pinned at the top of this forum included links which at one time were active tto that website. Unfortunately they are no longer active.
edz
WRAK
Reged: 02/18/12
      #5647601 - 01/28/13 08:52 AM Attachment (14 downloads)
Ed, sorry for switching topic from "size of spurious disk in relation to size of Airy disk" (we agree here so far at least to some degree) to "size of Airy disk depending on CO" without further notice - but it seems we disagree here totally.
There are at least two clear references that the radius of the Airy disk (diameter of the first minimum) changes with the size of CO. First one is the paper of Lord "A report upon the analysis of the telescopic resolution of double stars of unequal brightness" with a table on page 6 (see uploaded image) indicating that the size of the Airy disk changes significantly with the size of CO.
Second reference is to be found at http://www.telescope-optics.net/obstruction.htm in table 8 again with the same content.
Else there exist several references in the literature about double stars that the size of the Airy disk gets smaller with increased CO without giving exact numbers.
In another thread (http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5611524/page/1/view/collapsed/sb/5/o/all/fpart/1) I was already wondering why this aspect is kind of ignored but this discussion came to no conclusive result.
Wilfried
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5647629 - 01/28/13 09:14 AM
Ed, I am reading, again, your treatment of resolution. On page 15, you begin discussing the effects of obstruction. As an example, you use a 6" aperture and a star with 83.8% light in the Airy disc - some of which is not visible. So, a dim star 60% as bright would be scaled down resulting in a visible disc of a smaller radius. The math seems pretty straight forward, 83.8% maximum intensity within the Airy disc * 60% ~ 50% the Airy diameter. For example, a 6" scope with an Airy diameter of 1.82" arc, the visible disc would have a diameter of 1.82" arc * 50% or 0.91" arc, which is the Raleigh limit in this case. A dimmer star, say 40%, would have a visible disc of 1.82" arc * 40% ~ 0.73" arc.
This is the convention I used when looking at an estimated visible disc size from bright stars down to the telescope's theoretical limiting magnitude (assuming 5% needed for the faintest stars to be seen above the pitch blackness of space.) Basically I just scaled their apparent, visual radii from 60% for mag 6 down to 5% for mag 14 (approx TLM.) I cannot remember what confused me during that exercise, other than maybe the slope of the PSF or the radius at any point not being that easy to work with.
So far, I have not gotten to the idea the Airy disc in an obstructed scope, the actual diffracted Airy disc, is smaller by a factor of 1 - co^2, where 1 is the aperture normalized to 1 and co is the obstruction by percentage of the aperture. In a 30% obstructed 150mm scope, the Airy disc becomes 138/150 * (1 - 0.3^2) = 0.84" arc, not 0.91" arc as Raleigh determined for a clear aperture. Added diffraction affects the outcome of the PSF.I think this explains my own success in excellent seeing of detecting a dark (not black) Dawes space on very tight nearly equal doubles, 7 tau at 0.72" arc +/- and around 7th magnitude being an example.
The maximum spacial frequency increases by that same factor, D/(1 - co^2) resulting from a smaller Airy disc, and peak intensity (normalized to 1) by (1 - co^2)^2. So, using the math above, the peak intensity for an obstructed scope might need to be adjusted down from 83.8% maximum peak intensity.
EdZ
Professor EdZ
Reged: 02/15/02
      #5647654 - 01/28/13 09:29 AM
thank you for finding Lord's table.
take note that although the location of the minimum of the Airy disk changes, the size of the visible disk, while it does change, changes less.
It's worth noting, as represented in this table, the position of the minimum of the Airy disk does change, but since it is a minimum, this position cannot be seen. Note how very little the position of the first ring changes and how little the size of the visible disk changes.
What has the most effect on the resovability of the double, the position of the minimum or the size of the central visual disk?
I would like to mention, this very topic was discussed extensively in hundreds of posts in this forum quite a few years ago. I do not recall specifics, but I seem to recall differences of opinion with the data represented here.
edz
WRAK
Reged: 02/18/12
      #5647790 - 01/28/13 10:50 AM Attachment (13 downloads)
...What has the most effect on the resovability of the double, the position of the minimum or the size of the central visual disk?...
Regardless of what seems plausible or not I tend to stick with the numbers like Norme - the Rayleigh criterion is defined with the first minimum of the diffraction pattern, the first minimum gets smaller with increasing CO, so CO influences the limits for splitting of equal doubles. This is also supportet with observation reports with better performance of reflectors for splitting equal bright doubles in the +6mag range.
Wilfried
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5647912 - 01/28/13 11:44 AM
The Airy disc is also slightly brighter than it would be if the radius stayed the same with an obstruction added. So, the obstruction dims it (obstruction and diffraction) and a slight decrease in diameter brightens it. This change in luminosity should affect the spurious disc size. For example, as you know, an unobstructed scope puts 84% of the light at peak intensity and a 30% obstructed scope 68%.
So, if your calculating for a 150mm scope, Raleigh limit is 138/150 = 0.92. The Airy diameter is 1.84" arc. Then, according to the math above, a dim star near 6th magnitude puts 50% of the light in the visible disc so it's diameter would be 1.84 * .5 = 0.92" arc spurious disc diameter (the Raleigh limit.)
For an 30% obstructed scope, the same "Raleigh limit" figure is 0.84" arc * 2 = 1.68" arc Airy disc diameter. However, it is also much dimmer to begin with due to diffraction and obscuration. A perfect 30% obstructed aperture produces a peak intensity of 68% (total diffraction and obscuration) and not 84% (diffraction only.) Normalized to 1, that is a Strehl-like result of 1 and 0.83, respectively.
So, following the same logic as in the clear aperture for a 6th magnitude star, it seems the Airy disc would be 1.68" arc * 0.5 = 0.83" arc radius (due to total diffraction) and dimmer by (1 - co^2 = 0.91%), or 0.84" arc * 91% = 0.76" arc compared to 0.92" arc unobstructed. An obstructed aperture Airy disc is, in a perfect optic, only 83% as bright as in a clear aperture. The rest is in the rings, respectively, 16% clear aperture and 32% with 0.3D obstruction.
Alternatively, total peak intensity (hence visual diameter) due to both diffraction and obscuration - normalized to 1 - is (1 - co^2)^2, or about 83% of the peak intensity of a clear aperture where 0.92" arc * 83% = 0.76" arc spurious disc diameter for a 150mm and 0.3D obstructed aperture. Provided the math of multiplying the Airy diameter by a percentage of visible disc holds, ya?
This seems to have some effect for very close doubles, Dawes and Sparrow limits are pushed back, where obstructed apertures have an advantage at spacial frequencies near D/(1 - co^2) just as the MTF says it will. (Though the MTF is slightly misleading because each scope's spacial frequency is normalized to 1, so the curve meets at 1.0 spacial frequency instead of D/[1 - co^2].) Of course, without taking into account the eye function, which is a wild card variable, and assuming seeing permits.
Edited by Asbytec (01/28/13 12:11 PM)
EdZ
Professor EdZ
Reged: 02/15/02
      #5648133 - 01/28/13 01:08 PM
Wilfried
My observations with 5", 6" and 8" SCTs do not support the increase in resolvability that you indicate here. Equally as important when compared to observations with my unobstructed scopes they do not show performance moved any considerable distance along the scale to indicate they are that much closer.
Your graphic would indicate a 5" 40% obstructed scope (my C5) can resolve nearly the same double as a 6" unobstructed scope (my CR150). Spend some time and perform 10 observations with each scope near and just below the difraction limits. You will find that just is not the case. The closest pair I've ever completely resolved with the C5 5" 40% obs was 1.1", with the CR150 0%obs 0.9"
In fact my C6 40% obstructed does not appreciably exceed my CR150.
edz
Cotts
Just Wondering
Reged: 10/10/05
      #5648358 - 01/28/13 02:31 PM
Wilfried
Wilfried. Your graph shows a very small difference in disc size from unobstructed (1.22 units - I assume arcsecs? ) to about 1.16 units in a 30% obstructed scope. About 5%. It is highly unlikely someone would use a 40% obstructed scope to do double star work so the entire range with useful double star scopes of 35% CO and less (interpolating a bit) is from 1.22 to 1.15 units which pretty much gets you into the noise theoretically and absolutely into the noise when actually observing. To simplify, I think the second decimal place here is not significant. And so, for practical purposes, at the eyepiece, the difference between these radii in an unobstructed scope and in a 35% obstructed scope is non-existant.
Dave
PS. The data in the WDS which we all use to determine separations only go to 2 significant digits in the separation ranges we are discussing here. Consider a WDS separation given as 1.2" This is a rounded figure and could actually be from 1.15" to 1.24", a range significantly greater than the variances in disc diameter vs. CO in your graph. Noisy data, indeed.
DC
Edited by Cotts (01/28/13 02:41 PM)
EdZ
Professor EdZ
Reged: 02/15/02
      #5648545 - 01/28/13 03:52 PM
Also, as i noted above, what is really shown in Lord's table is that the position of the minimum is moving within the dark space. frankly this is an almost inconsequential effect. To say that the position of the 1st minimum is not at 1.22 lambda, but is at 1.058 lambda, when the edge of the central spurious disk has not moved inward to the same degree and the position of the 1st ring has moved even less, essentailly means a dark minimum has moved on a dark pallette.
Take note that there is very little movement in the position of the first ring and the (what he calls) edge of the disk center.
This edge of disk center is another point that needs discussion. He seems to have chosen an arbitrary point, that at which the light is 50% or one half of the peak intensity. Take note that results in all of his disks ranging in size from 42% to 45% of the Airy disk, somewhat small from what seems to be known of central visible disks.
For what magnitude stars is that? Are we to assume the disk edge cannot be seen beyond a point where the light intensity drop below 50% of peak intensity? Or is this simply an arbitrary point? I think it is just an easily identified arbitrary point used forr consistency.
Furtermore his values indicate the visible disk increasing in percentage size of the Airy disk as the central obstruction increases, but this has far more to do with his indicated movemeent of the 1st minimum than anything else. He does indeed indicate the central disk getting smaller as CO increases, as we would expect.
Take note also that even if we assume the 50% intensity is the low limit of visibility, his central disk sizes drop only 8% from a 0% obstructed to 40% obstructed scope. Since he has arbitrarily chosen the 50% intensity diameter, we will have to assume that would hold true also at the limit of visiblity at the disk edge, regardless at what intensity we can no longer see light or how large the central disk is. That is what is going to control your ability to completely resolve the double. As I said before, it's a very small difference.
We conveniently determine the limit of resolution of our scopes by assuming the size of the visible central disk as one half the Airy disk. We even sometimes adjust the size of the central visible disk larger or smaller according to what we know of intense or dim magnitude. Empirical data shows this visible disk can sometimes be found to be larger than one half the Airy disk. It is this sizing of the central visible disk that determines our ability to resolve.
However, here in this table Lord accurately provides us with the sizes of the central disks at a constant point. So we do not use Lord's positions of the 1st minimum to determine one half of that as the central disk size as resolvabilty when he has provided us with the size of the visible disk.
This table gives no indication of a 20% gain in resolvability .
edz
WRAK
Reged: 02/18/12
      #5648822 - 01/28/13 05:48 PM
...Your graph shows a very small difference in disc size from unobstructed (1.22 units - I assume arcsecs? )...
Dave, no units here - numbers used in the grafic show only a relation. Small numbers in terms of separation translates in noticable numbers in terms of required aperture for splitting a double. Sorry that the image is less than precise - relative number for CO 0.3 is actually 1.1. This means that for a close double for example 0.5" the required aperture for reaching the Rayleigh criterion is 138/0.5=276mm for a refractor and 138/0.5/1.22*1.1 for a reflector with CO of 0.3 giving 249mm and this is certainly a significant difference.
Ed - share your frustration with SCTs concerning double star performance but this is maybe at least on my side also a question of personal preference.
Wilfried
EdZ
Professor EdZ
Reged: 02/15/02
      #5648902 - 01/28/13 06:27 PM
I certainly have no frustration with SCTs for double star performance. In fact, my C5 was without question one of the best scopes I've ever owned and was an exceptional double star performer. I'd put my C6 near the same.
edz
fred1871
Reged: 03/22/09
Loc: Australia
      #5649096 - 01/28/13 07:54 PM
edz
Ed, is that "exceptional" performance to do with near equal pairs or with significantly uneven pairs? The usual view is that large CO makes an unhelpful difference to close uneven pairs due to more light in the rings. Did your observing experience differ from that?
fred1871
Reged: 03/22/09
Loc: Australia
      #5649121 - 01/28/13 08:03 PM
Quote: The data in the WDS which we all use to determine separations only go to 2 significant digits in the separation ranges we are discussing here. Consider a WDS separation given as 1.2" This is a rounded figure and could actually be from 1.15" to 1.24", a range significantly greater than the variances in disc diameter vs. CO in your graph. Noisy data, indeed.
Indeed, quite right. It gets worse - there's some noise in the measures as well, even when quoted to two decimal places. It partly depends on the measuring method. Filar micrometers (the old standard) are typically less accurate than speckle interferometry. Speckle can't be used for everything. Other methods have varying average accuracies - and individual measures ditto. So there's potential "noise" (error bars) there as well. Of course, sometimes by chance noise may tend to cancel; sometimes by chance it's additive. So a series of measures at least allows some refinement. Eventually, the calculation of a grade 1 orbit, can reduce noise to very low levels. And wide pairs likewise can have lower noise levels (easier to measure accurately). And, no, I'm not suggesting big errors (big noise) are common.
And now, back to the main game ....
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5649488 - 01/28/13 11:31 PM
"Are we to assume the disk edge cannot be seen beyond a point where the light intensity drop below 50% of peak intensity?"
Even the 28% fall off in the Raleigh limit looks black and the Airy discs overlap by half their diameter. Your own math says a reasonably bright star with a visible disc of 60% the Airy diameter needs 60/50 = 1.2 * the Raleigh limit to see a clean, black space. For a 6" aperture, that increases the separation from 0.9" arc to 1.1" arc even if the first ring remains at 1.2" arc. A dimmer star 40/50 = 0.8 * the Raleigh limit or 0.73" arc for the same split (realizing the potential problems with very dim stars in reality.)
It makes sense cutting the PSF at varying levels of visible threshold might barely change the diameter of the visible disc because the slope of the curve changes little until near the peak. Even if the PSF itself is only 8 to 10% smaller at the base. But this implies bright and dim stars are nearly the same diameter, certainly closer than the significant spread between 1.1" arc and 0.73" arc as suggested above. What magnitude spread would be consistent with a 60% and 40% visible disc diameter? I think that is the question. How can one calculate the (ideal or theoretical) diameter of a spurious disc at some standard threshold of visibility, because that will affect the potential for resolution.
It get's complicated because dimmer stars do look smaller, maybe even less than 40% of the Airy disc. A dim star appears as a faint point, not a larger, very dim disc. As I understand taking the eye into account, bright stars (about first magnitude) appear pretty much flat across the central disc while dimmer stars (approaching 6th or 7th magnitude) begin to show some fading near the edge. Dimmer stars, even more so. This fall off is why the Raleigh split works, we can easily see a 28% drop off from the peak. And we can even see the 5% drop off at Dawes giving a dark space.
Now, given even an 8% decrease in the Airy diameter and the fall off from peak intensity, Dawes and Raleigh can both be bested in obstructed scopes (an old Questar ad even prides itself on that fact.) I have matched or beaten the Dawes limit on 7 Tau at it's reported theta, but am not sure how much tighter can be distinctly still be seen as two stars. Surely larger separations that 72 Pegasi at 0.57 or 0.6" arc. I realize we're getting into noise levels, here, and limits of seeing.
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
Re: Size of spurious disk new [Re: fred1871]
      #5649498 - 01/28/13 11:36 PM
Actually the first minimum in an Airy pattern is seen in a close double as it is the defining valley between the spurious disks. Whether or not the CO actually improves detectability (for near equal stars) is tough to say. The numbers say it is so. Seeing however dictates such an overwhelming influence (not to mention other details like eyepieces, visual acuity, etc) that it would be tough to prove.
But if Norme says he has then so much to the good.
The WDS and other catalogues do seem to lack precision. Does anyone know a good source to well defined precise measures for a set of 'popular' doubles? It would have to include orbital elements in some cases, but thats ok.
Glenn
azure1961p
Reged: 01/17/09
Loc: USA
      #5649528 - 01/28/13 11:52 PM
Ahh the slice quandary...
It would seem this becomes a problem not just here with doubles but in resolution limits on a number of fronts, is; planetary contrasts, lines versus disks, light features versus dark and resultant contrast. It would seem when you put the minds microscope up to drawing these finest boundaries and such it hits this ambiguous wall. One you'd normally never find if you never cut the wire that fine.
The slice issue is one of those things that seems to rest quietly till you wake it.
This is a really nice thread. Glad Edz dropped in.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Size of spurious disk new [Re: azure1961p]
      #5649639 - 01/29/13 02:14 AM Attachment (11 downloads)
Pete, apparently this is one of those topics that raises it's ugly head from time to time. I wish I could find the discussion Ed mentioned a few years back. Sorry to have missed it.
Glenn, I'm really curious to know how deep I can get on a split. The challenge is part of the allure of doubles, for me, and the entire journey of discovery has been fascinating. This whole RoT exercise and trying to understand how and why unequal pairs are difficult is so very interesting, too.
I was playing around with the apparent view of 7 Tau (top) and 31 Tau, two very close, nearly equal magnitude, Dawes pairs. The pairs are very close at just over 6th magnitude (approx), too. The sketch below is not far off from actual appearance, to me. I had to make the image small to get the darker space to show accurately as I can. So, 31 Tau is reported at 0.8" (150mm Dawes at 0.8" rounded) arc and 7 Tau at 0.74" arc (0.7" rounded.) So, rounded to one decimal, there is a 0.1" arc difference, otherwise maybe only about 0.06" arc. That's an incredibly tiny amount and still showing some contrast differential (dark, but not black space.)
Still, judging from the difference between the two, I'd bet I could shave off another couple 100th's and get closer to 0.70" arc and still see some contrast fall off between them. Taking the CO into account, Dawes /should/ be closer to 0.77" arc * (1 - 0.28^2) = 0.71" arc (barring aberrations) in 0.28% obstructed 150mm aperture (which is the Sparrow limit for 150mm clear aperture.) So, to me, it seems being able to get closer is a real deal and Wilfried is onto something. A real world observation that seems to agree with the MTF. I find observing something approaching the Sparrow limit fascinating and a challenge worthy of pursuit.
My guess is, accounting for inherent aberration (making close pairs more difficult) and the slightly dimmer pairs observed (making them a tad easier), I might be able to hit about 0.72" arc.
North is left and west is bottom. Seeing was exceptional at about 9/10 on average.
Edited by Asbytec (01/29/13 02:54 AM)
WRAK
Reged: 02/18/12
      #5649688 - 01/29/13 04:20 AM
For evidence regarding the performance of refractors and reflectors for splitting equal bright doubles I prefer again sticking to the numbers. Lord lists in his paper (to be found still under http://web.archive.org/web/20111203102746/http://www.brayebrookobservatory.or... ) single observations with 3 and 6" refractor and 6 and 10" reflector. While the advertised data in these reports for magnitudes is obsolete the data given for separation seems quite OK even if meanwhile WDS lists other separations due to orbits.
In relation to Dawes the 3" refractor shows for equal bright doubles one result with a 0.98 ratio and the 6" refractor shows 3 results with 0.92 ratio. For the 6" reflector Lord lists 2 results with a ratio of 0.79 and two with 0.92 and for the 10" reflector we find two results with a ratio of 0.87.
So at least this source gives evidence in favour of reflectors. There are hopefully other sources with better evidence for this topic and may be to the contrary - would be glad to know them but please do not refer to old threads that can no longer be found.
Wilfried
fred1871
Reged: 03/22/09
Loc: Australia
Re: Size of spurious disk new [Re: DesertRat]
      #5649693 - 01/29/13 04:25 AM
Quote: The WDS and other catalogues do seem to lack precision. Does anyone know a good source to well defined precise measures for a set of 'popular' doubles? It would have to include orbital elements in some cases, but thats ok.
Glenn
Glenn, the best prospect for highest accuracy measures is recent speckle measures of doubles. There are science papers, some available online, that discuss the improved level of accuracy attainable.
Otherwise, the 6th Orbit Catalog, same site as the WDS, the USNO astrometry section. Orbits with a "grade 1" rating are likely to be very accurate. Quite a few grade 2 orbits are of high standard too for getting high accuracy separations.
The WDS is a collecting house. Data will vary in accuracy, being collected from multiple sources, with varying levels of accuracy. It's the best single databasae for doubles. Of course there are errors, and the keepers of the WDS are open to being advised of these. But some data collected is of necessity going to be less accurate, or have errors.
If you look at some of the orbit plots in the 6th Orbit Catalog, especially with lower-graded orbits, say grade 3 and 4, you'll often find quite large error lines marked for some measures. It can even happen with grade 1 and 2 orbits - some data points don't fit the pattern of a large number of others so they're effectively rejected in determining the orbit.
Hope this helps.
fred1871
Reged: 03/22/09
Loc: Australia
      #5649696 - 01/29/13 04:31 AM
Wilfried, I may have overlooked it, but does Lord give a description in his paper you're referring to of what he means by "resolved"? The term is, as we've seen in these forums, often used with different meanings - separated, notched, elongated, not quite round, etc.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5649723 - 01/29/13 06:00 AM
Dave, those figures are not arc seconds, but the constant used to determine the angular size with the wavelength and the aperture. The Airy disc in a 30% obstructed scope is indeed (1.11 * 550 * .206) = 126/D radius in arc seconds - not 138/D. It's the difference between 0.92" and 0.84" for a 150mm clear and obstructed aperture, respectively.
The additional diffraction effects can be approximated using (1 - co^2.) So, in an obstructed aperture, the Airy disc is smaller with added diffraction by a factor of (1 - co^2), but also dimmer and smaller due to both diffraction and obscuration by a factor of (1 - co^2)^2 normalized to 1. It is the reason a 30% obstructed scope puts 68% of the light into the disc and 32% into the rings: the rings are brighter and the disc is dimmer and smaller.
Now, is that significant? In good seeing, cooled, perfectly collimated, and with a reasonably good Strehl (=/> 0.95) I am convinced (real world observation) it is.
It allows an obstructed scope to resolve closer pairs and still maintain some contrast between peaks. But, it also hampers unequal pairs with greater separations, complicated by the fact the second ring is a full magnitude dimmer in a moderately obstructed scope just as Treanor's chart above shows. The chart also shows how the disc shrinks in angular size at 50% intensity, and Treanor thought it to be significant.
EdZ
Professor EdZ
Reged: 02/15/02
      #5649738 - 01/29/13 06:21 AM
actually, these old threads are very easily found with just a minor effort. search on key words
Limits of C5
observations of 52 Ori at 1.1" and other 1" to 1.5" pairs including fainter pairs.
data for 52 Ori = 1.08"
Magnitude, Color and Obstruction affect resolution
look for links in these threads to other relevant threads
Dawes Limit vs Resolution
Evidence of overlap appearance in obstructed scope
observation of Zeta Cancri at 1 arcsec using C5, clearly shows that 16Cnc visible disk is not less than 50% of Airy disk.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5649745 - 01/29/13 06:28 AM
Thanks, Ed, "spurious disc" and a few other key words did not bring anything up within the first 10 pages.
EdZ
Professor EdZ
Reged: 02/15/02
      #5649759 - 01/29/13 06:56 AM
What is the formula for spurious disk size?
For this I seaarched on the word resolution
for the previous set I ssearched on the word limits
both under my name - open ended date
EdZ
Professor EdZ
Reged: 02/15/02
      #5649787 - 01/29/13 07:22 AM
Porrima at 1.0 arcsec in a C5 - strongly ooverlapped
edz
WRAK
Reged: 02/18/12
      #5649792 - 01/29/13 07:28 AM
Certainly a good question - Lord refers basically to Dawes, but also to Rayleigh, Sparrow etc. but does not give any definition what is to be considered as resolved. As Lord is using historical material from the Lewis collection of observations this question cannot be answered with any confidence as there are too many people involved - we can only trust in the seriosity of the observers.
Interesting also the last page of his paper I have overlooked until now, would have spared me some own calculations: The statement "Resolution of equal binaries may be marginally improved by introducing a central obstruction" is on top of a table with a calculation of the influence of a CO on the Rayleigh criterion.
Wilfried
Cotts
Just Wondering
Reged: 10/10/05
      #5649802 - 01/29/13 07:42 AM
Norme, if I see pairs such as in your illustrations I call them a split and move on.
I use Dawes and Rayleigh to select pairs for viewing - my new 8" TEC Mak-Cass will be examining lots of pairs from 0.4" to 1.0" because it's theoretical limit for splitting/resolving/dividing close pairs is around 0.6"...
And I'm jealous of your Pickering 9/10 seeing......
Dave
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5649826 - 01/29/13 08:11 AM
Dave, I fell into some great seeing during retirement, something not common during my professional career, and often so very thankful. It has allowed me to push the limits in ways I've never imagined. Without getting too religious, sometimes I look up and just thank God for the blessing. Few things are more beautiful than a well behaved Airy pattern.
Ed, having read some of the posts...I see where you mention more than once about the Airy disc size. In fact, "Although it could be a lifelong study, I wonder just at what point or how abruptly a transition from 'smaller disks' to 'more difficult to see' does occur? These thoughts need to go in the other thread when I get time." If you had not done so, now is the time.
I wish I could find that article, this seems to be discussed over and again. Anyway, Wilfried is looking for a way to figure the visible disc size, what would be the best way to attack that on paper, first? I used what I understood your article on resolution to mean: 50% Airy disc diameter and extrapolating down to limiting magnitude. Maybe that is not exactly the right method.
Fred mentioned slicing the PSF is too subjective or would be for different observers, but it might be a start.
Well, got some observing to so...back later. Cheers.
azure1961p
Reged: 01/17/09
Loc: USA
      #5650044 - 01/29/13 10:57 AM
I think part of the reason the slicing of the pie so to speak or lined boundary between value and another creates a quandary is that no line or slice can exist. Between values it would seem the lines, slices or limits are soft edged with a null zone of sorts. Within this grey area you could put varying perception between different observers and such so this zone is a grey area of averages.
Just a thought.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5650326 - 01/29/13 01:31 PM
You may be right, Pete, it's a complicated topic. Maybe Wilfried can just use the 50% figures in the chart he posted above. Maybe Treanor ran into the same problem and simply chose a cut off. But the figures are still a tiny bit smaller suggesting a tiny bit more resolution.
One thing becoming somewhat apparent to me is, when the conditions warrant - when all induced aberrations are minimal, those scales can make a tiny difference. You can push just a little deeper, maybe to the point where the size of the spurious disc will either make or break a tight split.
For example, I would never think of calling a split on 72 Pegasi at 0.56" arc. I called one on 7 Tau at 0.74" arc. And there is the slightest hint of a possible, barely detectable, tiniest hint (you get the point) of a very faint dark space on STT 517 at 0.67" arc. Not enough to call a split, but just enough to make you wonder. That seems unprecedented in theory and in practice.
So, there is probably no definite point where a split becomes non resolution, except for the Sparrow limit in concept, in theory, and maybe in practice. But, what is the Sparrow limit, 107/D is all scopes? There is probably a more gradual change up to the point where contrast is truly flat across the peaks. So, what is that point?
Point being, I think Wilfried asked a fascinating question that could use a good answer. I wish I had one for him. I do think about it a lot, and I do push my scope to those limits to see.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5650383 - 01/29/13 01:54 PM
Maybe I do. I'd have to dig up and verify my work, but at one point I calculated my own scope to have a high frequency resolution similar to a 6.4" clear aperture. Then, at lower frequencies larger than the first ring, I calculated it's mid range contrast transfer to be close to a 4.3" clear aperture. (I think I even included some aberration, Strehl 0.95 for my scope and assumed a Strehl 0.98 for the clear aperture.)
Now, since unequal pairs with separations within the frequency range corresponding to the first three or four rings seem to behave like planetary contrast at the same scale, so this treatment might be applicable to unequal pairs, too. After all, it is diffraction contrast that makes either difficult.
So, for tight pairs, treat an obstructed scope just like a slightly larger clear aperture. Conversely, for mid range frequencies out to about 3x or 4x Raleigh, treat an obstructed scope like a smaller aperture. A good figure can be calculated, for perfect or aberrant apertures, and the size of the spurious disc might be implicit in the answer.
WRAK
Reged: 02/18/12
      #5650689 - 01/29/13 04:27 PM
Ed, thanks for the posted links - I will go through them in the next days and will probably take the liberty to add some of the reported splits to my so far rather small data set of limit observations for my RoT project.
Wilfried
DesertRat
Reged: 06/18/06
      #5650819 - 01/29/13 05:44 PM
Thanks Fred! You jogged my memory into recalling the orbit grades. Interestingly Castor has a grade of '3' which was one I had interest in as I captured it as a test two years ago in computing plate scale. I realize a wider separation would be beneficial, but most binaries with good grades are very close doubles.
As far as the size of the spurious disk, one can calculate that assuming it is defined as something like full width half max. Using the wave eqn solution (no aberratons) with a possible obstruction, its not difficult to do. And it appears further up in this thread someone already did that calculation.
However the visual appearance I believe would be larger than that. If you were to use an insane amount of magnification, and had seeing of the gods, I suspect you would measure it out to something closer to the intensity of the first bright ring, or closer to 20% of the central max. But the flaw there is that the perception would be quite sensitive to the magnitude of the star. Bright stars would 'measure' quite a bit larger than faint stars.
Glenn
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5651347 - 01/29/13 11:10 PM
Glenn, my thoughts were to forget the spurious disc and simply go with line pairs. Calculate the maximum line pairs at either Dawes or Abbe limit, as modified by (1 - co^2), then calculate the clear aperture required to attain that spacial frequency. That clear aperture and the obstructed aperture should have the same maximum spacial frequency. So, you could treat resolution of close pairs the same way applying different apertures.
You can even apply aberration to the calculation using very good Strehl of 0.98 for the refractor and 0.95 for the obstructed scope. Using line pairs implies the spurious disc size. That would work for maximum spacial frequencies, in terms of getting an figure.
I don't remember how to treat lower frequencies. I may have determined the aberrant contrast transfer for both at lower frequencies, then applied the (D - co) rule of thumb to come up with a percentage of the clear aperture required. Its basically what we do we we say a 150mm - 42mm = 109mm clear aperture, then apply the a reasonable Strehl to both (instead of referring to "perfect" apertures like MTF does.) This should be more realistic, despite the non linear eyeball function.
Somehow you have to work in the lessor peak intensity of the obstructed scope (causing more light in the rings) using a approximation of (1 - co^2)^2 to determine their Strehl-like number and effective contrast transfer. The clear aperture definitely has the advantage here, so it can be smaller and perform as well.
Measuring them at insane magnifications would work, too. Dave mentioned that above. He seemed disinclined to do so because of the difficulties in getting 800x on a good night. He may have a point, and it would require calibration and some special equipment. It might be subject to errors, too. It could be done, but it might be done on paper, as well.
WRAK
Reged: 02/18/12
      #5652854 - 01/30/13 05:44 PM
According to the topic of this thread all observation reports were with may be one exception for equal doubles - certainly all interesting regarding the size of the spurious disk but to my regret of no use for the RoT project.
Wilfried
azure1961p
Reged: 01/17/09
Loc: USA
      #5653428 - 01/30/13 11:35 PM
Did Edz ever weigh on the queries you guys made?
Pete
WRAK
Reged: 02/18/12
      #5653545 - 01/31/13 02:35 AM
Sorry, no weigh intended.
Wilfried
EdZ
Professor EdZ
Reged: 02/15/02
      #5653681 - 01/31/13 06:37 AM
Pete
what queries?
WRAK
Reged: 02/18/12
      #5661894 - 02/04/13 02:24 PM
Back to the topic of this thread - the size of the spurious disk. Rereading the strong arguments of Taylor for the use of reflectors for double star observing I found no reason to doubt his measurement even if some of his reported observations shows extreme Dawes ratios down to 0.5 (without considering the effects of CO - Taylor mentions the use of artificial high COs for resolving extremely tight doubles).
At the same time I do not see any reason to question the observations of EdZ.
Referring to the numbers given for the size of the spurious disk in the already posted table of Chris Lord I get a relation of 42% of the Airy disk for non obstructed scopes. While Lord explains very well how he calculated the other numbers in his table he did this regrettable not for his numbers for the size of the spurious disk.
But may be the size of the spurious disk lies in the eye of the observer?
Wilfried
fred1871
Reged: 03/22/09
Loc: Australia
      #5662741 - 02/05/13 12:16 AM
A comment regarding Taylor - yes, he mentions using very large CO ratios, but indicates that none of the results he reports made use of that technique. Rather, it was with the 12.5-inch reflector in normal mode, with its normal small CO.
I've been saying this for some time now, in various versions, and I've noticed some others expressing a similar view.
How the eye sees what's there is interactive with the diffraction image, affected by seeing, CO effects, optical aberrations, and the quality of the eye along with the observer's ability to see (a skill improved by experience/practise).
WRAK
Reged: 02/18/12
      #5884117 - 05/25/13 02:39 PM Attachment (4 downloads)
... in Lord's table ... edge of disk center is another point that needs discussion. He seems to have chosen an arbitrary point, that at which the light is 50% or one half of the peak intensity.
... Are we to assume the disk edge cannot be seen beyond a point where the light intensity drop below 50% of peak intensity? Or is this simply an arbitrary point? I think it is just an easily identified arbitrary point used forr consistency
edz
Had to reactivate this thread for good reasons. Any approach for calculating the size of the spurious disk has to make assumptions regarding the visual theshold or use such a parameter as part of the calculation.
50% of the intensity seems an assumption very far away from reasonable to me - as we can see with good enough seeing conditions the first diffraction ring (or even more) of bright stars and as we know according to diffraction theory the energy resting in the first diffraction ring the visual threshold has to be less than 10% for scopes without CO.
But if you have a look at graphs of the diffraction pattern (like for example from http://micro.magnet.fsu.edu/optics/lightandcolor/images/diffractionfigure3.jpg) you see instantly that this small gap between spurious disk and first ring is certainly not what you see in the scope where the dark space between spurious disk and first ring seems much larger. But despite this I still think that the size of the spurious disk is at least for refractors much larger than 50% of the Airy disk (for brighter stars).
Have also searched my observation notes for dark space at Rayleigh for my 140mm refractor means 1" separation - found only one for the equal faint pair HO22 1" +8.5/8.64mag. All other observations at this separation range (not many as I have not this many nights with fair seeing) were notched rods at best and all positive obervations below 1" were with overlapping spurious disks from rods to eggs (considered positive resolutions when still allowing successfully to estimate the position of the companion).
Wilfried
1 registered and 6 anonymous users are browsing this forum.
Moderator:  PJ Anway, Rich (RLTYS), rflinn68
