droid
rocketman
Reged: 08/29/04
Loc: Conneaut, Ohio
Re: Was going to nab new RKEs to complete my set and..
[Re: actionhac]
#5645893 - 01/27/13 11:41 AM
Yeah the new RKEs are now 85.00 a pop. holy cow
rustynailz911
Reged: 01/30/08
[Re: actionhac]
#5645917 - 01/27/13 11:55 AM Attachment (10 downloads)
Terra i love my pre RKE K28mm from Carton it is a awesome piece of glass.In my 60mm f7 it gives me a massive 3.3 deg fov and is sharp right to the edge of the field.It was really nice during the conjunction of Jupiter and the Moon last week i could fit it everything in the FOV.I think the ultimate would be to have 2 if em in a binoviewer.
terraclarke
Reged: 05/29/12
Loc: Over the river and thru the wo...
[Re: actionhac]
#5645944 - 01/27/13 12:14 PM
Okay, now I'm confused. The add above says the ep has two achromats, i.e. two doublets, however both the Kellner and RKE consist of a singlet and a doublet. In the case of the Kellner, the doublet is the eye lens, and with the RKE it's the field lens. With the Kellner, the achromat is Plano-convex, positive side facing the field lens, with the RKE the positive side of the achromat faces the eye lens. The optics of the two eps are essentially reversed. So again, two achromats? What gives? Sounds more like a plossl.
rdandrea
Reged: 06/13/10
Loc: Colorado, USA DM59ra
[Re: terraclarke]
#5645978 - 01/27/13 12:32 PM
Or a symmetrical/dialsight. I don't recall whether anyone has disassembled one and posted pictures to CN.
bremms
Reged: 08/31/12
Loc: SC
[Re: terraclarke]
#5645979 - 01/27/13 12:32 PM
The early "RKE" was Plossl or symmetrical, not a Kellner. It wasn't an RKE. Took mine apart at some time in the mid 80's and it has two achromats. Not positive if it was symmetrical, but pretty sure it was. The RKE was a better eyepiece.
bremms
Reged: 08/31/12
Loc: SC
[Re: bremms]
#5645983 - 01/27/13 12:35 PM
There is one of the old ones( 79.00??) and a "real" RKE on the bay right now. $79.00 is wayyyy to much for the old Carton. A newer RKE or circle NJ 32mm TV plossl will be better
refasali
Reged: 01/28/12
Loc: Oregon & Washington
[Re: terraclarke]
#5646028 - 01/27/13 01:05 PM
from the same catalog, just opposite the eps in question
actionhac
Reged: 08/09/08
Loc: WA
[Re: refasali]
#5646112 - 01/27/13 01:47 PM
A traditional standard Kellner has a doublet eye lens and a singlet field lens.
The RKE (Rank Kellner Eyepiece) appears to be the reverse of above and the elements are modified.
Also Type 2 and 3 Kellners exist.
The old version of the Edmund 28mm (1 1/8") could be one of these type 2 or 3 Kellner variations, whatever they are like, but 2 doublets doesn't seen to fit the Kellner profile does it, but in fact the 2 doublets may possess some technical/design feature that allows it to remain a Kellner, sort of like poor Pluto, a dwarf, but still a planet.
They may be something cooked up for the military, I think we should look into the Type 2 and 3 Kellner.
RKE cutaway:
http://www.handprint.com/ASTRO/ae2.html#eyeterms
Robert
rdandrea
Reged: 06/13/10
[Re: actionhac]
#5646120 - 01/27/13 01:53 PM
Type III Kellner is discussed here: http://www.cloudynights.com/ubbthreads/showflat.php/Cat/1,2,3,4,5,6,7,8,9,10,11/Number/5204908/Main/5202111
refasali
Reged: 01/28/12
[Re: actionhac]
#5646505 - 01/27/13 05:33 PM
Ah- there's a Kellner type I, II, III mention in the old Edmund optical books... I the believe the following is from All About Telescopes (1975)
actionhac
Reged: 08/09/08
Loc: WA
[Re: refasali]
#5646808 - 01/27/13 07:53 PM
That book is a masterpiece.
orion61
Vendor(Clear Edge Optical)
Reged: 10/20/07
Loc: NW Iowa BURRRR
[Re: Preston Smith]
#5647188 - 01/27/13 11:37 PM
You need to take your time and find the right eye placement then they're very sweet.
I could not have stated it any better! It always takes a second or two to get your eye placement just right with that eyepiece. I enjoy the views with mine.
I love my set of RKE"s! Only bad thing about using the 28 is there is so much eye relief I have trouble using it in the City with street lamps, I use an eye cup, The image does seem to float in front of your eyes. I use them as my main eyepieces and am not ashamed to say so! You do have to keep bottom covers on to keep dust off the bottom lens cause it will drive you cray with the spots! I love the 15, 12, and 8 mm in my Bino Viewer. I cut my teeth on small field eyepieces so I don't need the 80 degree AFOV. They are very very bright and sharp in the center of the field.
Jaimo!
Reged: 10/11/07
Loc: Exit 135 / 40° North
[Re: orion61]
#5649025 - 01/28/13 07:25 PM
The Pre-RKE's are actually asymmetrical Plössls similar to Clave's, and I find I prefer the Pre-RKE views over the RKE:
I was even able to snag a 1" version on the bay, it has the same lens arrangement as the 1 1/8"
Jaimo!
