btb
Reged: 07/07/06
Loc: Northeast Indiana
Re: Is it sacrilegious... new [Re: Mike E.]
      #5646288 - 01/27/13 03:44 PM
If you don't tell anybody who is going to know?
Spyke
Reged: 07/22/03
Loc: Scotland
Re: Is it sacrilegious... new [Re: dfell]
      #5646289 - 01/27/13 03:45 PM
Scopestuff has an adapter to fit the Telrad base to a synta shoe, you may be able to adapt it for yours, then it can be added or removed like any other finder.
Thanks, but I've already got one of those - and it's even uglier than the standard Telrad base! Useful though.
So if the screws are safe to remove, I'll just mount the standard base on the OTA... anyone?
Thanks, Ant
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
Re: Is it sacrilegious... new [Re: EdZ]
      #5646327 - 01/27/13 04:10 PM
...to mount a Telrad on an Intes Micro M603?
I love using Telrads, even in combination with the optical finder, but I don't know... the M603 has such a "classic" look...
Ant
For me, telescopes are tools not holy relics.
Anything that makes my tools work better gets used.
good answer
I agree ... But it didn't really answer the question. Should he use the Telrad on his Mak or not?
Sarkikos
Reged: 12/18/07
Re: Is it sacrilegious... new [Re: Sarkikos]
      #5646344 - 01/27/13 04:18 PM
IME & IMO, a Telrad is too bulky for a 6" Mak or SCT. And putting it on a little Synta base is just an accident waiting to happen.
My used 6" Mak came with a Telrad base but I promptly took it off. Now I have two QuickFinder bases on the 6" Mak, one on either side of the focuser. Which base I mount the QuickFinder on depends on which mount I use for the OTA.
YMMV
Sarkikos
Reged: 12/18/07
Re: Is it sacrilegious... new [Re: Spyke]
      #5646351 - 01/27/13 04:19 PM
Ant,
Still want my custom miniaturised Telrad to be produced though!
That's called a QuickFinder.
Reged: 07/06/07
Re: Is it sacrilegious... new [Re: orion61]
      #5646377 - 01/27/13 04:28 PM
I usually agree with Rod about 1/2 the time.. LOL well perhaps a little more..
But he is 1000% right about this, all the other red dots or projection finders block out so much light they are practically useless, Only thing they are good for is
bright star alignment for go to, even then YUK.
Let me add that you can get standoff type brackets for Telrads that maybe make for a neater looking installation, if that's important.
m2k
Reged: 12/10/06
Loc: Massachusetts, USA
Re: Is it sacrilegious... new [Re: rmollise]
      #5646453 - 01/27/13 05:05 PM
I used one on my TEC-6...
-Mike
Spyke
Reged: 07/22/03
Loc: Scotland
Re: Is it sacrilegious... new [Re: m2k]
      #5646465 - 01/27/13 05:14 PM
Ok, quick question: do the screws that hold the finder attachment base on the M603 have nuts inside the OTA or is it safe to undo them without opening up the OTA?
TIA
Ant
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5646485 - 01/27/13 05:23 PM
Having both an optical and red dot finder enhances the utility of the telescope. The red dot gets the view close, and the optical dead on. Also, the optical finder gives a telescope view, which makes identifying the object in the main eye piece that much easier. I have used a variety of red dot finders, and in my opinion, the Telrad is superior.
stevew
Now I've done it
Reged: 03/03/06
Loc: British Columbia Canada
      #5646804 - 01/27/13 07:52 PM
It's a 6 inch Russian built utilitarian Maksutov, not the Mona Lisa.
Stick the Telrad on it!
If you have an issue with plastic, buy the Televue Starbeam.
Now if it was a TEC Mak........
Steve
      #5646864 - 01/27/13 08:22 PM
"...telescopes are tools not holy relics."
Bite your tongue, Unk.
- Jim
NHRob
Reged: 08/27/04
Loc: New Hampshire
Re: Is it sacrilegious... new [Re: jrbarnett]
      #5646866 - 01/27/13 08:25 PM
Unspeakable !!!
Sacrilege !!
Sarkikos
Reged: 12/18/07
      #5646944 - 01/27/13 09:03 PM
AFAIK, there are two standoff brackets. I've tried both for my 8" and 10" Dobs. I like the taller one better. It's easier to lean over the optical finder to reach the Telrad, and my head is comfortably above the OTA.
On the other hand, a Telrad takes up a lot of real estate on a 6" Cat. Put that Telrad on a tall standoff and it looks even more out of place and cumbersome.
As far as it being an offense against the Optics Gods, I've got nothing against sticking a Telrad base on any telescope. These scopes should be thought of as tools. That is what they are - or should be - after all. But IME that Telrad is just too large for small scopes. IMO, a Telrad on a small scope looks a bit ridiculous.
Sarkikos
Reged: 12/18/07
      #5646950 - 01/27/13 09:09 PM
Ant,
If you are determined to use a Telrad on the 6" Mak, just stick that sucker right on the OTA. Put the sticky tape on the base, and slap that base on the scope. Don't have it attached to a little Synta mount or something similiar, like some overblown monstrous weed. Just stick it right on the old OTA! The plastic Telrad base is not going to turn the rest of the Mak into plastic. It's not catching!
DoctorNoodle
Reged: 07/14/07
Loc: Lawn Guyland, NY
      #5646973 - 01/27/13 09:20 PM
I dunno. I always thought a Telrad was cool enough to go on any scope.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5647070 - 01/27/13 10:17 PM
I like this idea, especially if the Telrad base still attached with tape. That is my aversion.
Sarkikos
Reged: 12/18/07
Re: Is it sacrilegious... new [Re: Asbytec]
      #5647177 - 01/27/13 11:28 PM
Take a look at a Telrad attached to one of those puny little Synta shoes. Doesn't look very secure to me. Snag it and something's going to give. Just sayin'.
Telrad tape is easy to remove. Dental floss and Goop Gone gets it done.
catboat
Reged: 12/01/09
Loc: Maine
      #5647404 - 01/28/13 04:43 AM
TIA
Ant
Ant, You've asked this question twice, and I'd like to know the answer as well. So let me ask it again for you…
Can the finder shoes of the M603 be removed from the outside without nuts/retaining clips/whatever coming loose inside the tube?
Edited by catboat (01/28/13 11:32 AM)
Reged: 06/16/04
Re: Is it sacrilegious... [Re: DoctorNoodle]
      #5647418 - 01/28/13 05:17 AM
The important thing with any finder is not how it looks during daylight hours but how comfortable it is to use and how effective it is at night... The tendency is to place the finder towards the rear of the scope but it is often easier to use when it's up towards the front.
RogerRZ
Whatta you lookin' at?
Reged: 01/09/06
Loc: West Collette, NB, Canada
Re: Is it sacrilegious... new [Re: Jon Isaacs]
      #5647450 - 01/28/13 06:14 AM
I have one on my Intes MN65, and it works great. Iam, however, waiting for an acceptable cast iron version that would better intergrate with the rest of the trimmings on the scope...
17 registered and 25 anonymous users are browsing this forum.
Moderator:  Starman27, kkokkolis
