aa6ww
Reged: 10/23/11
Loc: Sacramento, Calif.
How accurate is the Celestron Nexstar SE6/8 Mount? new
      #5647323 - 01/28/13 01:47 AM
For people that own this mount, can you talk about the pointing accuracy of the this mount. Many years ago I had an LX-200 with High Precision Pointing, and it would always put objects dead center in the eyepiece when I was using that scope in HPP mode.
I understand this is more of an entry level GoTo type mount, maybe even for new astronomers who don't generally understand the skies or know whats out there, but there has to be some veterans out here who have owned this type of mount who can talk about the pointing accuracy of this mount.
Can the mount for example, put deep space objects in the field of view of your C8 consistently? Can you enter NGC or IC objects or other objects in the database by those catalog names, or enter coordinates in RA and Dec in the keypad, and it goes to those objects accurately and consistantly?
I'm asking because sometimes during my back yard observing, I cant always star hop to objects I want to find in the sky because my seeing conditions aren't always that good, but my C14 can still find objects i point to. I generally use my manual setting circles to find objects I cant star hop to, but sometimes, when using my long tube refractors, my mount is so high i have to get on a ladder to read the setting circles, and a simple mount like the Celestron Nexstar SE6/8 Mount set up with a lazer pointer and my TV-85 refractor on it could make finding objects in my back yard pretty easy.
Any comments on the pointing accuracy of this mount for those that have owned this type of mount?
Thanks for your time in responding.
...Ralph in Sacramento.
WarmWeatherGuy
Reged: 08/27/11
Loc: Orlando, FL 28° N, 81° W
Re: How accurate is the Celestron Nexstar SE6/8 Mount? new [Re: aa6ww]
      #5647348 - 01/28/13 02:12 AM
If you use Precise Goto you will get your target much closer to dead center than you will by using "regular" goto.
This YouTube video explains how to use it.
RTLR 12
Reged: 12/04/08
Re: How accurate is the Celestron Nexstar SE6/8 Mount? new [Re: WarmWeatherGuy]
      #5647403 - 01/28/13 04:38 AM Attachment (15 downloads)
I have an 8SE that I rarely use the 8" OTA with any more. I find it a very good mount for my small refractors. It is much more accurate than with the SCT. I also find 'Precise GoTo' to be very helpful.
Stan
Midnight Dan
Reged: 01/23/08
Re: How accurate is the Celestron Nexstar SE6/8 Mount? new [Re: RTLR 12]
      #5647489 - 01/28/13 07:10 AM
Hi Ralph:
As you say, it is an entry level mount in terms of goto accuracy. When properly set up, a normal goto will usually put objects somewhere in the field of a 25mm EP with an 8SE scope. Don't expect dead center.
As others have said, Precise Goto does an excellent job. It finds a bright star nearby the target of interest and allows you to align on it first before the final slew to the target. I use this frequently when going for very difficult targets that I'm not sure if I will be able to see or not. It gives me the confidence to know that if I don't see it pretty close to dead center of the field, then it's not visible.
-Dan
Reged: 07/06/07
Re: How accurate is the Celestron Nexstar SE6/8 Mount? new [Re: Midnight Dan]
      #5647518 - 01/28/13 07:45 AM
I don't own one, but I used a buddy's frequently. Verdict? Reasonably accurate if you are careful about centering alignment stars and using the up and right keys for final centering. Roughly comparable to my ETX 125--everything in a lower power eyepiece, but not always centered. I'd rate the ETX as slightly better and the NS GPS and CG5 as considerably better. Did always seem to me it was more prone to miss the occasional object than the ETX, but my pal was not always--or ever--very careful about alignments.
Edited by rmollise (01/28/13 07:47 AM)
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
      #5647549 - 01/28/13 08:09 AM
I used one for a few years and it worked quite well. As others have mentioned, it might not put everything dead center, but I could always count on the object being in the middle third of the field.
Yes, you can input RA/Dec coordinates - that's how I go to 90 percent of my doubles and variable stars. And yes you can also enter the NGC and IC numbers as well. The SE mount uses the standard Celestron hand paddle, so you can expect similar performance.
The SE mount is an alt/az, so you want to be careful picking alignment stars. Similar to a Dob, the accuracy is not as good when going to objects directly overhead.
Ron
Mike Foreman
Reged: 04/06/07
Loc: Texas
Re: How accurate is the Celestron Nexstar SE6/8 Mount? [Re: RAKing]
      #5649532 - 01/28/13 11:57 PM
I found the something Ron.
I had a 5si for several years and it worked very well.
I can sometimes only see 5 or 6 stars from my home in the DFW nebula so if I am going to look at anything dimmer than Mars I have to have a go to mount. If you search there are several threads about aligning and using the mount. You will enjoy it if you learn it's quirks.
MikeF
bogg
Reged: 11/17/09
Loc: Bruce County Ontario
Re: How accurate is the Celestron Nexstar SE6/8 Mount? new [Re: Mike Foreman]
      #5651747 - 01/30/13 08:04 AM
I have a 6se and if I am careful with centreing the alignment stars it will put the target in the centre 50percent of a 15 mm eyepiece. Precise goto will do better. If I am using a 32 mm and say that looks centre then most of the time the target is somewhere in the 32mm field. The SE mount does seem for me to give reasonable gotos. I use mine for a slightly larger travel scope.
palmer570
Reged: 09/04/12
Loc: Scranton, Pennsylvania
Re: How accurate is the Celestron Nexstar SE6/8 Mount? new [Re: bogg]
      #5661148 - 02/04/13 05:22 AM
Several in debt posts about the mount are in the nexstar sub forum. I believe Tel and Bob G. had extensive guides to these mounts and how to tweak them and tips for setting up alignment stars.
I'll do my best to quote some tips but they have it already explain very well.
NOTE: the following is just an example and some info my be wrong
Depending on how you balance your OTA you can change the setting for approaching stars and you want to be slightly front or back heavy. If front heavy you want to be moving the scope upwards when positioning alignment star and set the approach option in menu to this. Same can be done with azimuth. This example we will use right and up and our directions.
So you will always approach alignment stars with up and right on the controller. If you go past the star you cannot center with left or down so you will have to go back past the star and use up and right only till you center.
Another adjustment you can make is backlash in the gears and it helps with gotos and tracking.
I would definitly read their guides if you're considering a nexstar mount. They have helped me immensely.
As to your original questions I'm really pleased with mine. It's the only mount I've ever owned but with a good initial alignment its always been very accurate.
24 registered and 40 anonymous users are browsing this forum.
