Mike B
Starstruck
Reged: 04/06/05
Loc: shake, rattle, & roll, CA
Re: mirror cleaning and cotton new [Re: Starman1]
      #5646646 - 01/27/13 06:36 PM
The mirror runs a bigger danger from chipping by hitting it against the sink, so there you do have to be careful...
Yeah, no kidding! While the *idea* of cleaning my mirror, in principle, no longer worries me... the actual PROCESS- involving metal spigots, tile counters, steel basins, and a general klutz in charge of orchestrating the whole affair... i'm pretty nervous as i actually perform the task!
turtle86
Pooh-Bah Everywhere Else
Reged: 10/09/06
Re: mirror cleaning and cotton new [Re: Mike B]
      #5646715 - 01/27/13 07:04 PM
Same here. Even if my 18" mirror could fit in my kitchen sink I think I'd still want to clean it in a plastic container anyway.
Aleko
Reged: 08/01/10
Loc: Georgia
      #5646897 - 01/27/13 08:41 PM
"found that cotton balls did not clean the mirror adequately, so I use my fingertips."
Don, I'm sitting here feeling like an idiot for never having tried this in 20 years of mirror cleaning. What a great tip!
I've had a small mirror set aside to have recoated, so I just tried your method and in 5 minutes the haze was gone. The mirror will go back into the scope instead of to the recoater.
-Alex
Tim L
Reged: 12/17/08
Loc: Missouri
Re: mirror cleaning and cotton new [Re: Aleko]
      #5646991 - 01/27/13 09:35 PM
Any thoughts from any of you about whether the type of tap water in the home (hard vs. soft) has any impact on the mirror?
I've seen haze on my mirror too, but thought maybe it was because I was only using distilled water for the final rinse. I'll try using fingertips for light cleaning next time.
okieav8rModerator
I'd rather be flying!
Reged: 03/01/09
Loc: Oklahoma!
Re: mirror cleaning and cotton new [Re: Tim L]
      #5647468 - 01/28/13 06:33 AM
I use distilled water for the entire cleaning. It's cheaper than dirt.
Mike B
Starstruck
Reged: 04/06/05
Re: mirror cleaning and cotton new [Re: okieav8r]
      #5648534 - 01/28/13 03:47 PM
I dunno... if you've ever had to import good fill, or topsoil, you'd find that dirt ain't quite so cheap.
Still, probably not among the better solutions for mirror cleaning...
davidpitre
Reged: 05/10/05
Loc: Central Texas
Re: mirror cleaning and cotton [Re: Tim L]
      #5650456 - 01/29/13 02:30 PM
Hard water will tend to leave more spotting than soft water (hard water will typically be higher in calcium and or magnesium both of which can account for the spotting). I'm not so sure I would want to use water run through a softener though, as the salt would likely be bad for the coatings. Most like to rinse with distilled water after rinsing any detergent. I don't see an advantage to washing with distilled water as a distilled water rinse quickly removes tap water
jeff heck
Reged: 01/16/06
Loc: stl,mo.
Re: mirror cleaning and cotton new [Re: davidpitre]
      #5656611 - 02/01/13 03:44 PM
I just finished cleaning my mirror using the handwash method, came out perfect with no film/haze.
Also, kudos to the Teeter method of mirror removal, I now have a stress free method of mirror maintance.
VĂ­ctor MartĂ­nez
Reged: 02/05/07
Loc: Cádiz - Spain
Re: mirror cleaning and cotton new [Re: jeff heck]
      #5712829 - 03/04/13 04:17 PM
Does anyone know an effective and definitive method to remove watermarks even after using distilled water??
nevy
Reged: 02/07/12
Loc: UK
Re: mirror cleaning and cotton new [Re: VĂ­ctor MartĂ­nez]
      #5712878 - 03/04/13 04:42 PM
I found Isopropyl get rid of water marks.
VĂ­ctor MartĂ­nez
Reged: 02/05/07
Loc: Cádiz - Spain
Re: mirror cleaning and cotton new [Re: nevy]
      #5712989 - 03/04/13 05:31 PM
Directly on the mirror?
nevy
Reged: 02/07/12
Loc: UK
      #5713174 - 03/04/13 07:27 PM
Yes , but be carefull if you have a hotspot as it can loosen the glue.
VĂ­ctor MartĂ­nez
Reged: 02/05/07
Loc: Cádiz - Spain
      #5713805 - 03/05/13 02:58 AM
Ok, thank you.
VĂ­ctor MartĂ­nez
Reged: 02/05/07
Loc: Cádiz - Spain
      #5713895 - 03/05/13 06:01 AM
Well, I just cleaned my secondary mirror with pure acetone, as shown in the video of Spectrum coatings and I can only say one thing, I'm releasing my secondary mirror, safe, quick and easy.
http://www.spectrum-coatings.com/Movies/Removing%20Finger%20Prints%20Video%20...
Xiaoding
journeyman
Reged: 12/19/13
Loc: Raleigh, NC, USA
      #6360301 - 02/06/14 06:01 PM
If the haze is difficult to remove, i wonder, if an alkaline based cleaner would work?
I haven't cleaned my mirror yet, so this is just theory for me.
I know, most dish soaps are alcohol based. So, they clean certain stuff, but not all. The water, for instance, helps get sugars off, since alcohol does not dissolve that. So, when cleaning furniture, I use alcohol, then water, then alcohol again.
So, try some alcohol, if that doesn't work, try an alkaline based cleaner. Spic and Span is such, and "Awesome Cleaner", sold here in the states.
Any yellow cleaner, that is very slippery, is alkaline based. Dissolves different things than alcohols.
Anyone tried alkaline on their mirrors? I know that alkaline does wonders for stained dishes and mugs. Let it soak, stains gone!
Another bit of cleaner info: all cleaners work one molecular layer at a time. So, it may take awhile, repeated applications, to get it all off.
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: mirror cleaning and cotton new [Re: Xiaoding]
      #6362525 - 02/07/14 05:49 PM
Neither acids nor alkalis will be good on mirrors. The aluminum actually reacts to neutral water if contact is prolonged. It reacts more strongly to alcohol and acetone. Your ideal cleaner would be pH neutral, and contain a surfactant for cleaning, followed by distilled water (de-ionized if possible).
19 registered and 37 anonymous users are browsing this forum.
