Telescope Specific Forums >> Meade LX
chasdz
Reged: 01/04/13
Loc: Seattle
OTA Swap out new
      #5650430 - 01/29/13 02:18 PM
I have an older LX 200 and want swap out the OTA . Is there a site that shows how this is done? I find a lot on de-forking but nothing on installation
Christopher EricksonModerator
Reged: 05/08/06
Loc: Waikoloa Village, Hawaii
Re: OTA Swap out new [Re: chasdz]
      #5650835 - 01/29/13 05:56 PM
Swap out the OTA with what?
chasdz
Reged: 01/04/13
Loc: Seattle
Re: OTA Swap out new [Re: Christopher Erickson]
      #5650842 - 01/29/13 05:58 PM
Sorry it's a newer ota of the same size lx200 with better optics.
Edited by chasdz (01/29/13 06:03 PM)
ldesign1
Reged: 09/17/09
Loc: Northern Illinois
      #5651492 - 01/30/13 12:56 AM
Sounds like you found what you need. Just work in reverse and RE-FORK. Just make alignment marks with pieces of tape to line the forks back up with the base before disassembly.
SEE IF THIS HELPS
If you join the LX200GPS Yahoo Group, you can down load this LX200GPS_Conversion_LX200R.doc file from the files folder. You have to be logged into yahoo and be a member of that group to download the file. It has lots of pictures for re-forking a new OTA.
chasdz
Reged: 01/04/13
Loc: Seattle
Re: OTA Swap out [Re: ldesign1]
      #5651872 - 01/30/13 09:25 AM
Thank you
I'LL DO JUST THAT
Markigno
Reged: 01/09/10
      #5655684 - 02/01/13 07:26 AM
Sorry but I do not understand these operations. RE-fork an OTA is not easy without the proper tools. THE GOTO can suffer enormously negative.
Sell old instrument, and buy one, even used, with next-generation optical. So much easier. This is the best way to go.
Marco
Edited by Markigno (02/01/13 07:27 AM)
Reged: 05/08/06
Re: OTA Swap out new [Re: Markigno]
      #5656632 - 02/01/13 03:55 PM
Marco
Actually if the diameter is the same and all of the threaded holes line up properly, all you have to do is check and adjust the orthogonality to have the GOTO accuracy work just fine.
And even if you just eyeball the orthogonality and call it good enough, the GOTO accuracy will probably be acceptable.
http://home.comcast.net/~jmmahony1/LX10/forkalign.html
chasdz
Reged: 01/04/13
Loc: Seattle
      #5663433 - 02/05/13 11:41 AM
Thanks again for your help.
rice224534
Reged: 06/29/08
Loc: Tokyo
      #5667825 - 02/07/13 08:39 PM Attachment (16 downloads)
Here is my 8" reflector LX200GPS telescope.
I use it for visual and imaging.
Matthew Ota
Hmmm
Reged: 04/30/05
Loc: Los Angeles, California
Re: OTA Swap out new [Re: rice224534]
      #5677880 - 02/13/13 03:37 PM
In 2007 I swapped out OTAs on a 10 inch LX200GPS mount. Instead of tape I used scribe marks on the fork tines to maintain orthagonality. It woked fine and my telescope points fine.
3 registered and 8 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
