oldbaldeagle
newbie
Reged: 12/27/12
aligning & centering a Telrad on a NexStar 6SE
      #5654323 - 01/31/13 01:26 PM
Hello
I'm trying to get my new 6E aligned with my new Telrad (along with 4" riser). According to Company 7 (Telrad manufacturer http://www.company7.com/telrad/products/telrad.html) the reticle pattern can be aligned during daylight. Yet, even at full power , in daylight I'm unable to see the pattern. Would you folks have a "best practice" on properly doing this task? And is daylight not an option or is my Telrad not working correctly?
Thanks in advance.
Cronan
mitaccio
Reged: 03/17/09
Loc: Oahu, Hawaii
Re: aligning & centering a Telrad on a NexStar 6SE new [Re: oldbaldeagle]
      #5654584 - 01/31/13 03:54 PM
First, be careful when using a telrad during the daytime. If the reticle gets direct sunslight it can be ruined. Make sure that you have good batteries. With it turned on at maximum brightness, look down from the top and see if you can see the reticle displayed. If you can't see the reticle looking down into the telrad then you have a problem with the led/reticle.
I don't recommend using it for daytime alignment, it's too easy to do at night with just a few minutes and a low powered eyepiece.
BigC
Reged: 09/29/10
Loc: SE Indiana
      #5655053 - 01/31/13 08:50 PM
Well I cannot see well the dot or rings in my scopes' RDF or Telrad outside on a sunny or bright overcast day.At the very least try to set up the 6SE and Telrad under as shaded a spot as possible perhaps by bringing out the patio umbrella.Or set up the 6SE in interior hallway with the lights off and align on a distant object visible through a window or doorway.
You are just trying to get a finder alignment so forget all the advice about not viewing through a window.
You can touch up the Telrad alignment on the Moon or a bright star in the evening.
Bob Griffiths
Getting Grouchy
Reged: 10/10/05
Loc: Frederick Maryland
Re: aligning & centering a Telrad on a NexStar 6SE new [Re: BigC]
      #5656468 - 02/01/13 02:23 PM
Bore site it ... simply look thru the scope at an object at a distance and then align the Telrad so that object is visible somewhere close to the center of the telrads "window"...you do not even have to power on the telrad
Take it off the raiser to do this.. its just easier to use the regular base ...
When its dark you can install the raiser and adjust it in seconds...
Bob G.
Greyhaven
Reged: 05/11/04
Loc: Greater downtown Maine
      #5656596 - 02/01/13 03:35 PM
I try to align my scope and finder during day light, one less last minute thing to do as the daylight fades. That's why I use a regular RACI finder or straight through 9x50 for most occasions Telrad does not work well under these circumstances and I find the awkward head position I need to see through the telrad even with a riser make it at best a secondary finder.
Be Well
Grey
oldbaldeagle
newbie
Reged: 12/27/12
Re: aligning & centering a Telrad on a NexStar 6SE new [Re: Greyhaven]
      #5657489 - 02/02/13 01:22 AM
thanks to all for the help.
5 registered and 13 anonymous users are browsing this forum.
