Scott in NCModerator
Mad Hatter
Reged: 03/05/05
Loc: NC
Re: If you could have only two eyepieces... new [Re: csrlice12]
      #5643014 - 01/25/13 05:28 PM
My traveling rig consists of a Nagler 3-6mm zoom, a Baader 8-24mm zoom, and a Televue 32mm Plossl. Okay, so that's 3 EPs, but if I had to pick only two I'd take the 2 zooms. If I could add a barlow or Powermate, then I'd use a TV 2x zoom or 2.5x Powermate along with the Baader 8-24mm zoom and TV 32mm Plossl.
But as I said, that's my travel rig for use with an 80mm f/6 refractor. I don't think I'd be happy confining myself to only 2-3 eyepieces for home use with multiple scopes with FLs ranging from 200-2000mm.
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: If you could have only two eyepieces... new [Re: Scott in NC]
      #5643036 - 01/25/13 05:39 PM
As much as I love the TV 32mm Plossl, that 80mm cries out for a larger-field 2" eyepiece. It probably has 2" capabilities?
Oh, and happy birthday and clear skies!
Illinois
Reged: 12/18/06
Loc: near Dixon, Illinois USA
Re: If you could have only two eyepieces... new [Re: Starman1]
      #5643968 - 01/26/13 08:43 AM
Million suggestions! I like low and medium power for most of the time. 26 mm and 10 mm! Good luck!
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
Re: If you could have only two eyepieces... new [Re: da_guy2]
      #5653005 - 01/30/13 06:51 PM
I'm putting together a little grab and go kit with my WO 80 FD (555mm f/6.9),
Leica ASPH zoom plus an AP BarAdv (and a small spacer ring to allow you to put 2" filters in between without hitting the BarAdv T2-threads), or Leica + Baader VIP element in a few baader T2 parts (then you can add 2" filters at the end).
Hey, you didn't mention a budget, now, did you?
Sean Puett
Reged: 09/06/10
Loc: always cloudy, washington
Re: If you could have only two eyepieces... new [Re: sixela]
      #5653435 - 01/30/13 11:45 PM
If I could have only two eyepieces...
I would cry myself to sleep every night.
21e 13e 2x powermate. Probably doesn't help with the space issue though. The 21e is the size of a 50mm finder.
Scanning4Comets
Markus
Reged: 12/26/04
Re: If you could have only two eyepieces... new [Re: Sean Puett]
      #5653481 - 01/31/13 12:45 AM
30mm XW
7mm XW
And a 2" Barlow
FirstSight
Duke of Deneb
Reged: 12/26/05
Loc: Raleigh, NC
Re: If you could have only two eyepieces... new [Re: Scanning4Comets]
      #5654790 - 01/31/13 06:01 PM
13mm Ethos + 4.7mm Ethos
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
Re: If you could have only two eyepieces... [Re: da_guy2]
      #5654858 - 01/31/13 06:33 PM
Unless you use a zoom, you need three --a low, medium and high power eyepiece.
11 registered and 27 anonymous users are browsing this forum.
