Gray
Reged: 01/31/11
Loc: Hixson, TN
IC434 Ha 1st time
      #5655449 - 02/01/13 01:28 AM Attachment (27 downloads)
Here is my first image with the new Atlas mount.
I'm going to try adding RGB tommarow night. Clouds rolled in tonight.
Horsehead and Flame nebula
AstroTech 72ED+ATFF
Orion Atlas. Sx Costar. Orion DSI3
300"x10. Baader Ha 35nm
Edited by Gray (02/01/13 09:33 AM)
Wouter D'hoye
Reged: 06/27/03
Loc: Belgium
Re: IC434 Ha 1st time new [Re: Gray]
      #5655471 - 02/01/13 01:47 AM
A nice image. Though I think you can pull a bit more from the image. Mybe try to increase the contrast for the dimmer parts of the image a bit.
Kind regards,
Wouter.
Mike7Mak
Reged: 12/07/11
Loc: New York
Re: IC434 Ha 1st time new [Re: Wouter D'hoye]
      #5655555 - 02/01/13 03:59 AM Attachment (12 downloads)
Hi Graham, looks like the new mount and guider is working good. Wouter is right, there's more detail in there, but when I stretched it up a bit there's a bright gradient along the left edge and top. Did you do flats? It might just be sensitivity patterns in the chip that flats should correct. I've seen something like it in almost every camera I've used.
Like in this flat from my 314L
NorthBoundTrain
Reged: 11/23/11
Re: IC434 Ha 1st time new [Re: Mike7Mak]
      #5655857 - 02/01/13 09:07 AM
Looking good Graham, I also agree that there is more detail hiding. Nice work though!
Undermidnight
BEOTS "Tweener Cup" winner
Reged: 05/25/04
Loc: Untermitternacht
Re: IC434 Ha 1st time new [Re: NorthBoundTrain]
      #5655859 - 02/01/13 09:09 AM
Gray
Reged: 01/31/11
Loc: Hixson, TN
Re: IC434 Ha 1st time new [Re: Undermidnight]
      #5655992 - 02/01/13 10:10 AM
Wow thanks fellas! Even got a from a mod. Hey Mike & Chris, it's been a while; glad to see you both here again. Wouter, I did stretch it a bit this morning when I got in and saw the extras in there, but I tried to keep an even smoothness across the image. I didn't use any flats but added three old bias frames from long ago. Mike, I believe that bright side maybe a mix of my neighbor's back-porch C.F. and I need to do flats; maybe darks too.
The light is literately 20' away. (Side project, buy OSB and nail up on fence).
I thought it looked nice even though the seeing was throwing my guiding off every so often. I'm trying to figure out how automating my imaging sequences would work, or if it's even worth it.
Thank you for your comments!
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5657875 - 02/02/13 10:34 AM
Just wanted to another 'well done!' to the above Getting stars that round with the new mount and getting the HH 'center chip' deserves an 'attaboy' at the minimum.
Gray
Reged: 01/31/11
Loc: Hixson, TN
Re: IC434 Ha 1st time new [Re: CounterWeight]
      #5658142 - 02/02/13 01:22 PM Attachment (7 downloads)
Added some RGB lastnight. Had to rotate and cut a large piece of fov. Thank you folks. Processed in CS5 and Fitsworks 4.
21 registered and 21 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, fishonkevin, WOBentley, rflinn68
