Koen Dierckens
Reged: 11/04/09
Loc: Antwerp, Belgium
Re: Great $60 Case for CPC 1100
[Re: Koen Dierckens]
#5126623 - 03/17/12 07:26 AM Attachment (86 downloads)
Pile of junk :-) on the small built-in table. It all comes out of the box.
Koen Dierckens
Reged: 11/04/09
#5126624 - 03/17/12 07:27 AM Attachment (69 downloads)
Left foam cut in half for easy removal; making lifting out and in of the OTA more easy. The foam at the right side goes on top of the OTA and is taken out/put in the box together with the OTA.
shiner
Reged: 11/04/11
Loc: England
#5127231 - 03/17/12 03:34 PM
Koen, what are the sockets and switches below the handle pls ?
Koen Dierckens
Reged: 11/04/09
[Re: shiner]
#5127497 - 03/17/12 06:41 PM
Shiner, that's a built-in self-made dew controller .
shrevestan
Reged: 04/19/12
Loc: Shreveport, LA
#5183559 - 04/21/12 05:06 PM
Just found this thread. I have an extra Stanley box I took to Iraq that will now get a new life!
Thanks CN!
boblakewood
Reged: 04/26/06
Loc: Vlg of Lakewood IL
[Re: shrevestan]
#5656303 - 02/01/13 12:45 PM
Does anyone know where to find this product these days? This thread goes back about 4-5 years ago.
Thanks for any help.
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
[Re: boblakewood]
#5656938 - 02/01/13 06:40 PM
I got mine at Home Depot. Don't know if Lowes carries them too, but it is worth a check. I suspect one could also order direct from Stanley, though shipping might be a bear.
jerwin
Reged: 05/17/12
Loc: Romeoville IL
[Re: MikeBOKC]
#5657055 - 02/01/13 08:00 PM
+ 1 for home depot about 6 months ago. In or near the hand tools isle.
Thanatos78621
Reged: 05/09/12
Loc: Elgin, TX
[Re: jerwin]
#5671815 - 02/10/13 05:03 AM
here's the Home Depot webpage for it:
http://www.homedepot.com/p/t/202300294?catalogId=10053
I might have to go pick one up myself
pcctex
Reged: 04/13/10
Loc: Texas Panhandle
[Re: Thanatos78621]
#5763148 - 03/28/13 08:45 PM
As it relates to storing an 11" CPC Edge in a Stanley case..... Can anyone tell me the actual length of the Feathertouch micro focus knob? I'm reluctant to install a micro focuser, then find that the scope no longer fits the storage box. I know; using storage as a determining factor for installing a focuser is silly, but storing our big scopes can be a huge issue. Thank you to all.
MikeBOKC
Reged: 05/10/10
[Re: Thanatos78621]
#5763245 - 03/28/13 09:44 PM
I have the feathertouch installed on mine and it fits the Stanlet case ok. You have to be a little careful lowering it into the case to make sure the focuser does not scrape the end, but there is still an inch or two to play with with the FT installed.
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
[Re: MikeBOKC]
#5763498 - 03/29/13 01:08 AM
Home Depot just came out with their own brand, Husky, work box. It's internally larger than the Stanley box, will comfortably fit a C14, and is $10 cheaper. It is built as well, if not better than the Stanley. In fact, after I wrote this, I went down and bought another one for my mount.
Edited by CharlesW (03/31/13 12:54 AM)
FXDX
Reged: 03/29/13
Loc: Good old Europe
[Re: CharlesW]
#5765456 - 03/29/13 06:11 PM
hi folks,
i am pretty new here. my first suggestion straight forward in this thread starts with a question:
has anybody tried just a simple luggage case/trolley as a cpc case? i (cpc9.25 user) have not but can imagine that with a wooden board in the trolley´s back plus a plank in it´s bottom (plus some foam pieces of course)could be a cheap but fine scope transporter.
i will check some luggage cases on my next shopping tour...
enjoy this easter weekend! (temperature here in old europe is still around zero degrease centigrade - unbelivable!)
Holger
ps: we all live underneath the same sky - but not everybody has the same horizon...
pcctex
Reged: 04/13/10
[Re: FXDX]
#5771443 - 04/01/13 06:42 PM
Just bought a Husky 37" Mobile Job Box; have had the 50 gallon Stanley box for a while. Will do some careful measurements and report back.
------------------- CPC 1100 Edge 18" Obsession Classic Garrett 100mm binos Lunt 60HaPT60DS
pcctex
Reged: 04/13/10
[Re: pcctex]
#5778629 - 04/04/13 09:32 PM
Hat tip to Charles W. My CPC1100 Edge fits much better in the Husky box. Here are the dimensions I promised:
Stanley 50 gal box: 29" x 16-1/2" bottom 30-3/4" x 17-3/4" mid-point 31-1/2" x 19" top
Husky 37" Mobile Job Box: 31" x 16-1/4" bottom 33-3/4" x 18-1/4" mid-point 34" x 18-1/4" top
The most significant difference is the extra 3 inches of length at the mid-point....that's where our CPC scopes rest. The difference is caused by the handholds in the ends of the Stanley box....the handhold indentions run down the full height of the ends of the box. The Husky box ends are flat: no full depth hand indentions. Now I have no worries about going to a Feathertouch micro focuser. Actually, I had to scrounge around my stuff room for more pieces of foam.
Thanks again Charles.
Best of Luck to all.
iam1ru12
Reged: 02/25/06
Loc: Raleigh/Durham, NC
[Re: pcctex]
#5824118 - 04/26/13 11:00 AM
I picked up the Huskey case from Home Depot for $59.99. I'm now trying to get the foam. I'm post pics when I've sorted it all out.
