Telescope Specific Forums >> Meade LX
DUCE202
Reged: 01/03/12
scope hitting hard stop in both directions
      #5657343 - 02/01/13 11:14 PM
help!! my lx200 is hitting the hard stops in both directions after turning it 60 deg. in either direction ! what would cause this ? .. no one seems like they want to touch this one..help!!
Christopher EricksonModerator
Reged: 05/08/06
Loc: Waikoloa Village, Hawaii
Re: scope hitting hard stop in both directions new [Re: DUCE202]
      #5657485 - 02/02/13 01:16 AM
It sounds like something as come loose inside the base.
Time to carefully remove the bottom cover and look inside and see what you can figure out.
DUCE202
Reged: 01/03/12
Re: scope hitting hard stop in both directions new [Re: Christopher Erickson]
      #5658355 - 02/02/13 03:26 PM
hi chris, i removed the bottom cover . i cannot actually see where or why the scope is stoping .you can only see about half of the gear wheel and a plate that turns as you rotate it.
Reged: 05/08/06
      #5658506 - 02/02/13 04:57 PM
hi chris, i removed the bottom cover. i cannot actually see where or why the scope is stopping. you can only see about half of the gear wheel and a plate that turns as you rotate it.
It sure sounds like something has come loose in the hard-stop assembly.
I believe you have a number of astronomy clubs in your area and in the greater Philadelphia area, assuming that is where you are. Hopefully one of them has a member who is experienced with the internals of your scope who can come over and look at it.
If not then there is Meade Customer Service, as well as a couple of independent individuals that work on Meade scopes.
And you might be interested in joining the LX200GPS Yahoo group, which is narrowly-focused on your model of scope.
http://tech.groups.yahoo.com/group/LX200GPS
DUCE202
Reged: 01/03/12
      #5659167 - 02/03/13 12:04 AM
thanks for the info chris ! yes.. i`m in the greater philadelpha area...thanks again....
thesubwaypusher
Reged: 07/08/04
Loc: New York City
      #5694864 - 02/22/13 02:31 PM
Sounds like a software problem.
As Chris suggests, go into the yahoo site. Doc and his pals will have a solution.
Good luck, Chris
7 registered and 6 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
