Telescope Specific Forums >> Meade Computerized Telescopes
wakk0
Reged: 01/08/13
Just got a EXT125EC
      #5661488 - 02/04/13 10:42 AM
Finally I got EXT125 despite the reviews of the problems but then again there are others with it that had absolutely no problems with it. The seller was very thorough on how to take care of it and aligning it properly...he loves this scope but has too many. The motor sounds good..nothing out of the ordinary. It is pretty nose heavy tho. It only has a 26mm and 2x telenegative. I've read that Dr Clay prefers to use a 15mm with 2x barlow the most. I'll need to get a power supply and dew shield for sure. Its been cold and snowing here so I have not gotten my first light yet. In the meantime I can study the scope and its functions.
Any recommendation for eyepieces or accessories? I want to start out small and not just buy the lens kit because I might not even use them all. Thanks in advance
Christopher EricksonModerator
Reged: 05/08/06
Loc: Waikoloa Village, Hawaii
Re: Just got a EXT125EC new [Re: wakk0]
      #5661891 - 02/04/13 02:23 PM
Get a nice 24-32mm wide-angle eyepiece.
Something like this:
http://www.telescope.com/Accessories/Telescope-Eyepieces/24mm-Orion-Stratus-W...
Of course the TeleVue Panoptic 24 is the absolute best eyepiece of this kind to get but it is expensive.
http://www.astronomics.com/televue-24mm-panoptic-eyepiece_p3490.aspx
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: Christopher Erickson]
      #5662070 - 02/04/13 04:22 PM
Thanks Chris. Yeh I plan on getting a 32mm and 15mm but I read that you don't really have to buy expensive eyepieces for these no?
Reged: 05/08/06
      #5662380 - 02/04/13 07:53 PM
It does make a tremendous difference.
Put a $25 eyepiece in a $1,500 scope and get a $25 view.
If you have a local astronomy club, maybe someone there has a Televue Panoptic 24 or other premium, wide angle 1.25" eyepiece that you can try sometime at a club star party. The pleasing, panoramic views will definitely get you hooked.
Back when I had an ETX-125, the Pan-24 was my default eyepiece for just about everything.
Reged: 07/06/07
      #5662408 - 02/04/13 08:10 PM
But the nice thing about the long focal length ETX is that 25 dollar eyepieces often perform like 50 dollar ones.
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: rmollise]
      #5662803 - 02/05/13 01:15 AM
Would the Orion Sirius Highlight Plossl work with the EXT125? There's a local seller on that eyepiece.
*skyguy*
Reged: 12/31/08
Loc: Western New York
      #5662822 - 02/05/13 01:33 AM
.... I read that you don't really have to buy expensive eyepieces for these no?
Congratulations on the purchase of your ETX-125 ... I've owned one for a number of years and it's certainly a great scope with fine optics.
... and yes, you don't have to buy expensive eyepieces to enjoy the full potential of this scope. However, not expensive doesn't mean cheap, poor quality eyepieces. It generally refers to quality eyepieces with a simple lens design utilizing a minimum number of optical elements ... which translates into a lower purchase price than the expensive multi-element, wide/flat field design, exotic eyepieces.
For planetary observing ... which the Maksutov optical design excels in ... a simple, quality Plossl eyepiece will provide excellent high power views that in most cases will be superior to the more expensive eyepieces. In fact ... out of the dozen or so high power eyepieces I've tried in my ETX-125 ... the very best views of the moon and planets are with my old-style, smooth-side, Circle NJ TeleVue Plossls (10.5mm(181X) and 7.4mm(257X)) ... used price ~$50
Good Luck with your new scope ... it will provide a lifetime of enjoyable observing.
Reged: 07/06/07
      #5663000 - 02/05/13 07:51 AM
Yes, it will work fine.
wakk0
Reged: 01/08/13
      #5663148 - 02/05/13 09:30 AM
Kool.. great infos. Thanks guys =]
Peter B
Reged: 04/17/07
Loc: Parker, Colorado
      #5664480 - 02/05/13 11:18 PM
I find that having a red dot finder on my ETX105 is easier to use than the right angle finder. I also bought an extra hand controller just in case. The flexi-focus is a good accessory too.
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: Peter B]
      #5664989 - 02/06/13 10:59 AM
I was looking at some flexi focus but when I saw the instructions for it..I just went about my business. Looks complicated.
gastargazer01
Reged: 12/21/12
Loc: Flowery Branch GA
      #5669608 - 02/08/13 06:50 PM
Congrats
You are right to not get a Plossl eyepiece kit.
I bought that scope when it first came out in 1990something, I used that scope quite a bit.
The one eyepiece that I loved and used most was a 14mm Nagler, I know it might be out of your budget right now but it gave amazing view. It was a little heavy so the AC adapter was used.
Next would be a 40mm Plossl
Get a good barlow
I put a telrad on it and still use one on my C11
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: gastargazer01]
      #5669691 - 02/08/13 08:05 PM
Thanks. Haven't had first light yet
For the 14mm Nagler.. what did you use it to view mostly. Some people are happy with their 15mm and 32mm. I will read about the 14 Nagler. If there is just one eyepiece to get even an expensive one what would it be?
Edited by wakk0 (02/08/13 08:15 PM)
gastargazer01
Reged: 12/21/12
      #5669726 - 02/08/13 08:35 PM
Sorry correction it was the Type-4 12mm 82deg FOV. Loved it, Saturn, M objects or just star hopping. Everything is crisp and clear to the edge. Another plus is that it is a 1.25 and 2 inch so if you get a larger scope you can take advantage of the 2". Now I am using the Celestron Ultima series 8mm and 32mm 70deg FOV and I am pretty happy with the optics but they really don't compare to the Nagler. My next wide FOV will probably be in the Ethos series but at 600+ I am going to take a little time till I pull the trigger on that one. The Ethos would not work on your scope because of the weight of the eyepiece I think.
I not an expert on optics but that was my experience.
wakk0
Reged: 01/08/13
      #5669771 - 02/08/13 09:09 PM
I only have 3 eyepieces: 26mm that came with the scope, celestron 7mm ortho, and celestron 32mm highlight. I may get these next GSO 1.25" SuperView Eyepiece Set (15 & 20mm)
wakk0
Reged: 01/08/13
      #5675000 - 02/11/13 11:40 PM
Congrats
Get a good barlow
What did you mean by adding a AC adapter?
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5675506 - 02/12/13 10:06 AM
The Meade S5000 UWA 14mm is a good clone, at least to my Marty Feldman eyes, and I just saw one at a third the price of the Nagler.
Jerry-rigged
Reged: 01/30/12
Loc: Coastal Texas.
      #5676002 - 02/12/13 02:52 PM
Congrats
Get a good barlow
Guessing here but what I think he is saying - the weight of the eyepiece puts enough load motors that the batteries could not provide enough constant voltage. Motors straining = voltage dips = scope computer has issues. When he powered the scope via the AC adapter (instead of batteries), the voltage issues went away.
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: Geo.]
      #5676518 - 02/12/13 08:11 PM
Is there a significant difference between S5000 and S4000? I read somewhere (maybe here) that there was only slight difference and S4000 cost less. I may look into the 24mm SWA or UWA?
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: Jerry-rigged]
      #5676522 - 02/12/13 08:13 PM
Ahh ok Thanks
gastargazer01
Reged: 12/21/12
      #5676908 - 02/13/13 01:01 AM
Yes, Jerry is correct, mainly when slewing to an object.
wakk0
Reged: 01/08/13
      #5682741 - 02/16/13 01:53 AM
When I loosing the clutch and spin it freely..every half turns I can feel a bump. Have to open up the base and take a look.
wakk0
Reged: 01/08/13
      #5687999 - 02/18/13 10:48 PM
Quick question..to update autostar I will need #505 cable correct? anything else besides the cable?
Reged: 05/08/06
      #5688185 - 02/19/13 01:32 AM
#505 cable, probably a Serial-to-USB adapter (I'll suggest FTDI-based) and either Meade's ASU program or much-better yet, the free or paid version of StarGPS (Starpatch).
But do you really need to update the firmware for some reason right now?
Edited by Chris Erickson (02/19/13 02:01 AM)
wakk0
Reged: 01/08/13
      #5688512 - 02/19/13 09:10 AM
Chris: I have the old firmware right now (I think v2). And newest firmware is v4 I believe.
gastargazer01
Reged: 12/21/12
      #5693096 - 02/21/13 04:37 PM
If the scope is an older one I would recommend updating the firmware if you are having problems BUT only if you know what you are doing and make sure that you do not lose power during the update and all cables are safe from running pets or kids.
I had one of the first ETX-125s and the were some issues that required me to update the firmware but that was when they first came out and understandably had to flush out some bugs.
Good luck
cavefrog
Reged: 11/11/08
Loc: loozyanna
      #5697505 - 02/23/13 10:48 PM
if you do the firmware update, then reset, calibrate, and train motors. very important!
Theo
wakk0
Reged: 01/08/13
Re: Just got a EXT125EC new [Re: cavefrog]
      #5699211 - 02/25/13 01:15 AM
Thanks =]
0 registered and 11 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
