BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
T-Rex or Orion Atlas Pro AZ/EQ-G?
      #5662496 - 02/04/13 09:14 PM
I am coming down to the wire on deciding which Alt-Az mount I will end up buying and am looking for some advice. I really like the look of the T-Rex and it appears plenty capable of handling the OTAs I have in mind (TEC 140 and C925) and holding them steady. The main drawback for me is the lack of tracking capability for when I want to use high magnifications. While the slo-mo cables look more than adequate, I am increasingly having trouble with my hands - possibly early signs of arthritis; so I don't know if I could twist the knobs all night...and I don't want to nudge. If something like the JMI Track-and-Train were available for the T-Rex this decision would be a no brainer for me. And then the Orion Atlas Pro AZ/EQ-G arrived! 44lb payload capacity, GoTo and tracking, and convertible to a GEM if I want to...it looks like a really good alternative. Either mount would ride on one of my Losmandy HD tripods with an adapter from Optical Supports and should be rock steady. I currently own two EQ-6Ps and know they can handle the OTAs quite nicely, I imagine the new model would do the same, particularly on the HD tripod. The price difference between these two mounts is negligible and I would be willing to spend some bucks motorizing the T-Rex if an option presented itself. So what do you think about the two contenders - the good, the bad, and the ugly? My interest is visual observing with whichever mount I get, it just needs to handle my scopes, have no more than 1-2 second settle down times, and be easy on my hands. Thanks!
Clear Skies,
Brian
Reged: 07/06/07
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: BKBrown]
      #5663005 - 02/05/13 07:54 AM
If you need/want go-to and tracking, the choice would seem obvious...
Darren Bly
Reged: 07/24/06
Loc: Bakersfield, Ca
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: rmollise]
      #5663476 - 02/05/13 12:06 PM
One of these things is not like the other.....
Goodchild
Reged: 12/31/08
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Darren Bly]
      #5663578 - 02/05/13 01:19 PM
Although it would be nice to see more tracking alt-az mounts on the market. If you're a visual observer, it's hard to beat alt-az mounts for their simplicity, and tracking would be icing on the cake. The few that I am aware of are not my cup of tea as they seem to be too light duty or unreliable.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Goodchild]
      #5663992 - 02/05/13 05:21 PM
I have the Orion Sirius and the CGEM mounts and I bought a T-Rex a couple of months ago. The T-Rex is so easy to setup and carry around that I very seldom use the other mounts anymore. The T-Rex stays attached to the tripod and completely fits in a single bag along with the spreader and the Sky Commander. Even with everything in the bag it is relatively light weight. I can even carry the T-Rex in its bag and my C11 in its bag at the same time to my observing site without any real effort. Setup time is only a couple of minutes and then I am observing, which is a lot faster than the setup time for my other mounts. Don't even need vibration pads because there is no vibration. I highly recommend this mount.
The slow motion is silky smooth and you can turn the knobs with two fingers, but if you must have motors just hang on a while and they should be available.
I already had the JMI motors and controller on my Voyager mount so I decided to remove and test them on the T-Rex just by holding them in place and they work perfectly. So now I need to create the mounting plates, which are obviously different from the Voyager. I talked to JMI and they said they could create the mounting plates for me but I would have to send them my mount and that isn't happening. So instead I am creating the mounting plates myself and when I am done I am going to send one of them to JMI so they can create them for other people. Other than the correct mounting plate the coupler that goes between the motor shaft and the mount shaft will need to be slightly different from the voyager since the shaft on the T-Rex and the shaft on the Voyager are different sizes. I will be talking with them again shortly about getting the right coupler for the T-Rex.
      #5664132 - 02/05/13 06:33 PM
Have you had a look at the Desert Sky Astro DSV-3?
BKBrown
Reged: 08/23/09
      #5664317 - 02/05/13 09:06 PM
The options are limited Unk But the T-Rex at least has push-to and just looks soooo nice...
Clear Skies,
Brian
BKBrown
Reged: 08/23/09
      #5664321 - 02/05/13 09:09 PM
Thanks Darren and Royce...decisions,decisions, decisions
Clear Skies,
Brian
BKBrown
Reged: 08/23/09
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Lane]
      #5664325 - 02/05/13 09:11 PM
Thanks Lane, I will give this some serious consideration.
Clear Skies,
Brian
Terrance
Reged: 08/11/04
Loc: Near Portland Or.
      #5664395 - 02/05/13 09:57 PM
Is the Orion Atlas Pro AZ/EQ-G even available for actual order yet? I thought it was still aways down the road.
BKBrown
Reged: 08/23/09
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: jrbarnett]
      #5664409 - 02/05/13 10:07 PM
Hi Jim,
I had not considered this mount until you mentioned it. Curious, I went to their web site and found...a really nice piece of kit! Can I assume this is the one you picked up? The specs look good, have you had your TEC140 on board yet? My biggest concern would be the slo-motion controls - I would want to install longer ones since I doubt I could easily reach the knobs from behind my TEC. Definitely a mount worth considering, especially for the price
Clear Skies,
Brian
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5664571 - 02/06/13 01:53 AM Attachment (121 downloads)
Here is a pic of the TRex with the AT 152 on board.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5664586 - 02/06/13 02:15 AM
With the T-Rex you get two sets of slo-mo handles, the solid aluminum ones that stick out 6 inches and then the 22" flex cables that you see in the previous picture.
You also get the handle in the picture to move the scope around so you don't have to push on the telescope. Unfortunately the handle is grey not black. It does have a black foam grip at the end.
ADM dual saddle plate is standard.
The AT152 with rings, 2" diagonal, and the 31mm Nagler is about 28 lbs and the mount has no trouble with this. Vibration pads are not needed at all.
NorthBoundTrain
Reged: 11/23/11
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Terrance]
      #5664624 - 02/06/13 03:02 AM
Expected Ship Date: 02/16/2013
      #5665513 - 02/06/13 03:27 PM
Yep. I looked at the Half Hitch, T-Rex and DM-4/DM-6 options, and ended up ordering both a DSV-1 (quick look) and DSV-3 with encoders (higher capacity camping mount). I was able to buy both of those mounts, with multiple options, for less than what a DM-6 or T-Rex would have cost me. I'm a few weeks out from delivery (they are built to order), so I won't know how good or bad the mounts are until then, but as you said, when I looked at the website I was impressed with the design details; particularly the type and placement of the bearings.
My intended use is for bi-annual dark sky trips where dependency on large batteries carries with it a host of related problems (i.e., the need for solar recharging gear, and the space commanded by a big battery to name two). Ideally it will be able to carry the TEC 140 and/or a C9/C9.25/Mewlon 210.
I'll provide a thorough evaluation once I've received the mounts.
BKBrown
Reged: 08/23/09
      #5665593 - 02/06/13 04:18 PM
Thanks Jim, I'll look forward to your review
Clear Skies,
Brian
Goodchild
Reged: 12/31/08
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? [Re: BKBrown]
      #5665690 - 02/06/13 05:19 PM
Yesterday I purchased a Celestron CG-4 mount that a gentleman had replaced with a new DSV-3 mount. That DSV-3 is a thing of beauty and looks very solid. Much bigger than it looks in the pics. Very well machined and much thought given to detail. I'm afraid that I am going to have to purchase one down the road. The only flaw that I detected was that the bubble level is on top of the mount and therefore very difficult to read. And I wasn't able to test the mount, just look at it. But I really liked what I saw.
t.r.
Reged: 02/14/08
Loc: Upstate NY
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? [Re: Goodchild]
      #5681713 - 02/15/13 02:51 PM
Lane, great looking setup, but it looks like balance/tipping point could be an issue there. Is that the case? T-Rex'x are on sale right now 5% off for those who didn't know.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? [Re: t.r.]
      #5682292 - 02/15/13 08:28 PM
No problems at all. It is very stable even when turned so most of the OTA weight is positioned between the tripod legs.
My C11 and the AT 152 both work perfectly on this mount. To bad they did not make an optional counterweight bar for the other side, it could have easily been done and then you could put a C14 on this mount. It is built like a tank so I am sure it could handle the weight, but the balance would definitely be off. Anyway it achieves my goal of a totally quiet mount with slo-mo controls that can carry my biggest scopes and still have a very fast setup/takedown time. Being able to just fold it up and put in the carrying bag is a huge time saver.
I think the only bad thing I would say about this mount is that it cost to much.
Ira
Reged: 08/22/10
Loc: Mitzpe Ramon, Israel
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? [Re: Lane]
      #5683515 - 02/16/13 01:17 PM
I have had a T-Rex for about a year now. Very stable and capable mount. Given all of the outreach I do I mostly use an iOptron MiniTower Pro. The tracking and goto convenience are hard to beat when you're using a scope with total novices. Most people can't operate the slo-mo controls, or are too timid to try. Unfortunately, the MT Pro won't carry a very large load. I use a C8 on the primary side and an 80mm refractor on the secondary side. But it holds those well. I don't know if iOptron still sells the MT series still.
/Ira
18 registered and 42 anonymous users are browsing this forum.
