BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
T-Rex or Orion Atlas Pro AZ/EQ-G?
      #5662496 - 02/04/13 09:14 PM
I am coming down to the wire on deciding which Alt-Az mount I will end up buying and am looking for some advice. I really like the look of the T-Rex and it appears plenty capable of handling the OTAs I have in mind (TEC 140 and C925) and holding them steady. The main drawback for me is the lack of tracking capability for when I want to use high magnifications. While the slo-mo cables look more than adequate, I am increasingly having trouble with my hands - possibly early signs of arthritis; so I don't know if I could twist the knobs all night...and I don't want to nudge. If something like the JMI Track-and-Train were available for the T-Rex this decision would be a no brainer for me. And then the Orion Atlas Pro AZ/EQ-G arrived! 44lb payload capacity, GoTo and tracking, and convertible to a GEM if I want to...it looks like a really good alternative. Either mount would ride on one of my Losmandy HD tripods with an adapter from Optical Supports and should be rock steady. I currently own two EQ-6Ps and know they can handle the OTAs quite nicely, I imagine the new model would do the same, particularly on the HD tripod. The price difference between these two mounts is negligible and I would be willing to spend some bucks motorizing the T-Rex if an option presented itself. So what do you think about the two contenders - the good, the bad, and the ugly? My interest is visual observing with whichever mount I get, it just needs to handle my scopes, have no more than 1-2 second settle down times, and be easy on my hands. Thanks!
Clear Skies,
Brian
Reged: 07/06/07
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: BKBrown]
      #5663005 - 02/05/13 07:54 AM
If you need/want go-to and tracking, the choice would seem obvious...
Darren Bly
Reged: 07/24/06
Loc: Bakersfield, Ca
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: rmollise]
      #5663476 - 02/05/13 12:06 PM
One of these things is not like the other.....
Goodchild
Reged: 12/31/08
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Darren Bly]
      #5663578 - 02/05/13 01:19 PM
Although it would be nice to see more tracking alt-az mounts on the market. If you're a visual observer, it's hard to beat alt-az mounts for their simplicity, and tracking would be icing on the cake. The few that I am aware of are not my cup of tea as they seem to be too light duty or unreliable.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Goodchild]
      #5663992 - 02/05/13 05:21 PM
I have the Orion Sirius and the CGEM mounts and I bought a T-Rex a couple of months ago. The T-Rex is so easy to setup and carry around that I very seldom use the other mounts anymore. The T-Rex stays attached to the tripod and completely fits in a single bag along with the spreader and the Sky Commander. Even with everything in the bag it is relatively light weight. I can even carry the T-Rex in its bag and my C11 in its bag at the same time to my observing site without any real effort. Setup time is only a couple of minutes and then I am observing, which is a lot faster than the setup time for my other mounts. Don't even need vibration pads because there is no vibration. I highly recommend this mount.
The slow motion is silky smooth and you can turn the knobs with two fingers, but if you must have motors just hang on a while and they should be available.
I already had the JMI motors and controller on my Voyager mount so I decided to remove and test them on the T-Rex just by holding them in place and they work perfectly. So now I need to create the mounting plates, which are obviously different from the Voyager. I talked to JMI and they said they could create the mounting plates for me but I would have to send them my mount and that isn't happening. So instead I am creating the mounting plates myself and when I am done I am going to send one of them to JMI so they can create them for other people. Other than the correct mounting plate the coupler that goes between the motor shaft and the mount shaft will need to be slightly different from the voyager since the shaft on the T-Rex and the shaft on the Voyager are different sizes. I will be talking with them again shortly about getting the right coupler for the T-Rex.
      #5664132 - 02/05/13 06:33 PM
Have you had a look at the Desert Sky Astro DSV-3?
BKBrown
Reged: 08/23/09
      #5664317 - 02/05/13 09:06 PM
The options are limited Unk But the T-Rex at least has push-to and just looks soooo nice...
Clear Skies,
Brian
BKBrown
Reged: 08/23/09
      #5664321 - 02/05/13 09:09 PM
Thanks Darren and Royce...decisions,decisions, decisions
Clear Skies,
Brian
BKBrown
Reged: 08/23/09
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Lane]
      #5664325 - 02/05/13 09:11 PM
Thanks Lane, I will give this some serious consideration.
Clear Skies,
Brian
Terrance
Reged: 08/11/04
Loc: Near Portland Or.
      #5664395 - 02/05/13 09:57 PM
Is the Orion Atlas Pro AZ/EQ-G even available for actual order yet? I thought it was still aways down the road.
BKBrown
Reged: 08/23/09
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: jrbarnett]
      #5664409 - 02/05/13 10:07 PM
Hi Jim,
I had not considered this mount until you mentioned it. Curious, I went to their web site and found...a really nice piece of kit! Can I assume this is the one you picked up? The specs look good, have you had your TEC140 on board yet? My biggest concern would be the slo-motion controls - I would want to install longer ones since I doubt I could easily reach the knobs from behind my TEC. Definitely a mount worth considering, especially for the price
Clear Skies,
Brian
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5664571 - 02/06/13 01:53 AM Attachment (97 downloads)
Here is a pic of the TRex with the AT 152 on board.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5664586 - 02/06/13 02:15 AM
With the T-Rex you get two sets of slo-mo handles, the solid aluminum ones that stick out 6 inches and then the 22" flex cables that you see in the previous picture.
You also get the handle in the picture to move the scope around so you don't have to push on the telescope. Unfortunately the handle is grey not black. It does have a black foam grip at the end.
ADM dual saddle plate is standard.
The AT152 with rings, 2" diagonal, and the 31mm Nagler is about 28 lbs and the mount has no trouble with this. Vibration pads are not needed at all.
NorthBoundTrain
Reged: 11/23/11
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Terrance]
      #5664624 - 02/06/13 03:02 AM
Expected Ship Date: 02/16/2013
      #5665513 - 02/06/13 03:27 PM
Yep. I looked at the Half Hitch, T-Rex and DM-4/DM-6 options, and ended up ordering both a DSV-1 (quick look) and DSV-3 with encoders (higher capacity camping mount). I was able to buy both of those mounts, with multiple options, for less than what a DM-6 or T-Rex would have cost me. I'm a few weeks out from delivery (they are built to order), so I won't know how good or bad the mounts are until then, but as you said, when I looked at the website I was impressed with the design details; particularly the type and placement of the bearings.
My intended use is for bi-annual dark sky trips where dependency on large batteries carries with it a host of related problems (i.e., the need for solar recharging gear, and the space commanded by a big battery to name two). Ideally it will be able to carry the TEC 140 and/or a C9/C9.25/Mewlon 210.
I'll provide a thorough evaluation once I've received the mounts.
BKBrown
Reged: 08/23/09
      #5665593 - 02/06/13 04:18 PM
Thanks Jim, I'll look forward to your review
Clear Skies,
Brian
Goodchild
Reged: 12/31/08
      #5665690 - 02/06/13 05:19 PM
Yesterday I purchased a Celestron CG-4 mount that a gentleman had replaced with a new DSV-3 mount. That DSV-3 is a thing of beauty and looks very solid. Much bigger than it looks in the pics. Very well machined and much thought given to detail. I'm afraid that I am going to have to purchase one down the road. The only flaw that I detected was that the bubble level is on top of the mount and therefore very difficult to read. And I wasn't able to test the mount, just look at it. But I really liked what I saw.
t.r.
Reged: 02/14/08
Loc: Upstate NY
      #5681713 - 02/15/13 02:51 PM
Lane, great looking setup, but it looks like balance/tipping point could be an issue there. Is that the case? T-Rex'x are on sale right now 5% off for those who didn't know.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: t.r.]
      #5682292 - 02/15/13 08:28 PM
No problems at all. It is very stable even when turned so most of the OTA weight is positioned between the tripod legs.
My C11 and the AT 152 both work perfectly on this mount. To bad they did not make an optional counterweight bar for the other side, it could have easily been done and then you could put a C14 on this mount. It is built like a tank so I am sure it could handle the weight, but the balance would definitely be off. Anyway it achieves my goal of a totally quiet mount with slo-mo controls that can carry my biggest scopes and still have a very fast setup/takedown time. Being able to just fold it up and put in the carrying bag is a huge time saver.
I think the only bad thing I would say about this mount is that it cost to much.
Ira
Reged: 08/22/10
Loc: Mitzpe Ramon, Israel
      #5683515 - 02/16/13 01:17 PM
I have had a T-Rex for about a year now. Very stable and capable mount. Given all of the outreach I do I mostly use an iOptron MiniTower Pro. The tracking and goto convenience are hard to beat when you're using a scope with total novices. Most people can't operate the slo-mo controls, or are too timid to try. Unfortunately, the MT Pro won't carry a very large load. I use a C8 on the primary side and an 80mm refractor on the secondary side. But it holds those well. I don't know if iOptron still sells the MT series still.
/Ira
BKBrown
Reged: 08/23/09
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: NorthBoundTrain]
      #5685016 - 02/17/13 11:34 AM
FYI...now amended on the Orion web site to 05/02/2013 So what's with these guys, are we about to relive the Meade mount fiasco again? My attention has just focused down on the T-Rex with an honest hard look at the the DSV-3 as an alternative. I am inclining toward the T-Rex due to some recent experiments on motor control done by a fellow CNer...I really like the idea of a powered option. That with Sky Commander would pretty much fulfill my basic requirements.
Clear Skies,
Brian
10gauge
Reged: 10/31/10
Loc: Boston
      #5685872 - 02/17/13 08:10 PM
Hello Brian! People who already own the Skywatcher version of the EQ-6 Pro AZ seem so preoccupied with the GEM mode that they aren't posting anything useful for us in the alt-az mode. I wish I knew better how the Pro AZ feels in alt-az mode compared to the top dedicated mounts? I agree, Orion has pushed the date up 3 times. I won't be surprised if they push it up further. I knew they would be overwhelmed with the pre-orders, especially with the promising initial reports within the past month.
I've gone full circle with GEM and Alt-Az mounts during the past year while I was waiting for my TEC 140 to be built - Atlas, G11, EQ-6 AZ, IEQ45, DM-6, T-Rex, Unistar Deluxe, DSV-3, Orion AZ, Nova Hitch, ES, M150, etc.
Assessing all the pros and cons, and based on smoothness, weight capacity, slow motion, quick slew, push to, encoder adaptation, durability, I came to the conclusion that the T-Rex would be the ideal mount for a TEC 140 and an eventual C11. In your case, since you already have an Atlas GEM, a T-Rex would be ideal.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: 10gauge]
      #5687059 - 02/18/13 02:46 PM
In regard to the T-Rex motors:
I talked with JMI and they don't feel that enough people will buy the T-Rex to make it worth their while to create a specific motor solution for it.
You can still buy the train-n-track and you can order it with the correct motor shaft connectors for the T-Rex, but you will have to get a little sheet of aluminum from a hardware store to make your own mounting brackets. They are really simple to make, just a pair of sheet metal cutters (tin snips) and a power drill is all you need. Maybe some black paint to make it look good. I am going to paint mine with black hammer textured paint.
I already have the JMI motors and I ordered the motor shaft connectors last Thursday. Just waiting for those to arrive to put the whole thing together.
Those little motor shaft connectors cost me $12.50 each. Seemed a bit pricey to me.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Ira]
      #5687077 - 02/18/13 02:53 PM
You can probably motorize the DSV-3 as well. We need to get someone to shoot a detail shot of the shaft area for both AZ and ALT to see where a motor mount plate could be attached. On the T-Rex there are 4 bolts that hold the slo-mo worm gear cover in place, I plan to attach the motor mounting plate to two of those bolts.
Ira
Reged: 08/22/10
      #5687583 - 02/18/13 07:09 PM
Why not ask Barry, who makes the T-Rex, if he will make the mount for the JMI motors? He would have more interest in having that option available than JMI.
/Ira
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5688804 - 02/19/13 12:27 PM
/Ira
I will be looking into this again. Besides the motor mount, the real trick is getting a motor than can run direct drive rather than having to implement a belt or gear drive (which simply complicates things). That requires getting a fair amount of torque from a fairly small motor.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: EFT]
      #5689128 - 02/19/13 03:45 PM
The JMI motors work great without belts or gears, but they are not fast like motors on a CGEM. They are intented only to replace the slo-mo part of the scope. So you would still manually push the mount to a constellation and then use the JMI motors to scan around in that constellation, which I think is what everyone wants to do with these motors. Motors like this are very very quiet, someone standing 20 feet away could not hear these motors at all.
I will have my homemade/JMI solution finished soon and will post pictures. JMI did ask me to send them pictures and dimensions so they might be planning to go ahead and make the mount brackets. It just depends on how many people email them and say they are interested in putting a track-n-train on the T-Rex.
BKBrown
Reged: 08/23/09
      #5691687 - 02/20/13 08:21 PM
Thanks 10gauge and Lane So I went ahead and ordered the T-Rex...now to concentrate on the motorization. Take it away Ed!
Clear Skies,
Brian
BKBrown
Reged: 08/23/09
      #5691716 - 02/20/13 08:34 PM Attachment (30 downloads)
So now on to the next part. This pic shows the Manny Miles mod for the Porta II that allows the OTA to sit more "naturally" in the saddle. You out there Manny? How about doing this for the T-Rex as a potential project?
Clear Skies,
Brian
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5691843 - 02/20/13 10:10 PM
Well JMI got some emails from T-Rex owners and are now more interested in the mount. They might make the motor mounts after all. I am going to help them out by supplying them one of my mounts as a guide. We will just have to wait and see if they follow through.
10gauge
Reged: 10/31/10
Loc: Boston
      #5691979 - 02/20/13 11:27 PM
Congratulations Brian on the T-Rex! Looking forward to your next AP photos...
BTW, Orion heard you - they moved up the date by 2 wks to 4/23/2013.
George
Edited by 10gauge (02/20/13 11:32 PM)
BKBrown
Reged: 08/23/09
      #5693493 - 02/21/13 08:23 PM
That's cool Lane, I sure hope they do come through...if not we'll figure out a solution.
Clear Skies
Brian
BKBrown
Reged: 08/23/09
      #5693503 - 02/21/13 08:29 PM
George
Thanks George The T-Rex looks awesome and I already have a few ideas for modding it. I'd like to fill my waiting time imaging but winter seems to have finally caught up to us in Virginia and the seeing is trash. I think the jet stream is parked over my house, and they promise us a "wintery mix" here tomorrow
That's funny about Orion; wish we really did have that kind of influence...
Clear Skies,
Brian
thesubwaypusher
Reged: 07/08/04
Loc: New York City
      #5698536 - 02/24/13 04:28 PM
I am not sure I am understanding why you guys are interested in motorizing the T-Rex. The whole point of having it to begin with is to enjoy the simplicity, as you say Lane, it just pops out and back into the bag almost fully assembled. If you add motors, you'll have to carry a battery. Why not just get a regular eq mount then?
The T-Rex is a fantastic mount. It is VERY fun to use. I sold mine a while back, but am contemplating another because I miss playing with it. It handled my Edge HD 11 with ease. The manual workings of it make you one with the mount. Adding motors would destroy that feeling, and complicate things. The Sky Commander is fun and more than adequate for an altaz mount.
Good luck, Chris
thesubwaypusher
Reged: 07/08/04
Loc: New York City
      #5698544 - 02/24/13 04:31 PM
Brian, here is all you need to know about the Rex...
http://www.cloudynights.com/item.php?item_id=2699
wrz0170
Reged: 03/08/12
Loc: Bethlehem, Pa
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: thesubwaypusher]
      #5698811 - 02/24/13 07:26 PM
This review was a huge help in making my decision in favor of the T-Rex. I don't have any regrets. As mentioned before, it is a joy to use. Even the wife remarks how easy the controls are. It handles my SV80ST as well as my C9.25 Edge.
BKBrown
Reged: 08/23/09
      #5698821 - 02/24/13 07:37 PM
Good luck, Chris
Hi Chris,
I understand where you are coming from but different folks have different requirements. Adding a battery to the gear is nothing compared to what I have to do when taking a complete Atlas to the field...the T-Rex will be in business just as quick with the motors as without. I often do a lot of high power observing during a session and that is why I want slow motion control, but I have increasing arthritis issues with my hands. Turning knobs can become painful after a while, not so pushing a button and that's why I want the motors. I will still be able to set up with minimal effort, slew quickly, find my targets with Sky Commander, AND observe at high power for long periods if I want to; so there is a method to the madness. I'm not afraid to mod a piece of gear if it will make it more convenient and efficient for me; the T-Rex will be no exception. And as you said, it handled your C11 Edge with no problem and that is one of the OTAs I have as well, also a C925 and a TEC 140 - and the T-Rex should be just the visual observing ticket for all of them
Clear Skies,
Brian
BKBrown
Reged: 08/23/09
      #5698823 - 02/24/13 07:38 PM
Thanks Chris!
Clear Skies,
Brian
thesubwaypusher
Reged: 07/08/04
Loc: New York City
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: wrz0170]
      #5700135 - 02/25/13 04:06 PM
This makes me very happy. Thanks dude!
thesubwaypusher
Reged: 07/08/04
Loc: New York City
      #5700160 - 02/25/13 04:18 PM
Oh, an Atlas and counterweights. Okay, now I understand your comparison better Brian. Good luck with the motors and please post pictures as I and many others would be curious as to how they work.
You are going to love the Rex, and Ed and Barry provide excellent support. Just make sure you get the right color!
Good luck with your project. Actually, it sounds like fun!
Thanks, Chris
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5700466 - 02/25/13 07:40 PM
Not talking about loud goto motors here, just simple slo motion motors, very quiet and powered by a single 9 volt battery in the hand controller. My main goal is a super quiet mount for use at campsites, but capable of handling a big scope and easy to setup.
Also these motors are not fast, you still push the mount to the general location you want to view and then use the motors. I have not timed it but it would probably take somewhere around 10 seconds to move the scope from Rigel to Sirius.
Edited by Lane (02/26/13 04:50 PM)
thesubwaypusher
Reged: 07/08/04
Loc: New York City
      #5701705 - 02/26/13 01:42 PM
Understood. I would like to see your finished product!
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5702057 - 02/26/13 04:50 PM
You will
10gauge
Reged: 10/31/10
Loc: Boston
      #5702558 - 02/26/13 09:52 PM
What would be an upgrade saddle to the Orion Pro AZ/EQ? Is the ADM DSAD-EQ6 Losmandy saddle ideal?
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5702729 - 02/26/13 11:48 PM
I'm not sure if anyone has provided any measurements on the AZ/EQ yet to know if the ADM saddle will fit on one or either end of the mount yet.
BKBrown
Reged: 08/23/09
      #5703018 - 02/27/13 08:02 AM
Good point. I also wonder if including encoders has impacted the ability to mod the Atlas Pro AZ/EQ-G...
Clear Skies, Brian
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5703085 - 02/27/13 09:02 AM
Clear Skies, Brian
What mod would you be thinking about?
BKBrown
Reged: 08/23/09
      #5703930 - 02/27/13 05:49 PM
Hi Ed,
I'm a fan of the ADM dual saddles for instance...would they be doable? How about putting in Telescope Drive Master (TDM)?
Clear Skies,
Brian
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5703987 - 02/27/13 06:19 PM
I can tell you for certain the ADM can make a saddle and drill custom holes to your specifications. I ordered a saddle from ADM a few years ago and sent them a detailed diagram with dimensions for the custom holes I wanted drilled and there was no extra charge either.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5704053 - 02/27/13 07:01 PM
Hi Ed,
Clear Skies,
Brian
I'm sure that ADM will come up with something. I don't know about the TDM but I would think that the connection would be similar to the Atlas since the same polar scope is in use.
10gauge
Reged: 10/31/10
Loc: Boston
      #5704219 - 02/27/13 08:35 PM
Ed or Brian, I keep forgetting to ask... How much does the T-Rex mount weigh without the tripod?
Brian, which color did you opt for on the T-Rex? I can't decide which color to order for my new TEC 140.
Oh and BTW, Orion has the Pro AZ EQ-6 "In Stock."
George
BKBrown
Reged: 08/23/09
      #5704246 - 02/27/13 08:50 PM
George
Hi George,
I don't recollect the weight off the top of my head, maybe Ed can help there. I went with the black T-Rex because I plan to put it on a black Losmandy HD tripod. Wow, funny how the Orion delivery date changed so quickly, I wonder what happened...
Clear Skies,
Brian
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5704309 - 02/27/13 09:28 PM
George
The head is about 22 pounds.
10gauge
Reged: 10/31/10
Loc: Boston
      #5704489 - 02/27/13 11:01 PM
Thank you Brian and Ed!
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5709451 - 03/02/13 07:51 PM
Ok, I finished the bracket and tested it on the TRex, works perfect. I sent pictures and specifications to JMI. I told them I would send them the bracket and one sample of the replacement bolts if they want it. So now just waiting to hear back from them.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5709555 - 03/02/13 08:58 PM
Pictures!
Ira
Reged: 08/22/10
      #5709584 - 03/02/13 09:16 PM
Count me in for my T-Rex.
/Ira
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5709794 - 03/03/13 12:32 AM
I will post some pictures in a few days when I get back to my computer. I just have my iPad with me right now.
BKBrown
Reged: 08/23/09
      #5710542 - 03/03/13 12:25 PM
Sounds great Lane, I look forward to seeing the pix
Clear Skies,
Brian
SteveE
Reged: 12/05/07
Loc: Belle Louisiane
      #5715548 - 03/05/13 10:48 PM
A little late maybe but I wanted to put in a word about Desert Sky Astro's DSV-3.
I've owned one for a few months and have used it extensively in many different configurations: TEC 140; C9.25; Edge 1100; TEC 140/C9.25 dual mount; C9.25/Tak TSA 102 dual mount. In each case, using the Quick Balance System that is standard with the mount, performance was ultra smooth from horizon to zenith.
You will need to read the instructions but you will have no problems assembling and balancing. I did a dry run during the day and this one rehearsal was all I needed. I can set it up at night with little effort.
Motions are effortless. I can push the mount in altitude or azimuth with one finger. If this freedom is too sensitive for you you can apply some friction with a simple turn of a clutch lever. At high magnifications I am able to keep the object in the FOV as if the mount knows where to go.
Changing eyepieces may require you to lock the alt axis but it works. You will need to be careful not to nudge the mount in azimuth while doing so. Of course, if you do nudge it you will only need to move the mount in azimuth to find the object again. Once you lock the alt axis and place the heavier/lighter eyepiece you move the counterweight on the QBS to a proper spot, unlock the alt axis and resume viewing. You will need an evening perhaps to get used to it but it's easy and becomes intuitive after a short session. I prefer this counter-weighted system to simply adjusting tension as I have done on other manual alt/az mounts. Yes, you need to learn it but you will learn it and in short time. The reward is an invisible mount capable of considerable capacity either in single or dual scope mode.
The Quick Balance system can be mounted to a top rail on the rings of one of the scopes while in dual mode. Operation is just as simple and performance is just as impeccable.
Hope this is not more than you needed to hear!
Steve
BKBrown
Reged: 08/23/09
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: SteveE]
      #5715649 - 03/05/13 11:58 PM
Thanks Steve! The DSV-3 looks great and I might consider a lighter version in the future for my grab-and-go, but my quest took an unanticipated turn last week. The folks at Hands On Optics e-mailed to tell me that they would (unexpectedly in view of the earlier Orion announcement) be getting an Atlas Pro AZ/EQ-G by the weekend. So, despite having a T-Rex on order (due here on Friday) I ended up trading in my field Atlas for the new model. Soon I should be able to do some comparison testing of these two mounts which I will share here. Thanks again for the info
Clear Skies,
Brian
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5715745 - 03/06/13 01:48 AM Attachment (25 downloads)
Here is a picture I took of my homemade T-Rex motor mount bracket with a JMI motor attached. I replaced the M5-30mm bolts that hold the bracket to the mount with M5-35mm bolts. I also use several washers to keep the bracket from scratching the mount. The mount bracket contains slots not holes so to remove it or install it only takes about 1 minute. Just loosen the shaft collar with a hex wrench then loosen the two bolts on top about one full turn each and it slides off or on easily. I tested it and it will fit into the carrying case without removing the motors.
BKBrown
Reged: 08/23/09
      #5716428 - 03/06/13 01:42 PM
Looks like a very straightforward Mk I mounting plate Lane, shouldn't be too hard for folks to get their hands around the concept. Thanks for the pix
Clear Skies,
Brian
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5716692 - 03/06/13 03:44 PM
I sent this picture and several others to JMI along with the exact dimensions they will need. They might make the mounting plates for us, but I have not heard back from them yet. I will let you know if and when I do.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5726617 - 03/11/13 07:03 PM
I know a couple of you are interested so I thought I would post an update:
I have had no response to the emails and pictures I sent to JMI early last week, so I am not sure it they are just too busy right now or if they changed their minds again and aren't interested in making the motor mounts for the T-Rex.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5726814 - 03/11/13 08:38 PM
They may be waiting for me at this point. I'm hoping to get a TNT in here soon and see what we can come up with for a retrofit and/or a system for new mounts.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5727147 - 03/11/13 11:40 PM
That sounds great. Maybe you can come up with something much better than mine.
I personally wish telescope makers would think about these things in advance. If the worm gear housing just had some kind of short post sticking out next to the shaft. Then the motor mounting could be nothing but a small adapter around the front of the motor shaft with a socket for that post. Then you could push on and pull off the motor and only have to tighten one shaft screw in the process. The post in socket would keep the motor from rotating and that is all the mount needs to do because the shaft collar holds the motor in place. It would look much cleaner and make switching from the motor to the handles a lot easier.
Kunama
Reged: 10/22/12
Loc: Australia
      #5749101 - 03/22/13 06:24 AM
Any news on the JMI motor kits, will 'Train & Track' come to fruition?
I just ordered a T-Rex today which will carry my Tak TSA120/SV F50W2 combo with Argo Navis DTC to come a little later.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
Re: T-Rex or Orion Atlas Pro AZ/EQ-G? new [Re: Kunama]
      #5749427 - 03/22/13 10:40 AM
I have the TNT system now and will try to get to designing an appropriate attaching system as soon as possible.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5749747 - 03/22/13 01:39 PM
Thanks Ed, it would be nice if you can make it more compact than mine so it isn't as much of an eyesore on a beautiful mount.
The key thing in my mind is to make it easy to attach and remove. It would be nice if we could have some small socket plate that was permanently mounted to the bolts on the worm housing and then the motor mount would just click into the socket. This would also solve the problem of the motor being in the way of the saddle bolt, because you could mount the scope first and then attach the motor. That would also mean the motor could attach closer to the mount since it does not matter if it gets in the way of the saddle bolt. I only mounted it at the end of that shaft adapter (that comes with the flexicable) to keep the motor out of the way of the saddle bolt.
Whatever you come up with I will be buying it since I am sure it will look better than mine.
Thanks for taking an interest in this project.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5749826 - 03/22/13 02:16 PM
I'm going to do my best to see what we can do to make it look good. That will probably be the toughest part.
BKBrown
Reged: 08/23/09
      #5753447 - 03/24/13 09:29 AM Attachment (4 downloads)
Thanks for the effort Ed (and Lane!), I think it is worthwhile to take the time to make the mounting brackets blend in with the rest of the mount...it's a beautiful piece of gear. The slow motion controls are incredibly smooth and easy to use, but I think I will still need push button control for long hours in the cold so you can count me in for a set whenever they are ready.
Clear Skies,
Brian
31 registered and 37 anonymous users are browsing this forum.
