socialoutkast
Reged: 04/28/09
Loc: Pennsburg, Pa
2012 DA14 script for Stellarium?
      #5663022 - 02/05/13 08:08 AM
Does anyone out there have a script to add 2012 DA14 to Stellarium? I know it will be a fast mover and want to get a good idea where to point the binoculars on 2/15
BSJ
Reged: 12/22/08
Loc: Grand Isle, VT
Re: 2012 DA14 script for Stellarium? new [Re: socialoutkast]
      #5663575 - 02/05/13 01:15 PM
Press F2, to get into the “Configuration window”. Click on the Plugins Tab.
Click “Solar System Editor” and then the configure button.
Then click the “Solar System” tab.
Once there click the “Import orbital elements in MPC format…” button.
Make sure “asteroids” is selected. Click the “Select bookmark…” button. Pick the NEA bookmark.
Then click “Get orbital elements.” Search for 2012 DA14 if it’s not near the top. Check mark it and click add objects.
Close all the config pop-ups.
Close and re-start Stellarium just to make sure the data is fully/correctly loaded.
Should be be loaded now.
btschumy
Vendor - Southern Stars
Reged: 04/13/04
Loc: Longmont, CO, USA
Re: 2012 DA14 script for Stellarium? new [Re: BSJ]
      #5665219 - 02/06/13 01:06 PM
I'm not totally sure how Stellarium computes solar system object positions, but my guess is it is based on a simple Keplarian orbit based upon the latest orbital elements. This will *not* provide very useful information for a near-Earth flyby. Most planetarium programs suffer from this limitation.
The Earth profoundly perturbs the orbit as the object gets close and any predictions will be way off. You really need to compute the orbit by numerically integrating the differential equations, solving the n-body problem.
The solution is to download an ephemeris from JPL that is actually based upon such computations. Only then will you get an accurate predictions.
Note: getting the latest orbital elements a few hours before flyby will help. Then the path may be fairly accurate, but the timing will generally be off.
socialoutkast
Reged: 04/28/09
Loc: Pennsburg, Pa
Re: 2012 DA14 script for Stellarium? new [Re: btschumy]
      #5668708 - 02/08/13 10:58 AM
Thanks It worked. I was not aware of this feature,previously we would get scripts for these from the net or these forums.
BSJ
Reged: 12/22/08
Loc: Grand Isle, VT
      #5668727 - 02/08/13 11:05 AM
Yep, way better than the old way.
Works for Comets too...
Edward E
Reged: 03/26/06
Loc: Tucson, Arizona
      #5674213 - 02/11/13 03:14 PM
Cool.
Edward E
Reged: 03/26/06
      #5674218 - 02/11/13 03:17 PM
My brain...it's melting, melting! O what a world, what a world.................
Edited by Edward E (02/11/13 03:18 PM)
3 registered and 12 anonymous users are browsing this forum.
Moderator:  Bowmoreman, richard7
