Ricky
Reged: 09/09/03
Loc: Nor Cal
Source for 1.5mm thumb set screws?
      #5663778 - 02/05/13 03:27 PM
Hi All,
Im looking to replace the set screws that allow one to adjust the polar alignment reticule on the Sirius Heq5 mount with equivalent thumb screws instead. Ive found out that the screws are 1.5mm...is that pitch? Im a newbie on screw specs. Does someone have info. on this and/or know where to find such replacement screws?
don clement
Vendor (Clement Focuser)
Reged: 02/02/11
Loc: Running Springs, California
Re: Source for 1.5mm thumb set screws? new [Re: Ricky]
      #5663796 - 02/05/13 03:38 PM
This should help. http://www.wisc-online.com/objects/MTL5802/mlt5802.htm
Don Clement
Pinbout
Reged: 02/22/10
Loc: nj
      #5663826 - 02/05/13 03:56 PM
I used socket head allen caps screws from Home Depot, the head is big enough to grab with my fingers so I didn't press fit a knob on it.
Ricky
Reged: 09/09/03
Loc: Nor Cal
Re: Source for 1.5mm thumb set screws? new [Re: Pinbout]
      #5663853 - 02/05/13 04:06 PM
@Don...thanks for the link!
@Danny...did u do this replacement on your Sirius mount? If so, could you link the specific item at depot? Thanks much!
Pinbout
Reged: 02/22/10
Loc: nj
      #5663876 - 02/05/13 04:20 PM
a cg5, it had a standar metric thread just took the set screw in and matched the thread and body dia.
scopestuff sell replacements for $16
Ricky
Reged: 09/09/03
Loc: Nor Cal
      #5663883 - 02/05/13 04:23 PM
Thanks Danny! Ill check depot out.
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5664893 - 02/06/13 09:55 AM
Doubt they're 1.5mm. Possibly 1.6, but I'd think 2.5 or 3 are more likely. At these sizes there are no thread pitch options. Find someone with a tap set to get a sure match. A good Ace will have a selection of metric fastners. I go to Richard Russo's hometown for the best selection in my area. Look for an ACE in an industrial area.
Gordon Rayner
Reged: 03/24/07
Re: Source for 1.5mm thumb set screws? new [Re: Geo.]
      #5665887 - 02/06/13 07:25 PM
Shear-Loc have press-on heads for some metric size socket capscrews . www.shear-loc.com 1-800-775-5668
They have a competitor in Flippin, Arkansas
www.microplastics.com
You could drill and tap some Delrin, nylon, PVC, aluminum, acrylic, Lexan, square pieces, and then lock with a nut, if necessary.
For thumbnuts, I have pressed square Delrin onto steel nuts. Drill the hole ( shallow, not a through-hole) of a size which just clears the sides of a hex nut. The hex corners cut into the Delrin, to lock the nut. Chamfering the edge of the hole makes entry smoother.
A thru hole to clear the screw body can be made before or after the nut is installed. If desired, make that hole the tap size, and start the tap in the threads of the installed nut. A tightly fitted nut will not usually tend to be pushed out during the beginning of tapping of the plastic . Or, clamp the nut with a plate or wood block with hole, to keep the nut from being screwed upward out of its hole during the start of tapping.
Edited by Gordon Rayner (02/06/13 09:10 PM)
Ricky
Reged: 09/09/03
Loc: Nor Cal
Re: Source for 1.5mm thumb set screws? new [Re: Gordon Rayner]
      #5665902 - 02/06/13 07:35 PM
Thanks for all of the suggestions!
don clement
Reged: 02/02/11
      #5666005 - 02/06/13 09:03 PM
Plus 1 on Shear-Loc press-on thumbscrews. I have had a Shear-Loc press-on assortment set (size #4 to 5/16) for over 30 years and has passed the test of time. The nice thing is that Shear-Loc works on all types of SCHCs including nylon SHCSs that work as a non-marring set screw. Also if the metric size is close in diameter and pitch they may be interchangeable. For example an inch size screw UNF 10-32 fits a threaded metric M5-0.8 screw hole pretty well since the OD of the #10 screw is 0.190" and the OD of an M5 screw is 0.197" also the 0.8mm pitch is very close to 32 threads per inch. A quick pass with a 10-32 tap will fix any discontinuity.
Don Clement
Gordon Rayner
Reged: 03/24/07
Re: Source for 1.5mm thumb set screws? new [Re: don clement]
      #5666041 - 02/06/13 09:23 PM
I used 10-32 in the several M5-0.8 holes for bearing attachment on the Fuji 25 x 150 binocular body , first model (with trunnions), to install a a headrest support plate over the bearing flanges. There was never any problem, on many specimens, some of which are still in service.
This was because stainless socket cap screws M5-0.8 , of the required length, were not available ,or special order import $$$.
Such a substitution would not be appropriate for highly stressed automotive or aircraft application.
don clement
Reged: 02/02/11
      #5666053 - 02/06/13 09:29 PM
Yep. Don't intend to drive or fly an import telescope mount. ;-)
Don
A song of great social and poetical import."
http://www.youtube.com/watch?v=i-4AheUl6ls
Although in the original ATM book series there is mention of a TN that was killed when his under built mount collapsed on him.
Pinbout
Reged: 02/22/10
Loc: nj
      #5666310 - 02/07/13 12:23 AM
I'd rather reference Husker Du - Wheels
[didn't link the youtube because of content.]
12 registered and 20 anonymous users are browsing this forum.
