donjoy
Reged: 01/26/10
Ioptron tripod new
      #5636743 - 01/22/13 11:58 AM
HI; I have a Ioptron telescope which works well the only problem I have is the hight of the tripod.It isn't high enough for observing unless I squat way down to look.Any body have any ideas? thanks Don
Agatha
Reged: 06/04/12
Loc: Coulee Region, Wisconsin
Re: Ioptron tripod new [Re: donjoy]
      #5636768 - 01/22/13 12:14 PM
Don,
I assume you are viewing while standing. Have you used or considered a viewing chair? Much more comfortable than squatting.
Best, Linda B.
donjoy
Reged: 01/26/10
Re: Ioptron tripod new [Re: Agatha]
      #5636779 - 01/22/13 12:21 PM
HI; thank you for writing.The tripod seems to be in a kind of nuetral zone.It's just like in a middle spot that is not a comfort zone and seems to need about 6" higher.the legs are a little unstable at full length.I wonder if anyone else has replaced the tripod with another one that fits the scope.
frebieAdministrator
Chief assistant to the assistant chief
Reged: 04/29/08
Loc: Neither here nor there.
      #5637119 - 01/22/13 03:08 PM
iOptron has a mini-pier that adds 8" to the height of most of their tripods. Here's a link to the iOptron webpage:
http://www.ioptron.com/index.cfm?select=productdetails&phid=cf1ba874-4bdc...
donjoy
Reged: 01/26/10
Re: Ioptron tripod new [Re: frebie]
      #5638460 - 01/23/13 09:08 AM
Thank you frebie.I'll look into that.
Spaced
Reged: 03/01/05
Loc: Tacoma, Washington, USA
      #5639291 - 01/23/13 05:31 PM
Another low-tech solution: My woodworking wife made me some blocks out of 4" X 4"s, stabilized with little lateral 1 X 2" braces that extend a couple of inches off to the sides, to place under each of my tripod legs to raise the whole thing about 5".
donjoy
Reged: 01/26/10
Re: Ioptron tripod new [Re: Spaced]
      #5641069 - 01/24/13 05:06 PM
Thanks for the light.I do woodworking and i've thought of trying that so i'll check that out.I think i'm going to look for a sturdier tripod though I saw a tripod for a celestron but I can't be sure if it will fit the cube.It's the kind where the arm fits in like a semicircle.
donjoy
Reged: 01/26/10
Re: Ioptron tripod [Re: donjoy]
      #5664842 - 02/06/13 09:12 AM
HI; I bought a celestron tripod and it looks like after a few changes it will work well.The tripod is for a one arm scope and i'll have to fill in the indentation where the arm mounts and put a round aluminum top on and it will be good to go.It is about 6" higher than the ioptron and has a level bubble like the ioptron and is much sturdier.Thank You for your help!!!!!.
13 registered and 19 anonymous users are browsing this forum.
Moderator:  tecmage, rflinn68
