Equipment Discussions >> Electronically Assisted Astronomy
James Cunningham
Reged: 08/07/10
Loc: Maryland
What would cause image on monitor not to change?
      #5666434 - 02/07/13 03:09 AM
I have a Mallincam. Last night, while observing, I went from the cigar galaxy to M42. It was brilliant, as usual. I then decided to slew back to Polaris which is always my first alignment star. I closed down my Miloslick camera contro software as soon as I started to slew to Polaris. For some reason, M42 stayed on the monitor. I turned off the monitor and then turned it back on but M42 was still there even though Polaris was in my finder scope. It was only after pulling the plug on the camera and then plugging it back in did Polars appear. What could have caused the image of M42 to stay on the monitor? Thanks, Jim
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: What would cause image on monitor not to change? new [Re: James Cunningham]
      #5666475 - 02/07/13 05:48 AM
Was this after an interval clearly longer than the integration time?
James Cunningham
Reged: 08/07/10
Loc: Maryland
Re: What would cause image on monitor not to change? new [Re: GlennLeDrew]
      #5666967 - 02/07/13 12:02 PM
I don't quite understand your question!
GlennLeDrew
Reged: 06/18/08
      #5667036 - 02/07/13 12:47 PM
If you had the integration time set to, say, 1 minute, had just obtained an image of target A and then immediately pointed to target B, target B will not appear on screen until a full minute had elapsed since the previous image update (for target A.)
I wanted to be sure that you had taken this into account. Which might be overlooked when ever longer integrations are employed.
But I'm now leaning toward the problem lying with the Miloslick control program, as I suspect your integration time would have been rather shorter than the time it took to execute the actions you described.
James Cunningham
Reged: 08/07/10
Loc: Maryland
      #5667450 - 02/07/13 04:39 PM
I know what you are talking about and that was not the problem. In addition to the image not changing, I have lost my countdown timer. Rock is aware of it. Thanks.
6 registered and 8 anonymous users are browsing this forum.
Moderator:  droid, David Pavlich, JayinUT
