Jeff Porter
Reged: 09/03/10
Loc: Utah
Fan baffle material
      #5666725 - 02/07/13 09:51 AM
I am looking to add a fan to my 12" dob, but I want to add a baffle as well to close out the back of the tube.
I have looked at both Kydex and ABS plastic, and a range of thicknesses up to 1/4". I want the baffle to be rigid, but I am not sure how thick of material I will need. Also please let me know if there is any benefit of using Kydex vs. ABS plastic.
Jeff P
Pinbout
Reged: 02/22/10
Loc: nj
Re: Fan baffle material new [Re: Jeff Porter]
      #5666847 - 02/07/13 10:57 AM
kydex is a pvc and abs mix.
you could use 1/8" thick black sintra [foam pvc], draw up what you need and have a sign shop cnc it. sign shop use sintra all the time not kydex or abs.
but on my 9.5 tube I have.028 kydex that is loosely velcroed to the inside, very loosely.
careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
      #5666886 - 02/07/13 11:15 AM
Are you cutting a hole in it for the fan? Will it carry any load? How will it be attached/supported it? Is the actual weight of any importance? Will it be exposed to handling, or will it be shielded inside the tube?
All of these have some effect on the best choices.
Stiffness goes up with the cube of thickness, which has the effect of creating an apparent threshold of thickness where you start regarding the material as "stiff".
You might look at Coroplast - the corrugated polypropylene used for signs, either by itself of a with a sheet of thin opaque plastic glued to it. It is 4mm thick, very rigid and light and cheap.
Thin plywood is also good 1/8" (3mm) is quite stiff and light (its density is about half that of the plastics and is twice as stiff). Actually somewhat thinner plywood would be stiff enough, but is not generally available. This would be over spec'd for the application really, it would be able to handle practically any method of attachment, load of a fan (if needed) and wear exposure fine
The Kydex and ABS are rather flexible (ie not very stiff) and a fairly thick sheet would be necessary, compared to some other materials. I have some 0.7mm Kydex it is quite flexible. I would guess that 1/8" (3mm) if you have a source would be stiff enough.
Jeff Porter
Reged: 09/03/10
Loc: Utah
Re: Fan baffle material new [Re: careysub]
      #5666976 - 02/07/13 12:06 PM
My thoughts were to attach the fan to the baffle material, and then suspend the baffle from the tube using some sort of elastic since I wanted to keep vibrations to a minimum.
I have a fan that I got with the scope that I can use, but I was also thinking of getting a larger fan with lower RPMs while maintaining the CFM rating. I have heard that he lower RPMs help with vibration. By suspending the baffle I figured that I would need something more rigid, especially if I use a larger fan.
Jeff P
Dick Jacobson
Reged: 12/22/06
Loc: Plymouth, Minnesota, USA
      #5667116 - 02/07/13 01:40 PM
I used a plastic coffee can lid on a scope that I'm currently building. I don't think the material makes much difference, as long as it can support the fan and doesn't let the air flow through. What's really important is that you isolate fan vibration from the scope. I've found that small, weak compression springs seem to work best.
Mark Peterman
Reged: 08/07/12
Loc: Texas
      #5667208 - 02/07/13 02:36 PM
Mine is made from 3mm thick PVC; rigid enough, yet lightweight. Weatherstrip on the edge seals it around the OTA. No noticeable vibration from the SilenX fan.
The first photo is the baffle for an 80mm fan. The rest of the photos show the 120mm version.
Scanning4Comets
Markus
Reged: 12/26/04
Loc: Ontario, Canada
Re: Fan baffle material new [Re: Mark Peterman]
      #5667234 - 02/07/13 02:51 PM
I am in the midst of experimenting using both methods. I used a thick cardboard baffle for about a year and now I am trying the elastic bands thing.
Only reason for the change is that when your batteries die and you are out in the field, the next best thing is cold air getting to the mirror rather than having the baffle without the fan working. In the latter scenario, your mirror is covered with nothing getting at it.
Jeff Porter
Reged: 09/03/10
Loc: Utah
Re: Fan baffle material new [Re: Scanning4Comets]
      #5667358 - 02/07/13 03:57 PM
Thanks to all for your responses so far.
Mark,
Thanks for the pictures. It looks like you use the weather stripping for sealing the end of the tube and for vibration suppression. I also like the use of Velcro to attach for access. Simplicity and elegance.
Jeff
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
      #5667569 - 02/07/13 05:57 PM
Guess I'm old school. I used plywood with rubber washers for the fan.
Have an old wet suit lying around? You'd be able to make your baffle AND isolate it. Failing that, Walmart and the like have rubber sheets in small squares for a few bucks.
Jeff Porter
Reged: 09/03/10
Loc: Utah
      #5667619 - 02/07/13 06:25 PM
I do like the idea of being able to remove the baffle in the field. That is why using elastic bands or Velcro has great appeal.
Typically here in the high desert the temperature will drop 30-40 degrees in the summer over the first few hours after sunset. After that things settle a bit and so the fan is not as necessary.
Jeff P
careysub
Reged: 02/18/11
      #5667726 - 02/07/13 07:38 PM
Yes, a large (120 mm) slow fan is best.
You might consider this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835124023
(A Kingston 120mm, 950 RPM, 40 CFM, $5)
I prefer Scythe 120mm fans, the best on the market, dead silent, energy efficient (0.1 amp), vibration free and rated for 10 years of continuous use(!). I use them in all my computer builds, and have used them for other equipment cooling applications.
Unfortunately they just closed their U.S. office which has disrupted their supply. I have just emailed their central office in Taiwan to see if they can be ordered directly from there. (Fortunately I laid in my own supply for scope use.)
BTW a CD makes the perfect template for cutting a 120 mm fan hole.
Although a 120mm fan does add a load to the baffle, it also stiffens it since the fan body is rigid.
Jeff Porter
Reged: 09/03/10
Loc: Utah
      #5668071 - 02/07/13 11:10 PM
Thanks for the recommendation on the fan. I want something quiet and durable there.
Jeff P
David Castillo
Reged: 09/09/06
Loc: Carmel Valley, Ca
      #5668206 - 02/08/13 12:46 AM
I just re-purposed an old plastic "For Sale" sign, painted it ultra-flat black to keep the comments down, and it's held up for 10 years now. Kydex -Really ?
Dave
tnranger
Reged: 01/14/12
Re: Fan baffle material new [Re: David Castillo]
      #5668371 - 02/08/13 06:19 AM
What's wrong with 1/4 inch plywood?
Dick Jacobson
Reged: 12/22/06
Re: Fan baffle material new [Re: tnranger]
      #5668462 - 02/08/13 08:23 AM
I've also used foam-core poster board. Very light and stiff and easy to cut.
Pinbout
Reged: 02/22/10
Loc: nj
      #5668473 - 02/08/13 08:36 AM
is that the corragated plastic sheet, coroplast? cut it up and layer it and you can make a very good baffle to create a laminar flow.
Jeff Porter
Reged: 09/03/10
Loc: Utah
Re: Fan baffle material new [Re: Pinbout]
      #5668487 - 02/08/13 08:47 AM
All of the suggestions are appreciated.
Since I have not done much ATM myself, I don't pick up on the day to day stuff that could be used like you folks. I read a lot of the suggestions and wonder why I didn't think of it. It seems to me that ATM is a frame of mind, rather than just doing a project.
Jeff
careysub
Reged: 02/18/11
Re: Fan baffle material new [Re: Dick Jacobson]
      #5668555 - 02/08/13 09:20 AM
I had thought about recommending that - it is certainly stiff and strong enough -but was concerned about its durability, especially the fact that is covered with paper which would suffer from the humidity of dew-laden air.
Giving it a good coating of spray paint might give it adequate moisture resistance though.
What is your experience?
Project Galileo
Reged: 11/14/07
Loc: Jefferson County, Colorado
      #5668690 - 02/08/13 10:50 AM
LB16s need a lot of counter weight in their butts especially if you use a paracorr, large eps, and a finder scope. That is why I used 1/8" steel. After cutting, grinding, and punching I had a 7.5 lb baffle. It was powder coated and a neoprene gasket was made to seal it up. The final result balances like a dream and I believe is elegant.
Dick Jacobson
Reged: 12/22/06
      #5669054 - 02/08/13 01:34 PM
I have to admit, I'm still building the scope so there is no experience. It occurred to me that dew could be a problem, but the foam in the core should be dew resistant.
6 registered and 20 anonymous users are browsing this forum.
