zeldaboy101
Reged: 03/13/04
Loc: Maryland
Nexus 7 Sky Safari Screen Brightness Disappointing new
      #5667914 - 02/07/13 09:42 PM
I downloaded Sky Safari Pro to my Droid Charge with an AMOLED screen a few months back. The single core phone was a little slow but ran it and the charts looked beautiful. More importantly, it didn't impact night vision when I used ScreenDim in conjunction with the red mode because the screen's overall brightness could go to pure black if I wanted. The black background did not emit light, it was just black.
I recently got a Nexus 7, mainly to use for Sky Safari Pro, because of the larger screen and dual processor. Since it's not AMOLED, the screen always has a glow to it. In Sky Safari Pro the sky is black in regular mode, but switch it to red mode and the background sky actually turns to a brighter gray! It The stars are red, but the grey background ruins your night vision. The regular screen brightness was at the minimum value.
So I turned on ScreenDim, set the screen brightness to the minimum and the contrast to the minimum value. You can't see anything in Sky Safari, but the entire screen still glows a grey color. There's almost nothing being shown on the screen yet it can't get darker or redder.
If you hold the Nexus 7 and Droid Charge near a wall, there is a pure red glow coming from the Charge and a white glow from the Nexus 7, it's not even close to real night vision.
I tried running another screen filter app i've used on the Droid Charge with some success and that didn't help at all either.
Short of red film, can this glow actually be removed, or is the lack of a LED screen going to cause it to hurt night vision more than my phone no matter what I do? It's a shame too, because the Sky Safari + ScreenDim combo on my phone was down right impressive.
Edited by zeldaboy101 (02/07/13 09:57 PM)
ccs_hello
Reged: 07/03/04
Re: Nexus 7 Sky Safari Screen Brightness Disappointing [Re: zeldaboy101]
      #5668037 - 02/07/13 10:53 PM
Per your description, it's the LCD technology issue (quite common). The only fix is to use a red film to cover the entire screen or to get a new device .
Clear Skies!
ccs_hello
Reged: 07/06/07
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: ccs_hello]
      #5668437 - 02/08/13 08:03 AM
Forget "short of red film. I have never seen _any_ tablet or phone that didn't need red film to preserve your night vision.
zeldaboy101
Reged: 03/13/04
Loc: Maryland
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: rmollise]
      #5668449 - 02/08/13 08:15 AM
You ought to try looking at an AMOLED screen with Sky Safari then. The blacks are just pure black because they are turned off. Then using ScreenDim you can turn the brightness of the red down so much the screen is nearly completely off. It's still easy to read it when it's dim.
The Nexus 7's screen however is an issue. I wonder if instead of applying a generic red filter in SSP, which brightens the background, if they could keep the background black, but change the color of everything else to red? That could potentially help.
Sorny
Reged: 03/15/12
Loc: Southern MN
      #5669870 - 02/08/13 10:12 PM
Try a "retina" iPad running SkySafari. It can dim it to where I can't see anything and it doesn't ruin my night vision. Mind you, I never leave the SkySafari app once I start using it, but it works just fine w/o film. Auto-brightness in the system settings of the iPad disabled, screen brightness all the way down, and the brightness slider in SkySafari has to be up a tick in night-vision mode to be usable; more, obviously, if the moon is up.
Obviously not a solution for someone with a Nexus 7, so I'll have to echo everyone else who says to get some red film for the screen.
zeldaboy101
Reged: 03/13/04
Loc: Maryland
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: Sorny]
      #5669902 - 02/08/13 10:27 PM
I contacted Alex who made ScreenDim. He had an idea but I don't know enough programming to give it a try.
One could recompile the Linux kernel, though, on your device with finer-grained PWM support for the backlight.
Reged: 06/16/04
      #5670203 - 02/09/13 06:46 AM
My phone doesn't affect my night vision as long as I keep it in my pocket.
I personally think a red screen is necessary to protect against the possibility of accidentally ending up outside of Sky Safari without it's red screen.
Reged: 07/06/07
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: Jon Isaacs]
      #5670275 - 02/09/13 08:19 AM
Yep. And if you have an iPhone, you will wind up at that consared Lock Screen every time.
demiles
Reged: 11/07/06
      #5670439 - 02/09/13 10:16 AM
An ipad with retina display is still way too bright to use without a film over it. I've tried them.
lamplight
Reged: 09/18/12
Loc: west central MA, U.S.
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: demiles]
      #5725715 - 03/11/13 12:13 PM
I just found an app on the google play store called "Lux" that dims the actual backlight .. (That gray light you describe even when everything is turned down) There's a free version.. It's daytime now so I can't say for sure how well it will work.. but I think this may do the trick. I have a nexus 7 too and yes it's waaaay too bright..
mark03
journeyman
Reged: 03/12/13
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: zeldaboy101]
      #5728989 - 03/12/13 09:03 PM
I just stumbled onto this thread after experiencing similar behavior with my Nexus 10. Almost none of the replies to the OP are correctly understanding the issue, so maybe I can help.
There are two contributors to the amount of light coming from an LCD display: (1) the backlight intensity, and (2) the pixel values on the screen. The pixels are like valves, controlling how much of the backlight is exposed. Even a completely black screen will emit a fair amount of light from the backlight. This ultimately sets the "contrast ratio" of the LCD display.
The issue with Skysafari's night mode, at least on the Nexus 7 and 10, is that while it changes the pixels to shades of red, it simultaneously TURNS UP the backlight. Actually, I did some experiments which suggest that it is setting the backlight to a fixed level, so if you start out with a really bright screen, the backlight gets dimmer, but if you start out with it set to minimum, night mode makes it a lot brighter.
Of course, you will likely need some Rubylith filter material in the field anyway, but the high backlight setting in night mode makes the contrast lousy, so I actually get a more usable field display in non-night-mode with a double layer of Rubylith. It's not perfect, as blue and green text is [obviously] really hard to read through the red filter, but it's still better than night mode.
So, the reason this is an issue, is that it is entirely preventable (at least in theory). I can't think of any reason why Skysafari should be fiddling with my backlight intensity. I sent a support request a few weeks ago but didn't hear back. They're usually very responsive so I guess I just need to try again.
BTW, I also corresponded with the author of ScreenDim and it turns out that the Nexus 10 is somewhat unusual in allowing you to turn the backlight all the way down to 1/255 in the OS settings. Thus, ScreenDim doesn't help. No other app can help either, because they are just scaling the pixel values, and as the OP points out most of the light is coming from the black pixels. We just need Skysafari to not sabotage the very nice backlight control on these devices, and things will improve markedly.
btschumy
Vendor - Southern Stars
Reged: 04/13/04
Loc: Longmont, CO, USA
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: mark03]
      #5729199 - 03/12/13 10:26 PM
I can guarantee that we are not fiddling with the backlight intensity. If it is changing then it must be a side effect of something else. I can try to take a look at it. Can an app even adjust the backlight intensity without being rooted?
Sorry if we didn't respond to an earlier inquiry. Sometimes thing fall through the cracks.
mark03
journeyman
Reged: 03/12/13
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: btschumy]
      #5729419 - 03/13/13 12:04 AM
Hi Bill,
Thanks for your reply. I'm fairly confident the backlight level is in fact going up. I might have had some residual doubt at first but zeldaboy101's observation seems to confirm it. The black areas are definitely getting [much] brighter when night vision is activated.
I wish I knew more about Android internals, but my experience only goes as far as standard Linux. Perhaps it's an undocumented side effect of some system call? I hear that's a problem on Android (:
If there's anything I can do to assist in testing, I'd be happy to.
Mark
Reged: 06/16/04
      #5729889 - 03/13/13 09:03 AM
Probably Alex could answer that one but I do use his Screen Dim with Sky Safari. With my HTC Incredible, I did some experiments using Screen Dim and SSP. I had Screendim set at 4.7% brightness, 100% contrast.
I zoomed way in until there were no stars or objects in the field of view, then I went into a closet, allowed my eyes to dark adapt a short while and then switched between night and normal while observing the brightness/darkness of the background. I could see no change.
Edited by Jon Isaacs (03/13/13 09:47 AM)
mark03
journeyman
Reged: 03/12/13
      #5730349 - 03/13/13 01:19 PM
Could the issue be unique to Jelly Bean? Which Android version do you have on the Incredible? It would be interesting to get some more data points.
I have ScreenDim installed, but ended up not using it, becausse minimum backlight in ScreenDim turns out to be the same level as minimum "brightness" under the Android Settings menu. Apparently the Nexus tablets are somewhat unusual in that regard.
Reged: 06/16/04
      #5730454 - 03/13/13 02:23 PM
The Incredible runs something like 2.3.7.
The Screendim documentation says it adjusts the backlight brightness in "many LCD devices"
CarolG
Reged: 10/16/06
Loc: Oklahoma
      #5731114 - 03/13/13 08:57 PM
Perhaps you have already tried this free app. I downloaded it today, and it seems to work much better than ScreenDim. It's Night Mode by Bruno Barao. You can find it at Google Play. It really dims the screen of SSP, in fact if you turn it all the way down, the screen is black.
mark03
journeyman
Reged: 03/12/13
Re: Nexus 7 Sky Safari Screen Brightness Disappointing new [Re: CarolG]
      #5731355 - 03/13/13 11:23 PM
You probably have an OLED screen. Just scaling the video data will reduce the OLED light output very effectively. On an LCD, the app you referenced will not reduce the light output at all, once you are already at the point where all the light is coming from the black pixels.
lamplight
Reged: 09/18/12
      #5732146 - 03/14/13 12:15 PM
hi
some nexus 7 observations (I also have a android phone to try later):
i cant see any increase in brightness when skysafari comes on either.
when using "Lux" night mode doesnt even do anything(isnt needed) in sky safari...
lux has a couple extra night mode options that basically turn everything red.. i found it easier to not use this and have sky safari still on color maps..
screendim actually dims the navigation buttons (home, back) whereas lux and "Night mode" annoyingly doesnt. i bought screendim because of this.. personally any of these will be a super improvement from what it was like before..
and will help compensate for those few screens where full brightness still pops up in sky safari (entering descriptions/keyboard etc.. )
and for the record these apps make the screen way WAY dimmer than an ipad turned all the way down (although i dont know if there are any advanced brightness/dimming apps for retina display ipads).
mark03
journeyman
Reged: 03/12/13
Re: Nexus 7 Sky Safari Screen Brightness Disappointing [Re: lamplight]
      #5732286 - 03/14/13 01:47 PM
Did you try this with the Nexus 7 brightness (under Settings->Display) set to minimum, and auto-brightness disabled?
Then you spent at least a few minutes in a completely darkened room, with Skysafari in normal mode and zoomed in so most of the screen was black, and only then turned night mode on?
If you did all this, but didn't see an obvious jump in screen brightness when night mode was enabled, I'm at a loss to explain the differing observations
In Screendim have you left contrast at 100% or are you turning it down too?
4 registered and 10 anonymous users are browsing this forum.
Moderator:  Bowmoreman, richard7
