foste1cc
Reged: 01/06/13
Loc: Armada, MI
guidescope guiding a 8SE SCT new
      #5660028 - 02/03/13 01:48 PM
hey everyone. i'm new to AP and just ordered my first equatorial mount (celestron AVX). I know that everyone says to guide these SCTs with an off-axis guider. but i also heard that those are very hard to use for beginners. so my question is,
Have any of you had any luck guiding your SCTs with a guidescope? or do you run into the problems like mirror flop and flexure they talk about?
and also, could someone explain to a beginner like me, exactly what mirror flop and flexure are and how they're caused? i have an idea, but i want to know these things.
Midnight Dan
Reged: 01/23/08
Re: guidescope guiding a 8SE SCT new [Re: foste1cc]
      #5660181 - 02/03/13 03:17 PM
Hi foste1cc:
Well, there's mirror flop and there's mirror shift. Both are due to the same underlying construction of the SCT where the mirror is glued to a tube in it's center, and this tube is slipped over a second tube which is fixed to the rear cell of the SCT. The two tubes slide relative to each other for focusing and have grease between them to allow them to move smoothly. But, the two cannot be an exact fit or it would not move so there is a slight difference in their diameters. This allows the mirror to move sideways a very small amount if force is applied one way or the other.
When an SCT is used on a GEM mount and it moves across the meridian, the shift in the mirror's weight from one side to the other causes it to flop from one side to the other to take up the slop between the two tubes. That is called mirror flop and it only happens when moving through the meridian.
Mirror shift is what happens when the SCT is tracking. You'll notice on a GEM mount that the SCT rotates as it tracks the night sky. You can easily see this if you have an eyepiece in the scope because it ends up in all kinds of weird directions as you slew from target to target. Since the scope's orientation relative to the pull of gravity is changing, the position of the mirror slowly changes as well so the tube slop is always oriented the same direction with respect to gravity.
With either mirror flop or mirror shift, the imaging camera sees the image move, but the guide scope does not. So guiding with a guide scope cannot compensate for it. An off-axis guider sees the same image as the imaging camera so if the guide star shifts slowly due to mirror shift, it should be able to compensate. Mirror flop can happen quickly and may move the image too far and too fast for even an off-axis guider to work.
Flexure also causes the guide scope and imaging scope to see different movements in the image, but due to a different underlying cause. All materials, even metal, bend under force. There are a number of metal parts that connect each piece of your gear to each other and they all flex differently when the mount moves during tracking. The more solidly all the parts are connected to each other, the less differential flexure will occur. The guide scope can think it is keeping the guide star perfectly centered, but the main scope is, over time, seeing the image shift a little relative to what the guide scope sees. It can be difficult to figure out what part of your setup is allowing the most flexure to occur and to figure out how to improve it. But going heavier and more solid always helps - like using Losmandy size dovetails instead of Vixen size.
-Dan
Tel
Reged: 03/31/06
Loc: Wallingford England
      #5660215 - 02/03/13 03:39 PM
Hi foste1cc,
Just one guy's opinion, you understand, but based on my experience with the Celestron Off-Axis guider, my advice is to steer very clear of this piece of kit.
Coupled to my Meade DSI, I think I would have exhausted the patience of a saint before I was able to get any alignment on a guide star let alone par-focus it and the object I was trying to image in the capturing camera !
Now my present system of coupling the Meade DSI to my 104mm refractor and using Stark Labs. PHD free software for guiding purposes is an entirely different affair in its simplicity to set up and the accuracy with which it tracks. I would therefore recommend a guide 'scope combination every time !
As to mirror shift and mirror flop, and again based on my own imaging experience, I think their potential effects are vastly exaggerated judging by the fact that they have never hampered my imaging with my Nexstar 8i OTA/GEM combination.
Referring though to their definitions: mirror shift is a phenomenon you may well have experienced yourself when focusing your 8SE. The image may well shift in the EP as a result of the focusing thread and fork movement when you turn the focusing knob .
Mirror flop on the other hand, is a function of gravity : the potential for the mirror to "flop" or "drop" when in such a position on an equatorial mount as to permit this to happen under gravity.
I hope that the above explains. As I said, it's only my opinion. Others may well differ.
Best regards,
Tel
Midnight Dan
Reged: 01/23/08
Re: guidescope guiding a 8SE SCT new [Re: Tel]
      #5660381 - 02/03/13 05:15 PM
After my long-winded explanation, I forgot to talk about my experiences with OAG guiding!
I had read, from Tel and many others here on CN, that the Celestron OAG was to be avoided. Seems like many have had trouble using that particular one. I purchased a Taurus Tracker III instead and have been reasonably pleased with it. It's a quality-made piece of gear, provides a large pick-off mirror, and allows some in/out motion of the pickoff mirror for better placement of the guide star.
Having said that, it is still an OAG and has the downsides that are shared with all OAGs. The area of view of the pickoff mirror is limited and depending on your target it can be difficult to find a decent guide star. Since you're guiding at the same focal length as the imaging scope, you have the advantage of more accurate guiding, but it also means you have a smaller field of view than with a guide scope making finding an appropriate star additionally difficult.
The times that I've used it, I have been able to find a guide star and it has worked well. But I also have an Orion 50mm min-guider and I prefer to use that on smaller refractors where mirror shift is not an issue. Once I get my observatory (this summer, hopefully!) and can image more regularly, I may end up getting a side-by-side setup so I can use a guide scope if desired. That will let me use the OAG if there's good guide stars nearby, or a guide scope if not.
As Tel says, many of these issues of flexure and mirror shift can be overblown. Certainly if you're a perfectionist, you'll want to consider them. But you can get some pretty nice images without worrying about them, and only your picky astro-imaging-buddies will know the difference.
-Dan
ourobouros2k2
Reged: 11/10/11
Loc: okc area, oklahoma
Re: guidescope guiding a 8SE SCT new [Re: Midnight Dan]
      #5660938 - 02/03/13 11:52 PM
FWIW I don't have much experience, but the one time I setup my Orion SSAG package with the ST-80 it all worked according to plan. My Sirius mount was out of balance and it did a pretty good job despite the mechanical difficulties. With a properly balanced mount and staying within weight limits, I see no issues with a c8/guidescope combo.
foste1cc
Reged: 01/06/13
Loc: Armada, MI
Re: guidescope guiding a 8SE SCT new [Re: ourobouros2k2]
      #5661889 - 02/04/13 02:20 PM
These are all great replys that help out alot! Thanks everyone!
foste1cc
Reged: 01/06/13
Loc: Armada, MI
      #5666689 - 02/07/13 09:23 AM
Do any of you know if i can get away with buying the cheaper package for the SSAG? The difference in the two packages is about $90 and a helical focuser in the more expensive one. Would i need this with my setup or is it just something fancy i can get away without?
ourobouros2k2
Reged: 11/10/11
      #5666953 - 02/07/13 11:53 AM
If I had it to do over again, I would have done the mini SSAG package using the 50mm finder. Simply to conserve on weight
foste1cc
Reged: 01/06/13
Loc: Armada, MI
      #5667023 - 02/07/13 12:41 PM
Andrew, those are the ones im looking at now. Do u think i need the helical focuser for my setup? Or do u think i can get the cheaper package that just comes with the ssag, mount and 50mm guidescope
Tel
Reged: 03/31/06
      #5667098 - 02/07/13 01:29 PM
Hi Carl,
There seems to be some sort of strange caveat associated with the Orion "mini- package" in as much as the ad. states that it is a :--
"Complete and easy-to-operate autoguiding system for precise astrophotographic guiding with instruments up to 1500 mm focal length".
The 8SE has of course a focal length of ca.2000 mm but, (and maybe I'm missing something here), as far as I'm aware from my own experience, the focal length of the guide 'scope has no influence whatsoever on the imaging 'scope's focal length.
The main criteria for a guide 'scope is surely that it should be of sufficient aperture to produce sufficient brightness in the available and most favourable guide star and have a relatively short focal length in order to exploit a wide field of view and thus improve the guide star choice.
Puzzling !
Best regards,
Tel
Midnight Dan
Reged: 01/23/08
      #5667176 - 02/07/13 02:16 PM
The reason that the focal length of the guide scope matters is that you want to be able to control the mount accurately enough so that the stars don't move on the imaging scope's sensor. With a short focal length guider like the 50mm finder, a star can be wandering around quite a bit in the field of a 2000mm scope, but stay on the same pixel the whole time in the guider. The guider won't issue any commands to the mount until the guide star wanders around on *its* pixels, which cover a MUCH larger part of the sky.
The common wisdom has been that the focal length of the imaging scope should be no more than 5x the focal length of the guider. That means that, in theory, a guide scope should be at least 400mm for the 8SE. However, PHD and other guiding programs can now do sub-pixel guiding, so some say that the mini-guider works fine on an 8" SCT.
My personal take is that sub-pixel guiding is more difficult and less accurate (and it has its limits), and that the closer your guide scope's focal length is to the imaging scope, the better. I think staying with the old 5x-focal-length advice is still a good idea. But, as with all things AP, it depends on how particular you are. For many, the images you get with a mini-guider and an 8" SCT will probably be just fine.
At the very least, it's a good place to start because it's inexpensive, it mounts easily, and adds little to the weight of the gear. Later, if you want to move to a larger guide scope, the SSAG guide camera from the mini-guider will work with that too. And if you get into AP, you'll likely have other imaging OTAs in the future. The miniguider will work well with them if they are shorter focal length.
-Dan
ourobouros2k2
Reged: 11/10/11
      #5667934 - 02/07/13 09:58 PM
Tel, thanks for bringing up the issue of focal length with the 50mm package. I had no idea, good to know!
Tel
Reged: 03/31/06
      #5668354 - 02/08/13 05:35 AM
HI Andrew,
I was both puzzled and curious but many thanks to Dan for providing that very comprehensive explanation. As they say; "I never knew that" !
However, to me, Dan hit the nail on the head when he said ,"But as with all things AP, it depends on how particular you are".
Taking therefore as an example, my own, (more Bohemian), approach: I have a 4" refractor placed in parallel with my Nexstar 8i's OTA on a dual dovetail bar, all sitting on a Skywatcher HEQ5 Pro GEM.
Depending then, on what I want to image, and with guidance from Rod Wodaski's "New Astronomy Calculator", which assists me in establishing which 'scope to use by providing the FOV size to expect, I make my choice between the two as to which will be the guide 'scope and which will be the "imager".
When using the 4" as the guide 'scope, I always "halve" its 590mm focal length by using a simple, Antares X0.5 reducer. (In actual fact, I think the amount of reduction is nearer to ca. 33% which provides for a revised focal length of ca. 390mm).
The reason for the reduction is to produce the widest number of guide star options possible within camera focus. My guide software is incidenrally PHD.
Conversely, if an object, such as the Orion Nebula, demands a very wide FOV, I use the 4" to capture and the N8i, suitably focal length reduced with a 6.3 FR to guide. (I have not yet tried it, but in always using a Meade DSI Mk.1 CCD camera to guide, I could use it in combination with my Meade 3.3 FR).
The above may be a far cry from a perfect mathematical model of how an imaging/guiding system SHOULD be set up, but I find it effective enough for my aspirations, given that my viewing range lies only between a restricted Northwest to a restricted Southwest, (rooftops), through East; I have to contend with the unpredictability of the English weather on any seemingly crystal clear night; and that I can almost always apply corrective measures to an image via the various pieces of software at my disposal.
I'm therefore mostly happy with my results.
Best regards,
Tel
Edited by Tel (02/08/13 06:01 AM)
foste1cc
Reged: 01/06/13
Loc: Armada, MI
      #5670194 - 02/09/13 06:35 AM
Thanks a bunch guys! I think i'm going to invest in orions ST80 rather than celestrons 50mm, even though i use a focal reducer for my OTA. I heard the ST80 is very light for it's class so i figured why not for $20 more. I'm planning on buying the ST80 and mounting rings from astronomics. I see that someone else on another thread awhile back said that the rings in the following link would fit the ST80, but would involve removing the focuser, which he said was simple and only required a screwdriver and one screw.
http://www.astronomics.com/astro-tech-90mm-finder-photoguide-ring-system_p122...
My question is, are these good rings? Is there any part of the rings/mounting shoe/collimation bolts that are of poor design or material? I'm not sure if there'd be flexure with these rings and shoe. Would all of this be a sufficient autoguiding setup I can use with my setup to start getting into AP? I have yet to shoot my first photo, as i just received my first equatorial mount (celestron AVX), and just got my first DSLR (canon T2i). So now it's time for my first autoguiding setup. Looking for something cheap, light weight, and good enough to get me 5-10 min exposures if possible.
And also, would I need anything else like an extender for focusing? Or would just the ring kit, ST80, and SSAG be all I need?
Thanks in advance guys! You're all helping me learn 10x as much on here than I do trying to figure it out on my own
hopskipson
Reged: 06/24/10
Loc: Queens, New Yawk, Light pollut...
      #5670287 - 02/09/13 08:28 AM
I bought the awesome guider kit from Orion's website last year.
http://www.telescope.com/Astrophotography/Autoguiding-Solutions/Orion-Awesome...
At that time it was $249 shipped. I haven't installed it yet, time and weather are not on my side! It comes with everything you need, including rings, mounting hardware, and extension tube.
Good luck with your decision.
hopskipson
Reged: 06/24/10
      #5670289 - 02/09/13 08:31 AM
And helping you spend your money !0x faster!
Midnight Dan
Reged: 01/23/08
Re: guidescope guiding a 8SE SCT new [Re: hopskipson]
      #5670468 - 02/09/13 10:33 AM
Hi Carl:
The astrotech setup looks pretty solid, and looks like it might be a bit heavier-duty than the set that comes with the Orion awesome autoguider package. If you get that, don't forget to take advantage of the Cloudy Nights discount. It's not a lot but every bit helps.
Since the Orion package comes with an extension tube, I'm assuming you'll need one.
I think the choice between the Orion and the Astro-tech comes down to how you want to mount it. The Astrotech mounts on a finder-like-shoe which will attach to the rear cell. This is easier to attach, but limits any fore-aft movement of the guide scope and may be more difficult to balance.
The Orion requires the attachment of a full rail from end to end on the OTA. I'm not sure if the rail they provide is long enough for an 8" SCT and if not, you'd have to get a longer one. If it is, it will take a bit more effort to mount the scope, but provides a lot of adjustment room to help with balancing.
-Dan
ourobouros2k2
Reged: 11/10/11
      #5670547 - 02/09/13 11:25 AM
"The Orion requires the attachment of a full rail from end to end on the OTA. I'm not sure if the rail they provide is long enough for an 8" SCT and if not, you'd have to get a longer one. If it is, it will take a bit more effort to mount the scope, but provides a lot of adjustment room to help with balancing."
It is too long in fact. It will overhang the rear of the ota by about 4-5 inches if I remember correctly. Nothing a jigsaw can't handle though, and a few squirts of black spray paint.
foste1cc
Reged: 01/06/13
Loc: Armada, MI
      #5670600 - 02/09/13 11:59 AM
thanks for the replies guys! do any of you know if celestrons 125mm rings they sell for their guidescope, will fir the ST80? now i'm thinking about going with celestrons 8-inch dovetail bar with their 125mm rings. it looks like a real solid setup. I'll go with celestrons guidescope if i have to, but would prefer the ST80 because of the weight difference and being an f/5 compared to f/7.5 . so just wondering if anyone knows if the ST80 will fit in the 125mm rings. thanks everyone!
foste1cc
Reged: 01/06/13
Loc: Armada, MI
Re: guidescope guiding a 8SE SCT [Re: foste1cc]
      #5670616 - 02/09/13 12:07 PM
Andrew - How'd you secure the bar to your OTA after you used a jigsaw to cut the access length off? I was really thinking about just buying that package, but am choosing otherwise because i don't know an easy way to secure it to my 8SE. It looks like the bolt heads for securing the rings to the bar stick down quiet a ways, and that you'd need some other type of bar or mounting accessory to raise it up and secure it strong enough for minimum flexure. Or did you find tube rings to fit your 8SE and do the setup properly? I would do it this way, but can't find any tube rings for my SCT that are in my budget as of now..
7 registered and 28 anonymous users are browsing this forum.
