rigel123
Reged: 06/29/09
Loc: SW Ohio
Bummed about my 2.5x powermate
#5671143 - 02/09/13 06:09 PM Attachment (100 downloads)
Attaching an image that I overstretched to show what I am seeing when I shoot longer exposures of proms with my new 2.5X Powermate. I'm getting a "Ghost" image of the sun and it's driving me nuts. I don't get this when I use my cheapo orion 2X barlow! I like the clarity I get with the powermate but any ideas how to avoid getting this ghost?
Camera is a DMK31AU03. I can reduce the ghost somewhat when shooting at higher frame rates but it is still there and I hate trying clone it out or reduce it by playing with the background. I may just go back to my inexpensive barlow!
BYoesle
Reged: 06/12/04
Loc: Washington USA
Re: Bummed about my 2.5x powermate
[Re: rigel123]
#5671329 - 02/09/13 07:54 PM
I noticed this in your animation too. The Powermates use a telecentric lens arrangement, with both a negative lens and a positive lens - or lens groups. My guess is that one of the groups or lenses may involve a plano component. If these are not tilted, you may get a reflected image like this. I'd send the image with your description to TeleVue for a more informed opinion.
sullij1
Reged: 11/08/08
[Re: rigel123]
#5671372 - 02/09/13 08:20 PM
WOW, Warren, I had similar issues with my Cak images. I never thought to peg the issue on the powermate. If you choose to follow Bob's advise, let us all know what Teleview says. Last time I saw this issue pop up it was an issue with the inside of the C to 1.25 adapters being not properly flocked.
When I saw your post it struck me to check my 2.5 Powermate for proper flocking on the objective side. Sure nuff, if you dis-assemble (unscrew the threaded elements) the inside elements are flocked. Unfortunately the chrome barrel on the objective side is not! Perhaps using flat black paint to flock the threaded chrome end on the powermate may make the reflectionm go away. If you have sun, it easy enough to do and post back (while you wait for teleview to respond).
Thanks for pegging the powermate as the possible culprit. I have been fighting the same reflection!
If it is the unflocked chrome end - that will be an easy fix for a lot of us.
Joe
Edited by sullij1 (02/09/13 08:26 PM)
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: sullij1]
#5671490 - 02/09/13 10:05 PM
Thanks for the comments Bob/Joe, I'll definitely write to Televue and I'll report back what they say. The inexpensive barlow I have used in the past (it is a Meade, not an Orion) is a shorty 2X barlow. I took apart the Televue and it appears flat black all the way through. Glad to hear it's not just me!
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
[Re: rigel123]
#5671784 - 02/10/13 03:49 AM
The 2.5x Powermate works well with my Imaging Source cameras. I note that the filter thread on the front of the nosepiece is shiny metal and might be better blackened or flocked but it really doesn't seem to affect me. I suspect your reflection is between the front element of the powermate and the back element in the Ha diagonal ... the elements in the blocking filter are often slightly tilted to avoid internal reflections & perhaps yours isn't tilted enough.
I've always had issues with "ordinary" barlows for high resolution imaging ... some loss of contrast due to reflections similar to that shown in your image, some loss of resolution possibly caused by poor correction especially at short & long wavelengths (solar CaK & Ha) but mostly because the magnification varies so much with the magnification. Give me a Powermate any day. I just wish they made 1.5x, 2x and 3x in 1.25" fittings ... the 2" fitting Powermates are far too heavy & the 5x is way too powerful in a scope with anything like a sensible focal ratio.
AstroPaolo
Reged: 01/30/08
[Re: brianb11213]
#5671812 - 02/10/13 04:48 AM
the 2x and 4x powermate 2" gave me the same reflection and gost images, they cost a fortune, I expected no reflection in any conditions, my cheap 2x celestron barlow suffer alot less but it has a different lens system
televue probably didn't create them thinking also the solar imaging, i switched to the baader telecentric barlow, created for solar imaging; that also has an halpha range cleaner avoiding any reflection.
marktownley
Reged: 08/19/08
Loc: West Midlands, UK
[Re: AstroPaolo]
#5671850 - 02/10/13 06:00 AM
I've read others having the same issue with the 2.5x powermate and Ha, I don't (luckily!) have this issue... Not sure what to suggest to fix...
ASTROTRUCK
Reged: 01/02/10
[Re: marktownley]
#5673160 - 02/10/13 10:01 PM
same issue with my 2.5 powermate with my dmk41
so who do we send it back to - if we do our own paint job what are the chances of the paint flecking with constant summer heat.
they should be prepared to correct the flocking issue considering the cost for one up here in canada.
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: marktownley]
#5673161 - 02/10/13 10:02 PM
Hopefully will have a chance to talk to Televue once I'm back from my meeting. I'll be interested in their input.
Aquarist
Reged: 08/27/12
Loc: Illinois
[Re: rigel123]
#5673756 - 02/11/13 10:14 AM
Yes, please keep us posted.
drksky
Reged: 09/01/09
Loc: Bloomington, IL
[Re: Aquarist]
#5673968 - 02/11/13 12:28 PM
Makes me curious to try out the 2.5X powermate that I bought a few weeks ago. Haven't had a clear day since then.
Andy Devey
Reged: 05/06/11
[Re: drksky]
#5674012 - 02/11/13 12:52 PM
Hi, just a thought, what about cutting a piece of matt black cardboard the same length of the inner circumference and putting it into the barrel of the the Powermate it would be very easy to do?
Regards
Andy
Edited by Andy Devey (02/11/13 12:55 PM)
ASTROTRUCK
Reged: 01/02/10
[Re: Andy Devey]
#5674211 - 02/11/13 03:14 PM
if it has to be opened then is there a critical alignment issue when reassembling
nagler i am sure may not be happy to receive back all our 2.5's
then are these isolated few not blackened not caught by them or all not blackened at all
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: ASTROTRUCK]
#5674857 - 02/11/13 09:50 PM
I did take mine apart and the only part that is shiny chrome is the very end of the tube, the entire inside is flat black. I may try some flat black on the very end and see if that takes care of it.
If anyone else notices this same reflection please let me know.
sullij1
Reged: 11/08/08
[Re: ASTROTRUCK]
#5674877 - 02/11/13 10:02 PM
I thought as Brianb, perhaps a reflection between the lens groups and the diagonal. It will be interesting to see how this pans out.
Warren, do you use a diagonal? If so, can you shoot one straight through without the diagonal and see what you get?
Edited by sullij1 (02/11/13 10:05 PM)
Jim Lafferty
Reged: 06/30/07
Loc: Southern California
[Re: sullij1]
#5679541 - 02/14/13 01:49 PM
Havent had that issue myself with my 2.5x powermate---Im assuming you arent doublestacked?
marktownley
Reged: 08/19/08
[Re: Jim Lafferty]
#5679577 - 02/14/13 02:07 PM
What size blocker is being used in the scope?
ASTROTRUCK
Reged: 01/02/10
[Re: marktownley]
#5707298 - 03/01/13 02:41 PM
question - i as stated using the 2.5 powerrmate have a very acute double image -using an etelon i place the powermate between the blocking filter & the dmk
IS IT SAFE TO PLACE THE POWERMATE BEFORE THE BLOCKING FILTER considering the etelon reduces the heat coming through , & still place the dmk after the blocking filter.
this somewhat changes the position of the various glass surfaces.
thanks
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: marktownley]
#5707379 - 03/01/13 03:31 PM
Sorry, forgot about this as I have been busy with work and it has been cloudy. I did do some imaging with my Orion 2X and no problems.
Yes there is a diagonal it is the 1200 BF, and it is a single stack. I haven't had a chance to talk with Televue yet.
Just spoke to Televue, it's a spacing issue, will post more info later
Edited by rigel123 (03/01/13 04:14 PM)
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: rigel123]
#5707738 - 03/01/13 08:21 PM
OK, this may make some sense. I spoke with Televue and it is the spacing that is causing the ghost. They suggest getting the PTR-1250 T Ring Adapter which replaces the eyepiece holder on the Powermate, as described by our sponsor here:
https://www.astronomics.com/televue-t-ring-adapter-1-25-inch-powermates_p3441...
Then I'll need another adapter to allow that to attach to the DMK31 camera.
When I look at the Orion Barlow I use that I don't have a problem with, it is a shorty model, and is about the length of the Powermate when you take the eyepiece holder off the Powermate. Of course it is not an inexpensive fix, I may just be using that CN discount!
sullij1
Reged: 11/08/08
[Re: rigel123]
#5707888 - 03/01/13 10:10 PM
Thanks for the follow up Warren. Valuable information for anyone battling the issue.
Edited by sullij1 (03/01/13 10:11 PM)
marktownley
Reged: 08/19/08
[Re: sullij1]
#5708179 - 03/02/13 04:21 AM
Yes, useful info there Warren, thanks
ASTROTRUCK
Reged: 01/02/10
[Re: rigel123]
#5708611 - 03/02/13 11:25 AM
note that the advert states that removal of the nosepiece adapts to ccd's so maybe also to the dmk's
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: ASTROTRUCK]
#5708894 - 03/02/13 02:08 PM
Yep, need to read more closely before I order! The guy I spoke with at Televue was great, very helpful and asked a lot of questions about my setup before giving me the advice.
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: Bummed about my 2.5x powermate Updated
[Re: rigel123]
#5725798 - 03/11/13 12:56 PM Attachment (18 downloads)
Finally got all of the pieces and of course it is cloudy. For those of you interested, here is a look at the set up that I'll be testing out once I get to see the sun again!
First image is the Camera and Televue 2.5 X Powermate
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: rigel123]
#5725805 - 03/11/13 12:59 PM Attachment (16 downloads)
Here are the parts you need after taking the Eyepiece Holder off the Powermate (Oh yeah, you'll see where I cut and rotated the T to C adapter as I had it turned the wrong way!!)
Edited by rigel123 (03/11/13 12:59 PM)
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: rigel123]
#5725811 - 03/11/13 01:01 PM Attachment (14 downloads)
And finally assembled. I measured the distance from the Powermate to the chip prior to replacing the parts at 55mm and this brings it down to 40mm.
I'll report back after I get a chance to use it to see how it works!
raylal
Reged: 04/19/10
Loc: Cornwall, Ont., Canada
[Re: rigel123]
#5727529 - 03/12/13 06:34 AM
Good luck Warren. Anxious to see results.
Ray
Jim Lafferty
Reged: 06/30/07
[Re: raylal]
#5727603 - 03/12/13 08:16 AM
Yup thats exactly the configuration I use with a DMK 41 and 2.5x powermate--works great!
JIm
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: Jim Lafferty]
#5728242 - 03/12/13 02:02 PM
JIm
That's great to hear. I'll be sure to report back.
marktownley
Reged: 08/19/08
[Re: rigel123]
#5728641 - 03/12/13 05:26 PM
Useful to know can get that adapter from edmunds optics...
ASTROTRUCK
Reged: 01/02/10
[Re: rigel123]
#5728990 - 03/12/13 09:03 PM
the photo of the line up shows the powermate ptr1250 + an edmund adapter BUT the astronomics blurb suggests that only the 1250 is necessary as it is supposed to couple the powermate directly to the dmk ??? the quote below is from astronomikcs blurb & the adapter they refer to is the powermate ptr1250 - no edmund adapter - obvious he needs the edmund adapter but not according to astronomics ??? does the powermate piece really not couple to the camera as astronomics states it does ??
"A CCD imager can be attached directly to the adapter after removing the imager’s 1.25” nosepiece to expose the imager’s female T-threads. " - adapter being the televue piece.
appears as if 2 pieces are necessary
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: ASTROTRUCK]
#5729130 - 03/12/13 10:02 PM
It probably would directly connect to my Atik CCD camera, but definitely not to the DMK without the T to C adapter. So by saying it could connect directly to a CCD is not inaccurate, it simply is not referencing CCD's that have a C adapter rather than a T.
ASTROTRUCK
Reged: 01/02/10
[Re: rigel123]
#5731258 - 03/13/13 10:17 PM
THANKS
ASTROTRUCK
Reged: 01/02/10
[Re: ASTROTRUCK]
#5739639 - 03/17/13 09:26 PM
rigel123 -
please - i tried to find that c-t adapter for the powermate - could not locate it on the edmund site - please if you have their part # please post it - i have the same powermate so will acquire the televue part but need the edmund part # -
thanks
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: ASTROTRUCK]
#5741956 - 03/18/13 10:30 PM
rigel123 -
thanks
It is the 53-483 as shown here: http://www.edmundoptics.com/mechanics/modular-mounting-components/t-mount-com...
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: rigel123]
#5743065 - 03/19/13 02:12 PM Attachment (4 downloads)
Finally got to try out the Televue 2.5X with the new adapters and it appears as though problem solved! Not a great day to try this out on, had to set up on my Portamount II in 40 mph winds and had to keep one hand on my computer and computer garage the whole time I was stealing some frames so it wouldn't all blow across the patio! But I don't see a hint of the "ghost" image of the sun so it looks like this will work out well. Maybe this weekend I can set up the Atlas and try some shots that are not in gale force winds!!
Edited by rigel123 (03/19/13 02:14 PM)
ASTROTRUCK
Reged: 01/02/10
[Re: rigel123]
#5744081 - 03/19/13 09:50 PM
thanks - would have chosen the wrong one - the images are the same for both so seems as if there is an error on the site.
