Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
Drilling Gear Racks new
      #5669713 - 02/08/13 08:20 PM
This is primarily a question for Scott H. but I figure there are others who've used gear racks as well and may be able to comment. The racks come solid by default and need to be drilled to mount them. I'm just wondering just how hard the carbon steel racks are and if they can be easily drilled on a drill press or require more advanced machining.
Beo
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Drilling Gear Racks new [Re: Lord Beowulf]
      #5669961 - 02/08/13 11:33 PM Attachment (12 downloads)
Beo my machinist friend bored mine out and never mentioned any tough drilling problems. My 6' ones have 4 holes in each for 1/4" bolts. Mike
jbattleson
Happily Retired
Reged: 03/02/09
Loc: Nebraska
      #5670438 - 02/09/13 10:15 AM
Hi Boe,
I have both drilled and milled gear rack and it is just mild steel.
Just step out your drills. In other words start with a small
hole then increase the bit size and drill again. A 1/2" hole for an example should be stepped at least 3 times.
Happy drilling.
Scott Horstman
Vendor - Backyard Observatories
Reged: 03/11/04
Loc: Here, There and Everywhere
      #5670518 - 02/09/13 11:09 AM Attachment (10 downloads)
The racks are usually pretty mild steel but sometimes we get a batch that's pretty hard and kills the bits if you don't take your time. We counter sink the holes as well otherwise the bolt heads can hit the limit switch/carrier bearing bracket.
Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
Re: Drilling Gear Racks new [Re: Scott Horstman]
      #5671510 - 02/09/13 10:22 PM
Thanks everyone. Appreciate the feedback!
Beo
Mr_T
Reged: 04/06/08
Loc: NJ
Re: Drilling Gear Racks [Re: Lord Beowulf]
      #5672690 - 02/10/13 04:54 PM
I used a pedestal drill and some lubricant punched a dimple first and had no issues pretty easy just take it slow
10 registered and 9 anonymous users are browsing this forum.
